143.3KVIEWS
41REPLIES
73APPRECIATES
7ACTIVE PEOPLE
5 hours agoLAST POST
11-26-2025
SIB 54 03 25 (2025-11-20)
BMW X1 2025
STRUCTURE: BODY
Contamination on the outer track(s) of thes unroof cassette. This can occur on either one or both side of the sunroof cassette.
MC-11025677-0001.pdf
SIB 64 05 25 (2025-11-14)
BMW X3 2025,2026
ELECTRICAL SYSTEM, STRUCTURE: BODY, UNKNOWN OR OTHER
1. The customer states that the output air from one of the vehicle vent assemblies doesn’t match the desiredtemperature, will change temperature opposite of climate settings. 2. The customer states that the output air from one of the vehicle vent assemblies doesn’t match the desired temperature, nor change from Hot/Cold.
MC-11025683-0001.pdf
SIB 16 01 24 (2025-11-12)
BMW 5 SERIES 2023
BMW 530I 2025
BMW 7 2023
BMW 740I 2025
BMW X1 2024,2025
BMW X5 2024,2025
BMW X6 2024,2025
BMW X7 2024,2025
ELECTRICAL SYSTEM, FUEL SYSTEM, GASOLINE
RSU availability. The engine cranks but will not start.
MC-11025670-0001.pdf
SIB 12 11 25 (2025-11-12)
BMW 530I 2024,2025
BMW 740I 2024,2025
ELECTRICAL SYSTEM, ENGINE
One or both of the following faults stored in the DME: 034AA5 - Mixture control bank 1, lambda regulation, mixture too lean 034AA8 - Mixture control bank 1, lambda adaptation, mixture too rich And additionally with the faults above, these affected vehicles may have one or more of the followingirregular combustion-related faults also stored: 033812 033813 033814 033815 033816 033817 033818 033819
MC-11025668-0001.pdf
SIB 12 14 25 (2025-11-11)
BMW I4 2022,2023,2024
BMW I4 EDRIVE35 2025
BMW I4 EDRIVE40 2025
ELECTRICAL SYSTEM, POWER TRAIN
RSU availability. BMW AG is conducting a Service Action on certain Model Year 2025 - 2026 BMW vehicles that were produced between March 17, 2021 – November 6, 2025. In certain driving situations there can be a loss of traction or wheel slip followed by a throttle or torque requirement that can potentially damage the axle shafts. Damage of the drive shaft can cause it to break.
MC-11025669-0001.pdf
SIB 64 11 25 (2025-11-11)
UNKNOWN OR OTHER
Insufficient cooling power in the passenger area. The following faults may be stored: 0380CA - Malfunction or electrical fault of the heat pump circuit expansion valve detected E70C51 - Heat pump circuit changeover valve is not responding E70C44 - Heat pump circuit expansion valve is not responding
MC-11025684-0001.pdf
SIB 63 10 25 (2025-11-10)
BMW 530I 2024,2025
BMW I5 2024,2025
EXTERIOR LIGHTING
RSU availability. The ambient lighting color cannot be saved permanently. The personalized color of the ambient lighting resets after the vehicle has gone to sleep.
MC-11025685-0001.pdf
SIB 61 29 24 (2025-11-07)
BMW X5 2024,2025
BMW X6 2024,2025
BMW X7 2024,2025
BMW XM 2024,2025
ELECTRICAL SYSTEM
RSU availability. Due to a software error in the BCP, the Calibration Identification Number (CAL ID) and the Calibration Verification Number (CVN) of the vehicle are not stored correctly. They are generated with eachprogramming session and are used to identify official BMW software.
MC-11025678-0001.pdf
SIB 36 02 25 (2025-11-06)
BMW X1 2023,2024,2025
BMW X2 2024,2025
BMW X3 2026
BMW X4 2026
BMW X5 2026
BMW X6 2026
BMW X7 2026
BMW XM LABEL 2026
STEERING, WHEELS
The wheel bearing and the brake disc are not correctly aligned; are not concentric (circled). When applicable work is being performed, it is therefore difficult to remove the wheel bolts from, or fasten them into the wheel bearing hub.
MC-11025672-0001.pdf
12-02-2025
SIB 12 14 25 (2025-12-01)
BMW I4 EDRIVE40 2025,2026
BMW I4 M50 2024
BMW I4 M50 XDRIVE 2025
BMW I4 M60 2026
BMW I4 XDRIVE40 2025,2026
ELECTRICAL SYSTEM, POWER TRAIN, STEERING
MC-11025830-0001.pdf
SIB 06 61 25 (2025-11-27)
BMW 230I 2026
EXTERIOR LIGHTING
Rear Light Return
MC-11025893-0001.pdf
SIB 65 27 24 (2025-11-25)
BMW X5 2021,2022,2023,2024,2025
BMW X6 2021,2022,2023,2024,2025
BMW X7 2021,2022,2023,2024,2025
AIR BAGS
A check control message (CCM) for the restraint system (Air bag) appears. In the instrument cluster, the redair bag warning light lights up permanently. One of the following fault codes is stored in the ACSM (air bag control unit): 930949 - Knee airbag, driver: Short circuit to negative terminal 93094F - Knee airbag, front passenger: Short circuit to negative terminal 93094C - Knee airbag driver's side: Resistance too great 930952 - Knee airbag, front passenger: Resistance too great
MC-11025835-0001.pdf
SIB 24 02 25 (2025-11-25)
BMW X5 2026
BMW X6 2026
BMW X7 2026
UNKNOWN OR OTHER
DELIVERY STOP: KSG SUPPLY LINE
MC-11025832-0001.pdf
SIB 62 04 25 (2025-11-21)
BMW X5 2026
BMW X6 2026
BMW X7 2026
STRUCTURE: BODY
DELIVERY STOP: INSTRUMENT PANEL
MC-11025833-0001.pdf
SIB 06 59 25 (2025-11-20)
BMW X3 2024
BMW X4 2024
STRUCTURE: BODY
Left Door Cover Return
MC-11025853-0001.pdf
B066-25 (2025-11-20)
BMW 530I 2026
BMW 740I 2026
BMW X5 2026
BMW X6 2026
BMW X7 2026
BMW XM LABEL 2026
ENGINE
Expansion Tank Return
MC-11025855-0001.pdf
SIB 65 27 25 (2025-11-19)
BMW 230I 2026
BMW 330I 2026
BMW 430I 2026
BMW 530I 2026
BMW 740I 2026
BMW IX XDRIVE45 2026
BMW X1 2026
BMW X2 2026
BMW X3 2025,2026
BMW X5 2026
BMW X6 2026
BMW X7 2026
BMW XM LABEL 2026
ELECTRICAL SYSTEM
RSU availability. The vehicle may experience various operation faults with the infotainment system such as: Resets of the head unit Delayed start-up of the head unit (longer than 30 seconds) Failed start-up of the head unit Sporadic or permanent problems with navigation Sporadic or permanent Bluetooth connection problems Sporadic or permanent audio problems Sporadic or permanent speech / IPA (international phonetic alphabet) problems Missing displays, radio stations, camera images or applications
MC-11025841-0001.pdf
12-11-2025
RECALL 25V837000 (2025-12-08)
Affecting 25 total vehicles built between 2025-11-15 and 2025-11-15
BMW X5 2026
BMW X5 PLUG-IN HYBRID 2026
BMW X6 2026
BMW X7 2026
AIR BAGS: CRITICAL FASTENERS
BMW of North America, LLC (BMW) is recalling certain 2026 X6, X7, X5, and X5 Plug-In Hybrid vehicles. The instrument panel may have been manufactured incorrectly and prevent the passenger-side air bag from deploying properly.
