The start.... June 13th 2025....
Stock vehicle (21''/22'' wheels) | 0 lbs reduction in weight | 617 HP | Gas Tank ~ 56%
Best Run: 11.953 @ 114.09 MPH
DA: +771 (using airdensityonline.com)
The middle.... August 6th 2025....
Modified vehicle (21''/21'' lightweight wheels) | -28 lbs reduction in weight | 617 hp | Gas Tank ~ 66%
Best Run: 11.975 @ 114.44 MPH
DA: +750 (using airdensityonline.com)
The end.... October 26th 2025....
Modified vehicle (21''/21'' lightweight wheels, 2ndary ER Downpipes, Titanium X Pipe - Mid Pipe) | -43 lbs reduction in weight | 627 hp? | Gas Tank ~ 60%
Best Run: 11.805 @ 115.80 MPH
DA: -490 (using airdensityonline.com)
My takeaways:
Wheels
1. I would have sworn lighter wheels, especially 7lbs less per corner would have helped a bit on the 1/4 but not even a bit. Car does feel a bit nimbler and does help with braking but nothing really on the acceleration.
2. Happy overall with the "Vossen EVO4" forged wheels and how they have held up.
Exhaust
1. Stock exhaust right after the secondary downpipe is not uniform in size, it goes from approx. 2.75'' ID to 3'' ID after the resonator.
2. Stock resonator IS an H pipe (didn't think it would be).
3. Downpipe + X pipe did help with sound, not obnoxious, not too loud and helped with responsiveness of the engine.
4. The "Allen" / "China" titanium exhaust fit very well to the stock exhaust, no issues.
Track Time
1. So did the exhaust help overall? I think so, even when you take the 2nd and the 3rd tests and use SAEJ1349 Style Air Density Normalization it still comes out to 11.923 vs. 11.840 (-.08) and 114.97 vs. 115.46 (+.5 MPH) gains. So the downpipe and X pipe is worth almost 1 tenth in the quarter if you look at it like this... not bad!
2. 0-60 was 3.59 (3.40 with 1 foot roll out)
3. Best times achieved were holding the LC for right around 2 seconds.
4. Track Mode vs. Pure M2 Mode with everything dialed up yielded no difference in times.
5. This ///M is consistent AF... like super consistent with ET and MPH, great bracket car
Weight Savings
1. Every component taken off and put back on the car was weighed... picture attached.
Thanks for the long read and next season I am going to look at JB4, possibly more weight reduction, Race Gas and that's probably enough for me.
-GT500R
