110.5KVIEWS
179REPLIES
63APPRECIATES
82ACTIVE PEOPLE
03-14-2026LAST POST
05-12-2021
did the sto n sho bracket works good no drilling with ACC Radar and I can remove it with a release clip
05-12-2021
LexxM3 wrote
zhangyi17 wrote
BugKiller?:lol:
There's one picture you didn't whiteout the actual plate alphanumerics
BUGKILLR would be a great plate and quite appropriate that summer as I believe I was responsible for eliminating an entire species of insects along 401 and 400 with the X5. But no, that's not my plate. I guess my "photoshop" skills are good enough for the forum :-).
You got me. That's for sure. Was curious what sentimental value could BUGKILLER hold..:)
05-13-2021
zhangyi17 wrote
I was looking at this Sly brackets. People in this thread had concerns about only two screws to hold the license plate. So is it sturdy enough?
SlyBrackets offers a full 4-screw plate frame, which i used to mount mine including the Leveler. (the plate will angle downward a bit without the Leveler.)
05-13-2021
perfect, thanks..I am getting this as well
05-18-2021
coffeelover696969 wrote
WAARBA wrote
Thanks for all of the knowledge guys. Living in NY, I needed a front plate solution. On my F16 I had Cravenspeed. But Cravenspeed hasn't figured it out for the G05.
Went with the Sly Bracket solution on my 2021 X5 M Sport. I dont have ACC so I was able to center on the grill. Was able to install nice with no touching without using any of the supplied spacers. Yes, it does angle down a touch, but its a clean centered look, and I dont have to open up the tow opening. I purchased the option with four screw bolt on for the plate. Very snug.
Highly recommended if anyone is struggling with a front plate solution.
https://www.slybrackets.com/store/SLY-BRACKET-FOR-BMW-WITH-MESH-STYLE-LOWER-GRILLE-p287756002
Was this what you got?
Which options did you tick off on their site?
I picked up the four hole bracket with the security screws. You may consider the leveler bracket… but after having the slybracket on my car past few weeks, I dont see a need for it
02-12-2022
AndroidRobot wrote
that would be fantastic
wait so was that approved?
I researched it. The bill didn't even make it to Committee. It's dead in the water.
02-12-2022
I still don't run a front plate but that's unfortunate
02-14-2022
hey nZtiZia :)
Thanks for the post. I wanted to make sure you have no issues with any of the sensors ie: parking and assisted driving pro etc. with this plate holder.
This is just one last check before I order :)
02-15-2022
1Mors wrote
hey nZtiZia :)
no sensor issues whatsoever ;)
02-15-2022
Ordered thanks guys.. this forum is a wealth of info and community makes it what it is ..
Outstanding!!!!
03-02-2022
Thanks to everyone for their contributions to this thread. My 2022 X5 xDrive 40i with M Sport package with every optional package available went into production today, and I just ordered the Sly bracket with 4 screw holder and leveler so I'll have it when the car is delivered to the dealership.
Having this thread allowed me to make an informed choice.
03-14-2022
I used rare earth magnets to attach the front license plate on my Miata. I taped magnets to the backside from the front fascia and taped matching magnets to the license plate. Those magnets are so strong that you really have to be careful with them to not loose the tip of a finger and that license plate isn't going anywhere at any speed. Yet, there's no modification to the car at all and it looks perfectly placed on that car. Hopeful that a similar solution is available to me on the X5 M50i I just ordered.
https://www.amazingmagnets.com/default.aspx
03-14-2022
You taped the magnets behind that plastic piece and the magnetism worked through the thick plastic? Which magnet specifically did you use from that site?
03-14-2022
Absolutely worked great. When I say working with these magnets are dangerous I'm serious. They are so strong that the 1" round, 1/4" thick magnets will crush your finger tip if you get between them. They come with 1/4" nylon spacers between them so that you can get them apart individually. If you let two of them snap together you will not get them apart using a vice and big channel lock pliers. You'll break the magnets before you can get them apart. Seriously strong magnetic force.
There was quite a comedy of mistakes when I first started working with these things. For example, I wanted to lay two of these magnets on a strip of tape before applying to the back of the fascia. Nope, as soon as I let go of the second magnet on the tape that was placed 3 inches from the other magnet, they snapped together so hard and fast that I was pretty happy my fingers weren't in the way. This is how I know that you can't get them back apart! :thumsup:
Four magnets taped to the plate and four taped to the backside of the fascia has the license plate very firmly attached. I can lever it off using a lot of force and it leaves no mark on the fascia.
03-21-2022
Looking great!
Have you checked if blocking the radiator with the license plate can cause any cooling issues? and if so, is it even possible to install the plate a little higher so that it sits above the lower grill? Thanks!
04-18-2022
This installation of slybracket doesn't block anything. Looks great too. I will show you some shots of my installation and what I did.
I put a felt pad on the back where it could possibly touch the front of the grill but it fits like a glove.. No issues at all with any sensor and it doesn't block airflow at all. It also has spacers or you can use your own washers to dial it in close.. I love it
05-19-2022
most have opted for the Sly Brackets but I've read a couple use the Carbonio though no photos
05-24-2022
FWIW, read recently that CA has a pilot program where they are using a stick on plate to go on vehicles on the front, so no holes, and it peels off with no paint damage, assuming the paint was in good shape in the first place. If it works out, they may allow them for the rear as well.
05-28-2022
https://licenseplatewrap.com/
Reading through the site and other references, it looks like it's still a pilot program but available to a limited amount of people.
Personally, if the DMV okayed it then who cares who makes it. Probably just needs to be properly reflective where they want. I'm sure there's a bunch of people on Pinterest already cranking them out. Plus, I seriously doubt the police are going to pull you over if it looks legit. If it matches the back and doesn't come back as a stolen plate or not matching the vehicle it's on.
05-29-2022
if placed on a vehicle in a state where it's not approved, it's rarity will surely get one pulled over and likely cited
08-03-2022
I just installed the SlyBrackets today, but the plate is slightly tilted forward. I did bought the leveler, but couldn't follow the installation instruction. Can you show a picture without the license plate, so I can see how the leveler is supposed to work? Thanks