12-20-2025
RECALL 25V857000 (2025-12-11)
Affecting 36922 total vehicles built between 2024-08-14 and 2025-10-20
BMW X3 2025,2026
STEERING: LINKAGES: DRAG: POWER ASSIST SYSTEM, STEERING: STEERING CONTROL MODULE
BMW of North America, LLC is recalling certain 2025-2026 X3 vehicles. While the vehicle is stationary, unexpected steering wheel movement (rotation) may occur.
ReleaseNotes_2511_US_BMW (2025-12-02)
BMW 330I 2026
ELECTRICAL SYSTEM, UNKNOWN OR OTHER
This communication contains the Release Notes for the BMW 2025-11 Remote Software Upgrade.
MC-11026705-0001.pdf
01-06-2026
SIB 66 13 23 (2026-01-05)
BMW X3 2022,2023,2024
BMW X4 2022,2023,2024
FORWARD COLLISION AVOIDANCE, FORWARD COLLISION AVOIDANCE: AUTOMATIC EMERGENCY BRAKING, FORWARD COLLISION AVOIDANCE: WARNINGS
Various Check Control messages (CCM) can be displayed to the customer, which indicate a restrictedfunction or an unavailability of the driver assistance systems or driver assistance functions. During the diagnosis, the following fault memory entries are entered individually or in combination: 800AC4 - Camera calibration failed 800AC8 - Permanent calibration error 800A24 - Temporary software fault 800ABE - KAFAS camera: Field of view permanently faulty This only affects vehicles with the following optional equipment: 5AU Driving AssistantProfessional.
MC-11026969-0001.pdf
SIB 64 09 25 (2025-12-22)
BMW I5 2024,2025
BMW I5 EDRIVE40 2024
BMW I7 2023,2024,2025
ELECTRICAL SYSTEM
A faulty electric auxiliary heater may have been installed in the certain vehicles. This could result in thefailure of the electric auxiliary heater, utilized for the vehicle interior.
MC-11026956-0001.pdf
SIB 63 09 25 (2025-12-18)
BMW 230I 2025,2026
BMW X3 2025,2026
ELECTRICAL SYSTEM, EXTERIOR LIGHTING
After programming the vehicle via ISTA/RSUto 25-07-5xx, some of the interior ambientlighting strips (examples circled) may nolonger function properly. Possible fault codes entries for F74: 804A38 – Interior lights layering (IL-LIN_3): versioning incorrect: LINslave 5 804A39 – Interior lights layering (IL-LIN_3): versioning incorrect: LINslave 6 804A3E – Interior lights layering (IL-LIN_3): versioning incorrect: LINslave 11 Possible fault codes entries for G45: 804A34 – Interior lights layering (IL-LIN_3): versioning incorrect: LINslave 1 804A35 - Interior lights layering (IL-LIN_3): versioning incorrect: LINslave 2 804A36 - Interior lights layering (IL-LIN_3): versioning incorrect: LINslave 3 804A37 - Interior lights layering (IL-LIN_3): versioning incorrect: LINslave 4 804A38 - Interior lights layering (IL-LIN_3): versioning incorrect: LINslave 5 804A3A - Interior lights layering (IL-LIN_3): versioning incorrect: LINslave 7 804A47 - Interior lights layering (IL-LIN_3): versioning incorrect: LINslave 8 804A48 - Interior lights layering (IL-LIN_3): versioning incorrect: LINslave 9
MC-11026955-0001.pdf
SIB 51 17 25 (2025-12-18)
BMW M5 2026
UNKNOWN OR OTHER
The rear tow hook cover cannot be reinstalled after it has been removed.
MC-11026951-0001.pdf
SIB 64 13 25 (2025-12-18)
BMW 330I 2024,2025,2026
BMW 430I XDRIVE 2024,2025,2026
BMW X5 2024,2025,2026
BMW X6 2024,2025,2026
BMW X7 2024,2025,2026
BMW XM 2024,2025
BMW Z4 M40I 2025,2026
ELECTRICAL SYSTEM
When performing a vehicle test, diagnostic trouble code “ 8013FE Software run time error” is found in theIHKA module. If this fault is set for two consecutive life cycles, it will turn on the check engine light on vehicles with an I-level lower than 24-11-570. This fault memory entry does not cause an impairment of functionality of the automatic air conditioningsystem.
MC-11026960-0001.pdf
SIB 34 09 25 (2025-12-17)
BMW 430I 2024,2025,2026
BMW M2 2024
BMW M3 2024,2025,2026
BMW M4 2024,2025,2026
SERVICE BRAKES
There may be an internal leakage in the brake fluid expansion tank (aka brake fluid reservoir). In the rarecase of a leak, the filling level sensor might malfunction over a relatively long period of time.
MC-11026950-0001.pdf
SIB 12 03 24 (2025-12-17)
BMW X1 2025
BMW X2 2025
The Engine Malfunction Warning is illuminated, and the following fault code is stored in the DME- FC 034AEF Exhaust Cold Start, Not Controllable
MC-11026948-0001.pdf
SIB 32 09 25 (2025-12-16)
BMW X3 2025
STEERING
Check Control message and a significant change in steering feel .
MC-11026949-0001.pdf
SIB 64 11 25 (2025-12-16)
UNKNOWN OR OTHER
MC-11026957-0001.pdf
SIB 11 10 25 (2025-12-12)
BMW 330I 2025
BMW 430I 2025
BMW 530I 2025
BMW X3 2025
BMW X4 2025
BMW Z4 M40I 2025
ENGINE
Coolant is leaking from the oil filter housing.
