700VIEWS
7REPLIES
1APPRECIATES
2ACTIVE PEOPLE
04-05-2026LAST POST
03-27-2026
Hello,
I’ve imported my car from Canada to eastern europe.
With bimmercode I’ve managed to code almost everything I need, what’s left are the maps.
I’ve found some hints here and there on what to change but still not 100% sure.
I’ve purchased EU 2025-4 maps from eBay from some guy with lifetime FSC code, I’ve downloaded the maps but what I’ve been sent is called a repair pack which I have no idea what it means.
Seller wasn’t very cooperative and tried to sell me a separate service for 10x the money so he can change it remotely. Needless to say he stopped responding after I said I could change it myself via bimmercode...
Anyway, besides the obvious navi country change through bimmercode and extracting the maps onto the USB drive, what exactly should I do with this folder called repair pack, full of .fsc, .xml and .der files?
Thanks in advance!
03-28-2026
You can try install maps.
Among the map files, on the root of the USB flash drive create a folder named FSC and place the .fsc file inside that folder. Then insert the USB drive into your vehicle’s USB port.
03-29-2026
Which .fsc file, there are 10+ and why is the folder called repair pack?
03-29-2026
Post a list of files, screenshot
03-29-2026
First of all, thank you for helping me. Means alot.
I’m uploading a screenshot of almost all the files, as you can see every FSC_L........fsc file has the exact name corresponding L......der/.fsc/.xml
After I change the region via bimmercode expert mode, which files should I upload in the FSC folder? All of them seems weird?
I’m asking about the name repair pack because I’ve seen it here and there and I’m unfamiliar with that it’s supposed to repair?
03-29-2026
Oh, what a mess.
I really don't know, maybe you should try FSC_L088340_01540001.fsc
Or try one by one
When you bought maps and fsc code, the seller should send you one .fsc file and that's it. I don't know what complicated it.
04-04-2026
I found it, you should use this file FSC_L088340_01569912.fsc
04-05-2026
I tried contacting the seller and he literally yelled at me I need to use some sort of „change region FSC“ file first before uploading the maps, because these are just to update the EU maps I should already have. Basically what I’ve bought would not work if I had canadian maps, even if I coded the region to be EU.
Im suspicious of it, to be honest, but I can’t get any clarity on the subject of changing the maps region, step by step and what exactly do I need?
What narrowed it down to FSC_L088340_01569912.fsc?
