Finally got around to making a quick vid of my Dinan full exhaust (midpipe and axleback) with MAD secondary catless downpipes. This was taken with the valves open.
Outside shots with the valves closed do not yield a dramatic change in sound. The exhaust is nearly as loud as with the valves open, but it does eliminate some of the low end drone found between 1100 and 1600rpm which is enough for me. Mind you there is essentially no drone with the stock secondaries. Overall, I like the way it sounds. It’s aggressive enough without being overbearing.