MC-11026946-0001.pdf
SIB 06 67 25 (2025-12-11)
BMW 230I 2026
EXTERIOR LIGHTING
Rear Light Return
MC-11027027-0001.pdf
SIB 65 28 25 (2025-12-10)
BMW 230I 2026
BMW 330I 2026
BMW 430I 2026
BMW 530I 2026
BMW 740I 2026
BMW IX 2025
BMW X1 2026
BMW X2 2026
BMW X5 2026
BMW X6 2026
BMW X7 2026
BMW XM 2025
ELECTRICAL SYSTEM
The vehicle may experience various operational issues with the Multifunction Display such as: Intermittent black screen Permanent black screen Intermittent head unit functions not displayed (i.e., Navigation screen only is black)
MC-11026964-0001.pdf
SIB 65 27 25 (2025-12-09)
BMW 230I 2026
BMW 330I 2026
BMW 430I 2026
BMW 530I 2026
BMW 740I 2026
BMW IX 2025
BMW X1 2026
BMW X2 2026
BMW X3 2025,2026
BMW X5 2026
BMW X6 2026
BMW X7 2026
BMW XM 2025
BMW XM LABEL 2026
ELECTRICAL SYSTEM
The vehicle may experience various operational issues with the infotainment system such as: Resets of the head unit Delayed start-up of the head unit (longer than 30 seconds) Failed start-up of the head unit Sporadic or permanent problems with navigation Sporadic or permanent Bluetooth connection problems Sporadic or permanent audio problems Sporadic or permanent speech / IPA (international phonetic alphabet) problems Missing displays, radio stations, camera images or applications
MC-11026963-0001.pdf
SIB 54 06 25 (2025-12-03)
BMW 530I 2024,2025
BMW I5 2024,2025
STRUCTURE: BODY
DELIVERY STOP: SUNROOF WATER DRAIN HOSE
MC-11026953-0001.pdf
SIB 06 62 25 (2025-12-01)
BMW 230I 2026
STRUCTURE: BODY
LEFT TRUNK LID HINGE RETURN
MC-11027010-0001.pdf
01-09-2026
RECALL 25V906000 (2025-12-29)
Affecting 1 total vehicles built between 2025-08-28 and 2025-08-28
ELECTRICAL SYSTEM: PROPULSION SYSTEM: CABLES
BMW of North America, LLC (BMW) is recalling one 2025 I4 EDRIVE40 vehicle. The connection between the positive battery cable and the rear power distributor may become loose.
01-23-2026
SIB 65 01 26 (2026-01-22)
BMW X3 2025
UNKNOWN OR OTHER
The customer returns after taking delivery of anew G45 X3 SAV, with a piece of the air bagwarning hang tag stuck between the centraldisplay screen upon attempting the tag’sremoval. The remaining portion of the tag is ofinsufficient length to extract it.
MC-11027775-0001.pdf
SIB 32 01 26 (2026-01-22)
BMW X3 2025
STEERING
When turning left, a “creaking” noise may be heard from the EPS when near the steering wheel end stop.The noise occurs at speeds less than 10 mph.
MC-11027764-0001.pdf
SIB 31 02 26 (2026-01-17)
BMW X3 2025
SUSPENSION
When driving over a bump (compression and rebound), a “click”-type noise may occur in the area of thefront axle. The noise can be heard on the control arm rubber mount under torsional load, and a relative movement ofthe inner core can also be seen.
MC-11027762-0001.pdf
SIB 16 02 25 (2026-01-17)
BMW 530I 2024
FUEL/PROPULSION SYSTEM
The assembly cover on the left side of the fuel tank may not have been properly plastic welded. Thiscould lead to a smell of fuel after refueling or service engine soon light (MIL) for an evaporative leakin the fuel system.
MC-11027759-0001.pdf
SIB 65 02 26 (2026-01-16)
BMW 230I 2025
BMW X1 2025
BMW X2 2025
BMW X3 2025
ELECTRICAL SYSTEM
While using BMW Intelligent Personal Assistant, the activation word (“Hey BMW”) must be reactivated afterevery terminal change, BMW Remote Software Upgrade; or customer profile change. Additionally, after a BMW Remote Software Upgrade, the setup process for the voice assistant must be runagain. This was not the case previously.
MC-11027776-0001.pdf
SIB 65 20 25 (2026-01-15)
BMW 230I 2025
BMW 330I 2025
BMW 430I 2025
BMW 530I 2025
BMW 740I 2025
BMW M3 2025
BMW M4 2025
BMW M5 2025
BMW X3 2025
BMW X5 2025
BMW X6 2025
BMW X7 2025
BMW XM 2025
ELECTRICAL SYSTEM
After replacing the Multifunctional Display (MFD), the Central Information Display (CID) is black. Thebacklight of the CID is illuminated, and touch function does register an audible sound.
MC-11027777-0001.pdf
SIB 52 19 23 (2026-01-15)
BMW X7 2022,2023,2024,2025
SEATS
In vehicles equipped with the second row 60% / 40% split seat, the flex cable assembly can come out of the seat rail mechanism (circled). This stops the forwards and backwards travel of the seat.
MC-11027769-0001.pdf
SIB 32 09 25 (2026-01-10)
BMW X3 2025
STEERING
MC-11027765-0001.pdf
SIB 51 19 25 (2026-01-09)
BMW 530I 2025
BMW M5 2025
STRUCTURE: BODY
When driving vehicle over rough roads, a rattle sound emanates from the left footwell panel.
MC-11027768-0001.pdf
SIB 24 02 25 (2026-01-09)
BMW X5 2025,2026
BMW X6 2025,2026
BMW X7 2025,2026
The threaded connection at the 48 power electronics (EME 48) may not have been properly secured. Further loosening of the connection could lead to a no-start or breakdown .
MC-11027760-0001.pdf
SIB 41 07 25 (2026-01-08)
BMW 330I 2020,2021,2022,2023,2024,2025
BMW 430I 2021,2022,2023,2024
BMW M2 2023,2024
BMW M3 2021,2022,2023,2024
BMW M4 2021,2022,2023,2024,2025
(plus 3 other models)
STRUCTURE: BODY
While driving on a smooth and/or unevenroad, a “cracking” sound is heard from therear wheel arch area (highlighted in orange) on either the right or left side.
MC-11027766-0001.pdf
SIB 51 01 26 (2026-01-06)
BMW X1 2025
BMW X3 2025
BMW X5 2025
BMW X6 2025
BMW X7 2025
UNKNOWN OR OTHER
A reference label for the tailgate SmartOpener (SMO) function (aka “touchless open,or “kick to open”) was mistakenly applied tothe bottom edge of the tailgate trim panel(either of the general locations circled) duringvehicle production.
MC-11027767-0001.pdf
SIB 61 24 25 (2026-01-03)
BMW 530I 2025
BMW 740I 2025
ELECTRICAL SYSTEM
A limited number of 48 (V) volt vehicle batteries may have been damaged during the manufacturing process;this could lead to a premature battery failure. The 48 V battery may fail, triggering a corresponding Check Control message.
