KayWhy wroteHere no problems with sway. Heavy stuff (drinks, bikes, chairs, sup boards) stowed in low places in the caravan.Down here in New Zealand X530i towing an Australian built Bailey caravan.
Van weighs 2,500kg (5,500lbs) fully loaded, fuel usage around 15.5 litres per 100km (15.2mpg)
X5 tows well but the factory tow hitch maximum load of 190kg (420lbs) is not enough as sway can set in. NZ speed limit when towing is 90kph (56mph) so can't get into too much trouble.
Caravan loaded weight 2200kg, hitch load 80kg
Maximum speed in some European countries with a caravan is 130km/h what the combination is doing fine, even with wind and overtaking trucks.
Fuel usage with 130km/h
so most times I drive around 100-110km/h with a fuel usage around 16,5 liters per 100km.