MC-11027774-0001.pdf
SIB 61 23 25 (2026-01-03)
BMW 550E 2025
BMW 750E 2025
BMW M5 2025
BMW X5 2025
BMW XM 2025
ELECTRICAL SYSTEM
The malfunction indicator lamp (MIL) is triggered and 0318E2 AC charging, charging electronics 1,component protection: Overload current on AC side fault may be stored during AC charging Level 1(120 VAC). Note: Despite the fault memory entry (and the malfunction indicator lamp), the AC charging process willcontinue operating as designed and there is no related drivability complaint. Affected PHEV (plug-in hybrid electric vehicle) vehicles with CCU-03 (7.4 kW combined charging unit).
MC-11027773-0001.pdf
SIB 61 22 25 (2026-01-03)
BMW 550E 2025
BMW 750E 2025
BMW M5 2025
BMW X5 2025
BMW XM 2025
ELECTRICAL SYSTEM
The malfunction indicator lamp (MIL) may be triggered by the erroneous fault code: BA0023 - Control unit: internal fault (software group fault) In addition, the BA0008 - CCU, internal coolant temperature sensor: Signal implausible faults may be stored in the CCU memory. However, AC charging will still operate as designed, without any related drivability complaints. Affected PHEV (plug-in hybrid electric vehicle) vehicles with CCU_P1 (7.4 kW and 11 kW) with I-levels from …24-07- 500 to …25-11-5xx.
MC-11027772-0001.pdf
SIB 61 19 25 (2026-01-03)
BMW 550E 2025
BMW 750E 2023,2024,2025
BMW M5 2025
BMW X5 2024,2025
BMW XM 2023,2024,2025
ELECTRICAL SYSTEM
SITUATION The malfunction indicator lamp (MIL) is triggered by the erroneous fault code 031BFC- AC charging, charging electronics 2,internal fault: No internal capacitor discharge stored in the CCU. However, AC charging is operating as designed without a charging concern or issue. Affected PHEV vehicles have the CCU-03 (7.4 kW / 11 kW) with I-levels from 24-07-500 to 25-11-5xx
MC-11027771-0001.pdf
SIB 54 06 25 (2026-01-03)
BMW 530I 2024,2025
BMW I5 2024,2025
STRUCTURE: BODY
Through quality checks, it has been detected that the front left water drain hose for the slide/tilt sunroof isnot connected.
MC-11027770-0001.pdf
SIB 31 01 22 (2026-01-03)
BMW X1 2023,2024
BMW X2 2023,2024
BMW X3 2018,2019,2020,2021,2022,2023,2024
BMW X3 HYBRID 2021
BMW X4 2018,2019,2020,2021,2022,2023,2024
BMW X5 2019,2020,2021,2022,2023,2024
BMW X5 HYBRID 2021,2022
BMW X6 2019,2020,2021,2022,2023,2024
BMW X6 M 2019,2020
BMW X7 2019,2020,2021,2022,2023,2024
BMW XB7 2021
(plus 8 other models)
SUSPENSION, WHEELS
During inspection and/or diagnosis there is noticeable dirt/grease buildup on the axles near the inner and/orouter CV boots.
MC-11027761-0001.pdf
SIB 11 04 25 (2026-01-03)
BMW X5 2024,2025
BMW X6 2024,2025
BMW X7 2024,2025
ENGINE
Due to an assembly error the upper oil pan screws may not have been torqued correctly.
MC-11027758-0001.pdf
02-03-2026
SIB 54 01 26 (2026-01-30)
STRUCTURE: BODY
A “rattling” noise may be heard from the rear portion of the headliner when traveling over rough surfaces.
MC-11027997-0001.pdf
SIB 63 01 26 (2026-01-29)
BMW 230I 2026
EXTERIOR LIGHTING
Delivery Stop Rear Lights
MC-11027998-0001.pdf
SIB 52 07 25 (2026-01-28)
BMW 530I 2025
BMW M5 2025
STRUCTURE: BODY
The decorative trims on the head restraints of the driver’s seat and front passenger seat cause groaning noises on any route, at any temperature, even in a slightly reclined position.
MC-11027994-0001.pdf
SIB 28 01 25 (2026-01-27)
BMW X1 2024,2025,2026
BMW X2 2024,2025,2026
POWER TRAIN
SITUATION A Check Control message (CCM) displays for “Transmission oil service required” (ID 2120). This warning will typically trigger based on one of the following that applies: From 60,000 miles (~95,000 km) to 78,000 miles (~125,000 km), or After six (6) years: The “six years” time interval is determined the production date of the vehicle. It is not based on the day/date of the first registration, or the completion date of the pre-delivery check (PDI). If the vehicle is driven more than approx. 1900 miles (~3,000 km) after the first CCM, then a secondmessage will be display for “Transmission fault!” (ID 368). Note: If this service appears to have prematurely displayed as due, please follow standard technical reporting procedures before proceeding.
MC-11027985-0001.pdf
SIB 51 19 24 (2026-01-22)
BMW 530I 2024,2025
BMW 740I 2024,2025
BMW M5 2025
BMW X3 2025
VISIBILITY/WIPER
There is a matte “veil” or milky stain on theexterior mirror glass.
MC-11027991-0001.pdf
SIB 01 01 22 (2026-01-21)
BMW X6 2019
(plus 31 other models)
COMMUNICATION, ENGINE, EQUIPMENT: OTHER: OWNERS/SERVICE/OTHER MANUAL
N63TU1 CLASS ACTION SETTLEMENT SVC CAMPAIGN: OIL CONSUMPTION DIAGNOSIS/REPAIR
MC-11028000-0001.pdf
SIB 51 02 26 (2026-01-21)
BMW X3 2025,2026
STRUCTURE: BODY
The center console armrest unlock button(arrow) pops out when attempting to open,and/or when closing the center consolearmrest
MC-11027987-0001.pdf
02-05-2026
SIB 06 12 26 (2026-01-28)
BMW X3 2025
STRUCTURE: BODY
Roller Blind Return
MC-11028199-0001.pdf
InVehicle-InApp-Comm (2026-01-27)
BMW 530I 2025
BMW X3 2024
BMW X4 2024
BMW X5 2024,2025
BMW X6 2024,2025
(plus 2 other models)
AIR BAGS, ENGINE, POWER TRAIN, SERVICE BRAKES
It was determined that due to bad data input of the DSC, there can be damage to the rear axle differential of your vehicle. It is necessary that the control units in your vehicle are reprogrammed.
MC-11028297-0001.pdf
SIB 06 11 26 (2026-01-27)
BMW X3 2024
STRUCTURE: BODY
Edge Trim Return
MC-11028198-0001.pdf
SIB 06 09 26 (2026-01-27)
BMW X3 2024
UNKNOWN OR OTHER
Set of Insert Return
MC-11028195-0001.pdf
SIB 06 05 26 (2026-01-20)
BMW 230I 2025
VISIBILITY/WIPER
Headlight Return
MC-11028204-0001.pdf
02-07-2026
RECALL 26V056000 (2026-02-02)
Affecting 87394 total vehicles built between 2020-12-14 and 2022-12-14
BMW 230I 2022,2023
BMW 330I 2021,2022,2023,2024
BMW 530I 2024
BMW X3 2021,2022,2023
BMW X4 2021,2022,2023
BMW Z4 2021,2022
(plus 1 other model)
ELECTRICAL SYSTEM: STARTER ASSEMBLY
BMW of North America, LLC (BMW) is recalling certain 2021-2023 Toyota Supra, 2022-2023 2 Series Coupe, 2021-2024 5 Series (xDrive), 2021-2022 Z4, 2022-2024 4 Series (Gran Coupe), 2021-2024 4 Series (Convertible and xDrive Convertible), 2021-2023 4 Series (Coupe), 2021-2024 3 Series, 2021-2023 X4, 2021-2024 X3 vehicles. Please see the recall report for a complete list of all models. The engine starter may overheat and catch fire due to wear on an internal component.
02-24-2026
SIB 33 01 26 (2026-02-18)
BMW X1 2023,2024
BMW X2 2023,2024
SUSPENSION
1. Noise complaint: Humming or clicking type noise in the speed range of 15 – 65 mph can be heard from the rear axle. Seeattached video “V33 01 26 Humming” and “V33 02 26 Clicking” The noise may be amplified depending on road speed. Or 2. Fault memory entry: Customer has Dynamic Stability Control malfunction indicator lamp and/or related Check Control Message. The following fault codes are found in the Integrated Brake module fault memory: 4809B7: Wheel speed sensor - rear left - tooth missing 4809C2: Wheel speed sensor - rear right - tooth missing 480AB4: Wheel speed sensor - rear right – noise monitoring 480AAD: Wheel speed sensor - rear left – noise monitoring
MC-11028922-0001.pdf
SIB 65 03 26 (2026-02-17)
BMW 230I 2025
BMW X1 2025
BMW X2 2025
BMW X3 2025
ELECTRICAL SYSTEM
In Augmented View, the arrows are rotated by 180° (shown inverted below) when displayed on the CentralInformation Display (CID).
MC-11028926-0001.pdf
SIB 51 03 26 (2026-02-17)
BMW X1 2025
BMW X2 2025
BMW X3 2025
SUSPENSION
While driving on rough surfaces, a “creaking” noise can be heard from the B-pillar trim panels.
MC-11028923-0001.pdf
SIB 12 03 24 (2026-02-12)
BMW X1 2024,2025
BMW X2 2024,2025
MC-11028920-0001.pdf
SIB 65 27 25 (2026-02-11)
BMW 230I 2025,2026
BMW 330I 2026
BMW 430I 2025,2026
BMW 530I 2025,2026
BMW 740I 2025,2026
BMW IX 2025
BMW X1 2025,2026
BMW X2 2026
BMW X3 2025,2026
BMW X5 2025,2026
BMW X6 2025,2026
BMW X7 2025,2026
BMW XM 2025
BMW XM LABEL 2026
ELECTRICAL SYSTEM
MC-11028927-0001.pdf
SIB 51 14 24 (2026-02-09)
BMW 530I 2024,2026
BMW M5 2026
STRUCTURE: BODY
The hood is difficult to close, or may not close
MC-11028924-0001.pdf
SIB 31 01 26 (2026-02-04)
BMW 430I 2024
BMW IX 2024
BMW X1 2024
BMW X2 2024
BMW X3 2024
BMW X4 2024
BMW Z4 2023
SUSPENSION
When driving over an uneven road surface, a “thumping” noise can be heard from the front axle. Seeattached video V 31 01 26. Under certain weather conditions, a “groaning” noise may be heard during steering movements
MC-11028921-0001.pdf
SIB 61 01 26 (2026-02-02)
BMW 230I 2025
BMW 740I 2025
BMW IX 2025
BMW X1 2025
BMW X2 2025
BMW X3 2025
BMW X5 2025
BMW X6 2025
BMW X7 2025
ELECTRICAL SYSTEM
SITUATION During vehicle start-up the Secure Element (SE) of the BCP may fail causing communication errors. TheCheck Control message “Drive carefully. Driving stabilisation.” will appear. In addition, the fault memoryentries below will be stored within 40 seconds of each other. ACSM: 02010A - Coding: Coding data not qualified VIP: 02390A - VIP control unit: Coding data not released, signature IB: 02290A - DSC control unit: Coding data not released, signature HKFM: 020D0A - HKFM: Coding data are not qualified
MC-11028925-0001.pdf
02-25-2026
RECALL 26V096000 (2026-02-19)
Affecting 58713 total vehicles built between 2024-06-18 and 2025-04-09
BMW 550E XDRIVE 2025,2026
BMW 750E XDRIVE 2024,2025
BMW I5 EDRIVE40 2024,2025,2026
BMW I5 M60 XDRIVE 2024,2025
BMW I5 XDRIVE40 2025,2026
BMW I7 EDRIVE50 2024,2025
BMW I7 XDRIVE60 2023,2024,2025
BMW M5 2025,2026
ELECTRICAL SYSTEM: WIRING
BMW of North America, LLC (BMW) is recalling certain 2025 M5 Sportswagon, 2025-2026 M5, 2024-2025 750e xDrive, 2025-2026 550e xDrive, 2023-2025 I7, 2023-2025 7 Series, 2024-2026 i5, and 5 Series vehicles. The electrical wiring harness for the air conditioning system may become damaged during replacement of the cabin air filter.
02-27-2026
SIB 17 01 24 (2026-02-25)
BMW I5 2024,2025
BMW IX 2021,2022,2023,2024,2025
ENGINE, ENGINE AND ENGINE COOLING
There is coolant leaking from under the car Low heater output Possible Check Control message ?Drive, you can continue driving? (ID49) Possible fault codes stored in these BEV vehicles: 224163 ? Electric auxiliary heater for the high-voltage battery unit: Undervoltage or internal communication fault 8049AA - Coolant level sensor, expansion tank: Coolant level low or short circuit to ground or line disconnection 80124F ? Electric auxiliary heater: Communication in electric auxiliary heater faulty 224F60 - Coolant level sensor, expansion tank: Coolant level low or short circuit to ground or line disconnection 224111 - Cooling system for power electronics: Coolant loss detected 224107 - Cooling system for high-voltage battery unit, component protection: Detection of coolant loss
MC-11029046-0001.pdf
SIB 31 03 26 (2026-02-23)
BMW X5 2024
BMW X6 2024
BMW X7 2024
SUSPENSION
Various external influences can cause premature aging of the tension strut hydro-mount elastomer; which can lead to cracks in the material, and leakage.
MC-11029047-0001.pdf
03-14-2026
SIB 12 03 26 (2026-03-11)
BMW 230I 2023,2024,2025,2026
BMW 530I 2024,2025,2026
BMW 740I 2023,2024,2025,2026
BMW X1 2023,2024,2025,2026
BMW X2 2023,2024,2025,2026
BMW X3 2023,2024
BMW X3 2025,2026
BMW X5 2023,2024,2025,2026
BMW X6 2023,2024,2025,2026
BMW X7 2023,2024,2025
ELECTRICAL SYSTEM
BMW AG is conducting Voluntary Emissions Recall (effective March 11, 2026) on certain Model Year 2023 -2026 BMW vehicles that were produced between January 14, 2022, and September 16, 2025.
MC-11030061-0001.pdf
SIB 52 01 26 (2026-03-09)
SEATS
The customer brings vehicle in with one or both of the second row 60/40 split seats in the folded position.The seat does not respond to any requests from the second seat row seat switch button(s).
MC-11030063-0001.pdf
SIB 01 03 25 (2026-03-06)
BMW 330I 2019,2020,2021,2022
BMW M340I 2020,2021,2022
BMW X6 2020,2021,2022
STRUCTURE: BODY
The Radiator Grilles Lower Active Air Flap Assembly limited warranty for defects in materials and/or workmanship has been extended to 15 years / 150,000 miles as determined from the original first in-service / delivery date.
MC-11030060-0001.pdf
SIB 12 05 23 (2026-03-06)
BMW I5 2024
BMW I7 2023,2024
The customer states there is a Drivetrain Malfunction message displayed in the instrument cluster. In addition, the following fault memory entries are saved in the CCU (Combined Charging Unit) 0317F2 - High-voltage system, insulation fault detected: when switch contactors are closed. 0317F1 - High-voltage system, insulation resistance below warning threshold: when switch contactors are closed. The fault memory entries (isolation faults) can occur both individually and in combination and must be traced back to the eDrive motor based on the ISTA test procedure. If ISTA test procedure lists possible cause of fault as; A metal chip is found behind the brush module (between the brush module and the end shield of the electrical machine). Repair required. Refer to service solution no. 20000794435083 in Aftersales Information Research (AIR). Follow information in the Procedure section below.
MC-11030059-0001.pdf
SIB 51 05 26 (2026-03-05)
BMW IX 2024,2025
STRUCTURE: BODY
A ?groaning? noise may be heard when closing the tailgate.
MC-11030055-0001.pdf
SIB 61 03 26 (2026-03-05)
BMW 750E XDRIVE 2025
BMW M5 2026
BMW XM 2025
ELECTRICAL SYSTEM
Several complaints are possible: Vehicle does not start Gear cannot be engaged Various Check Control Messages Malfunction indicator lamp (MIL) on Several Check Control messages are possible: ?It is possible to continue driving. High-voltage system.? ?You can continue driving. Drivetrain.? ?Restart not possible. Drivetrain fault.? ?Call Roadside Assistance. Drivetrain failure.? ?Information: Total error of vehicle.? The following fault memory entries are stored in the CCU: D796D9 - Message (- 0x91) not up-to-date, receiver CCU, transmitter EME D796DC - No message (- 0x91), receiver CCU, transmitter EME D796D8 - No message (- 0x91), receiver CCU, transmitter EME Other fault codes below may be stored in the EGS BA09B8 ? Inverter, Voltage Sensor, 5V HV AUX: Out of range or open connection detected BA0A45 ? ECU internal: Internal error of the synchronous serial data bus. Additional fault memory entries are possible. Similar fault memory entries indicating a missing EMEmessage (Traction E-Machine Electronic) can also be stored in other control units.
MC-11030054-0001.pdf
SIB 61 19 25 (2026-03-04)
BMW 750E 2023,2024
BMW M5 2025,2026
BMW X5 2024,2025
ELECTRICAL SYSTEM
The malfunction indicator lamp (MIL) is triggered by the erroneous fault code 031BFC- AC charging,charging electronics 2, internal fault: No internal capacitor discharge stored in the CCU. However, AC charging is operating as designed without a charging concern or issue. Affected PHEV vehicles have the CCU-03 (7.4 kW / 11 kW) with I-levels from ?24-07-500 to ?25-11-5xx.
MC-11030053-0001.pdf
SIB 61 23 25 (2026-03-04)
BMW M5 2025,2026
BMW X5 2025
BMW XM 2025
BMW XM LABEL 2026
ELECTRICAL SYSTEM
MC-11030051-0001.pdf
SIB 61 22 25 (2026-03-03)
BMW M5 2025,2026
BMW X5 2025
BMW XM 2025
ELECTRICAL SYSTEM
Malfunction indicator lamp (MIL) is triggered by the erroneous fault code(s) BA0023 - Control unit: internalfault (software group fault) In addition, the BA0008 - CCU, internal coolant temperature sensor:Signal implausible faults may be stored in the CCU memory. However, AC charging is still operating as designed, without any related drivability complaints. Affected PHEV vehicles have the CCU-03 (7.4 kW / 11 kW) with I-levels from 24-07-500 to 25-11-5xx.
MC-11030052-0001.pdf
SIB 33 01 26 (2026-03-02)
BMW X1 2023,2024
BMW X2 2023,2024
SUSPENSION, WHEELS
1. Noise complaint: Humming or clicking type noise in the speed range of 15 ? 65 mph can be heard from the rear axle. Seeattached video ?V33 01 26 Humming? and ?V33 02 26 Clicking? The noise may be amplified depending on road speed. Or 2. Fault memory entry: Customer has Dynamic Stability Control malfunction indicator lamp and/or related Check Control Message. The following fault codes are found in the Integrated Brake module fault memory: 4809B7: Wheel speed sensor - rear left - tooth missing 4809C2: Wheel speed sensor - rear right - tooth missing 480AB4: Wheel speed sensor - rear right ? noise monitoring 480AAD: Wheel speed sensor - rear left ? noise monitoring
MC-11030056-0001.pdf
03-31-2026
New 2026-03-31
SIB 12 04 26 (2026-03-27)
BMW X3 2026
ELECTRICAL SYSTEM
DELIVERY STOP: HARNESS ROUTING
MC-11030333-0001.pdf
InVeh-InApp-Comm (2026-03-25)
BMW 430I 2025
ELECTRICAL SYSTEM
It has been determined that the Telematics Control Unit for the vehicle’s backup antenna may not have been programmed correctly. If the main antenna is damaged, the backup antenna may not be available due to the faulty programming. To correct this issue, the vehicle will need to be reprogrammed.
MC-11030315-0001.pdf
SIB 32 02 26 (2026-03-24)
BMW X3 2025
STEERING
DELIVERY STOP: STEERING GEAR
MC-11030334-0001.pdf
SIB 61 05 26 (2026-03-20)
BMW 530I 2025
BMW 740I 2025
BMW M5 2025
BMW M5 SPORTSWAGON 2025
VISIBILITY/WIPER
Customers might report that washer fluid is leaking from the lower reservoir area, especially around thewasher fluid pumps.
MC-11030307-0001.pdf
SIB 12 03 26 (2026-03-19)
BMW M5 2025
BMW X3 2023,2024
BMW X3 2025,2026
ELECTRICAL SYSTEM, ENGINE, UNKNOWN OR OTHER
PROGRAM CONTROL UNITS (OBD)
MC-11030305-0001.pdf
SIB 63 09 25 (2026-03-18)
BMW 230I 2025,2026
BMW X3 2025,2026
MC-11030309-0001.pdf
SIB 51 22 24 (2026-03-18)
BMW 330I 2024,2025
BMW 530I 2024,2025
BMW X1 2024,2025
BMW X2 2024,2025
BMW X3 2024
BMW X3 2025
BMW X4 2024,2025
BMW X5 2024,2025
BMW X6 2024,2025
BMW X7 2024,2025
BMW XM 2024,2025
On the main door seal, detachment behaviorcan be detected at the sealing joint . Over time, the seal gradually and increasinglydetaches which can cause it to- Dangle Become visible to the customer Prevent the door from closing properly
MC-11030306-0001.pdf
SIB 65 07 26 (2026-03-17)
BMW 230I 2026
BMW X1 2026
BMW X2 2026
BMW X3 2026
ELECTRICAL SYSTEM
The following message is displayed on the central information display (CID): “Storage space running out”.Afterwards, apps can no longer be updated, and additional content can no longer be loaded.
MC-11030311-0001.pdf
SIB 63 07 25 (2026-03-17)
BMW 230I 2025
EXTERIOR LIGHTING
The check control message(s) for the (brakelights, taillights, side lights, turn indicator,daytime driving lights) taillamps (highlightedin orange in the photo) is intermittentlydisplayed. Possible fault codes entries 80801E- LED driver: Communicationfaulty 80819E- LED driver: Communicationfaulty 80831E- LED driver: Communicationfaulty 80849E- LED driver: Communicationfaulty
MC-11030308-0001.pdf
SIB 65 08 26 (2026-03-16)
BMW 330I XDRIVE 2025
BMW 430I 2025
BMW 530I XDRIVE 2025
BMW 740I 2025
BMW IX 2025
BMW X1 2025
BMW X2 2025
BMW X3 2025
BMW X5 2025
BMW X6 2025
BMW X7 2025
BMW XM 2025
ELECTRICAL SYSTEM
After the software update to version …25-07-5XX, existing activation points for the “Automate My Habits”function no longer work.
MC-11030312-0001.pdf
SIB 65 04 26 (2026-03-16)
BMW 430I 2025
BMW 840I 2025
BMW Z4 M40I 2025
UNKNOWN OR OTHER
Customers may report issues with the alarm system not functioning correctly. These concerns may includeone or more of the following: Missing confirmation sound (function cannot be selected or deselected in the Central InformationDisplay (CID) menu). Alarm system deactivated (interior mirror light off). Alarm does not function. DWA LED without function after locking (no flashing/flashing). Acoustic acknowledgement is unavailable or cannot be enabled/disabled via the CID menu underdoors/windows. Tilt alarm sensor “SINE” cannot be reached via diagnostics.
MC-11030310-0001.pdf
This is an automated post created with code written by a human.
04-28-2026
New 2026-04-28
SIB 61 09 26 (2026-04-23)
BMW XM LABEL 2026
ELECTRICAL SYSTEM
An error in the Battery Management Electronics (SME) can lead to an interruption in communication, which can lead to the high-voltage system being turned off. The error is indicated by a Check Control message, and it is generally possible to continue driving until the vehicle is parked.
MC-11031569-0001.pdf
SIB 61 02 26 (2026-04-23)
BMW 740I 2024
ELECTRICAL SYSTEM
In rare occasions, control of certain vehicle security functions via the Central Information Display (CID) is restricted for a short period of time.
MC-11031567-0001.pdf
SIB 51 06 26 (2026-04-23)
BMW 430I 2022,2023,2024,2025,2026
STRUCTURE: BODY
While driving on rough surfaces, a “tapping” noise can be heard from the tailgate area
MC-11031566-0001.pdf
SIB 32 03 26 (2026-04-23)
BMW 530I 2024,2025
BMW 740I 2024,2025
BMW IX 2024,2025
STEERING
“Groaning” noise from the EPS when the steering wheel is at the end stops.
MC-11031564-0001.pdf
SIB 31 04 26 (2026-04-23)
STEERING
SITUATION When turning the steering wheel fully to the steering end stops, a ”groaning” noise can be perceived at the respective steering stop. The noise occurs at higher ambient temperatures from approx. 68°F.
MC-11031562-0001.pdf
SIB 61 06 26 (2026-04-22)
BMW I4 2024
BMW I5 2024
BMW I7 2024
BMW IX 2024
ELECTRICAL SYSTEM
Charging sessions cannot be started or they are interrupted while using a Level 2 AC high-power charging station, or with a Level 3 DC charging station. Charging may start normally but can interrupt after some time. Level 2 (240 V) Flex Charger and Wall box may also be affected. The red or white LED is displayed on the high-voltage charging socket; however, no associated fault codes are stored.
MC-11031568-0001.pdf
SIB 32 09 25 (2026-04-20)
BMW X3 2025,2026
STEERING
Check Control message and a significant change in steering feel.
MC-11031565-0001.pdf
SIB 32 02 26 (2026-04-20)
BMW X3 2025,2026
STEERING
Check Control message and a minimally changed steering feel.
MC-11031563-0001.pdf
SIB 24 01 26 (2026-04-17)
BMW M5 2025,2026
ELECTRICAL SYSTEM
A possible “jerking” motion may arise when using the Parking Maneuver Assistant in purely electric mode in vehicles with 7 kW charging power and a programmed I-level starting from 25-03-500
MC-11031572-0001.pdf
SIB 65 12 26 (2026-04-13)
BMW 230I 2025
BMW X1 2025
BMW X2 2025
BMW X3 2025
ELECTRICAL SYSTEM
After updating the vehicle to I-level …25-07-5XX, the spoken language of the navigation instructions changes from the set language for the voice assistant without the customer initiating the change.
MC-11031578-0001.pdf
SIB 12 05 26 (2026-04-10)
BMW 530I 2024
BMW 740I 2024
ELECTRICAL SYSTEM
A “knocking” sound from the fuel tank area can be heard in the passenger area. Occurrence information below. 1. The noise occurs when the engine is at idle 2. The noise occurs sporadically 3. The noise disappears when the fuel filler cap is opened 4. The noise also disappears when the tank ventilation valve is disconnected There is no relevant fault saved in the fault memory.
MC-11031571-0001.pdf
SIB 61 03 24 (2026-04-09)
BMW 750E 2024
BMW 750E XDRIVE 2026
BMW I4 M60 2026
BMW I5 2024
BMW I5 EDRIVE40 2026
BMW I7 2023,2024
BMW I7 EDRIVE50 2026
BMW M5 2025,2026
BMW XM 2023,2024
BMW XM LABEL 2026
ELECTRICAL SYSTEM
Gen 5 BEV/PHEV vehicles may set the Combined Charging Unit (CCU) in programming abort due to no communication to the HV charge socket electronics.
MC-11031576-0001.pdf
SIB 31 03 24 (2026-04-08)
STEERING, SUSPENSION
When rolling forward or backwards with the steering at full lock (left or right) without the brake applied, a “groan”-type noise may be heard from the front axle. The noise is most noticeable after load reversal. The noise can be heard beginning at the 7 second time stamp.
MC-11031573-0001.pdf
SIB 65 09 26 (2026-04-06)
BMW 230I 2025
BMW X1 2025
BMW X2 2025
BMW X3 2025
ELECTRICAL SYSTEM
The customer reports that the Intelligent Personal Assistant (IPA) does not respond to the "Hey BMW" wake up word, or to the push-to-talk (aka voice activation) button on the steering wheel. Also, various voice commands are possibly not correctly executed.
MC-11031577-0001.pdf
SIB 32 01 23 (2026-04-06)
BMW 230I 2023,2024
BMW 330E 2021,2022,2023
BMW 330I 2019,2020,2021,2022,2023,2024
BMW ALPINA XB7 2022,2023
BMW I4 2022,2023
BMW M2 2024
BMW M340I 2020,2021,2022,2023
BMW M440I 2021,2022
BMW X6 2020,2021,2022,2024
BMW X6 M 2020
BMW XM 2024
BMW Z4 2019,2020,2021,2022,2023
BMW Z4 M40I 2024
When turning the steering wheel while stationary or when driving on uneven roads; cracking, creaking, or knocking noises may be heard.
MC-11031574-0001.pdf
04-29-2026
New 2026-04-29
ReleaseNotes_2603_US_BMW (2026-04-13)
BMW 330I 2026
This communication contains the Release Notes for the BMW 2026-03 Remote Software Upgrade.
MC-11031600-0001.pdf
05-02-2026
New 2026-05-02
SIB 41 01 26 (2026-04-29)
BMW XM 2025
STRUCTURE: BODY
Delivery Stop - Tail Panel Plug
MC-11031872-0001.pdf
SIB 31 05 26 (2026-04-29)
BMW 530I 2024
SUSPENSION
“Popping” noise from the front axle when cornering and driving on uneven road surfaces.
MC-11031871-0001.pdf
5 hours ago
New 2026-05-19
SIB 64 03 26 (2026-05-07)
BMW IX 2025
ENGINE
After starting up the vehicle, a distinct, constant, “humming” noise can be heard from the right area of the instrument panel.
MC-11032742-0001.pdf
SIB 01 14 25 (2026-05-07)
BMW X3 HYBRID 2021
ENGINE
The EVAP systems purge (vent) valve limited warranty for defects in materials and / or workmanship has been extended to 15 years / 150,000 miles as determined from the original first in-service / delivery date.
MC-11032734-0001.pdf
SIB 01 03 24 (2026-05-06)
BMW Z4 M40I 2024,2025
(plus 4 other models)
ENGINE
The EVAP systems purge (vent) valve limited warranty for defects in materials or workmanship has been extended to 15 years / 150,000 miles as determined from the original in-service date.
MC-11032731-0001.pdf
SIB 01 01 26 (2026-05-06)
BMW 230I 2022,2023,2024,2025
BMW 840I 2020,2021,2022,2023,2024,2025
BMW M240I 2022,2023,2025
BMW M440I 2021,2022,2023,2024
ENGINE
MC-11032729-0001.pdf
SIB 65 20 25 (2026-05-05)
BMW 330I 2023,2024,2025,2026
BMW 430I 2023,2024,2025,2026
BMW 530I 2025
BMW 740I 2025
BMW M3 2025
BMW M4 2025
BMW M5 2025
BMW X3 2025
BMW X7 2023,2024,2025,2026
BMW XM LABEL 2026
ELECTRICAL SYSTEM
After replacing the Multifunctional Display (MFD), the Central Information Display (CID) is black. The backlight of the CID is illuminated, and touch function does register an audible sound.
MC-11032744-0001.pdf
SIB 01 02 24 (2026-05-05)
BMW 340I 2019,2020
BMW X1 2023
BMW X2 2023
(plus 16 other models)
ENGINE
MC-11032730-0001.pdf
SIB 64 12 24 (2026-05-04)
BMW 230I 2022,2023,2024,2025,2026
BMW M8 2022,2023,2024,2025
BMW X4 2022,2023,2024,2025
BMW X5 2023
BMW X6 2023
BMW X7 2023
STRUCTURE: BODY
1. Use of aftermarket accessory hang-on cellular phone holders and/or air fresheners can break the instrument panel air vent slats. Damage and/or issues caused by outside influences are not covered under the BMW limited warranties. Originally, the air vent slats were only repairable by replacing the entire front center dash vent assembly; which in some applications, also included the IHKA control module.
MC-11032743-0001.pdf
SIB 64 03 20 (2026-05-04)
BMW X5 2019,2020,2021,2022,2023,2024,2025
BMW X6 2020,2021,2023,2024,2025,2026
BMW X7 2019,2020,2021,2022,2023,2024,2025,2026
EQUIPMENT, STRUCTURE: BODY
The center console and front cup holder get noticeably too warm to the touch on long journeys with the interior "Heating on".
MC-11032741-0001.pdf
SIB 63 09 25 (2026-05-04)
BMW 230I 2025,2026
BMW X3 2025,2026
After programming the vehicle via ISTA/RSU to 25-07-5xx, some of the interior ambient lighting strips (examples circled) may no longer function properly.
MC-11032740-0001.pdf
SIB 61 09 26 (2026-05-04)
BMW X5 2025
BMW XM 2025
BMW XM LABEL 2026
ELECTRICAL SYSTEM
MC-11032739-0001.pdf
SIB 52 19 23 (2026-05-04)
BMW X7 2022,2023,2024,2025,2026
SEATS
MC-11032738-0001.pdf
SIB 51 12 24 (2026-05-04)
There are two possible situations (rear left, right or both sides): A. The electric sunshade in the rear door does not function or sticks upon operation, and/or B. The electric sunshade is wavy.
MC-11032737-0001.pdf
