Going to pick it up tomorrow and try it for myself, but what a kick in the nuts to dish out that kind of money on something customers are not aware needs to be maintained.
49KVIEWS
242REPLIES
146APPRECIATES
74ACTIVE PEOPLE
2 days agoLAST POST
charbaby wroteThis isn't like engine oil, it doesn't need to be maintained, it's an indication of a problem in either the incorrect oil being used at the factory or an issue with the transfer case. Depending on the details of your situation, the dealer may be wrong in charging you for the oil. Here's some info for you.I'm going through this right now with my 2020 X5 that is under CPO warranty. My dealership told me they need to change the fluid at a cost of $880 here in Buffalo, NY. The procedure is to then drive it for 140 miles, which with my permission they did for me. According to them, the issue was fixed and I need to pay for the service since it's not covered under warranty. However, if the fluid change did not fix the issue (rumbling at lower speeds, jerking), they would then change the Transfer Case under warranty and would not charge me for the service.
First, the SIB that details the symptoms and possible causes relating to the transfer case. Hard to say in your case if "rumbling at lower speeds, jerking" fit within this SIB but since they decided to change the oil, I've attached the SIB pdf below.
Once the oil has been changed and the car driven the necessary mileage the issue remains, per the SIB, here is a work order from one of our posters who had the oil changed but the symptoms persisted, so they disconnected the transfer case, took it out for a drive and the symptoms were gone.....then the transfer case was replaced.
Marty in NY wroteSuper helpful, thank you so much. Heading to the dealership now to see what they say. And yes, it is "shuddering" that's occurring as well.This isn't like engine oil, it doesn't need to be maintained, it's an indication of a problem in either the incorrect oil being used at the factory or an issue with the transfer case. Depending on the details of your situation, the dealer may be wrong in charging you for the oil. Here's some info for you.
Parts: $99.38
Labor: $702.86
(+ tax)
For what it's worth it is driving as it should be now, will keep an eye out on it if the shuddering comes back.
Sign me up for this class action lawsuit if one ever comes up because having to fork this out for a factory originating issue is bull sh**.
charbaby wroteI'd go to BMW and ask them what the diff is between fixing a warranty claim by changing oil or fixing it by replacing the Xfer case. To me, a fix is a fix and should be covered under warranty.Yep they wouldn't budge. They claim if the issue comes back, they will replace the transfer case and provide me a refund for the $872.44 I just paid.
Parts: $99.38
Labor: $702.86
(+ tax)
Marty in NY wroteThey wouldn't budge and my tech rep was insanely rude claiming "I'm the first car all year to have this issue" which based on this thread and the numerous other threads out there, is complete BS.I'd go to BMW and ask them what the diff is between fixing a warranty claim by changing oil or fixing it by replacing the Xfer case. To me, a fix is a fix and should be covered under warranty.
charbaby wroteWell, they're not the only BMW dealer around even if you have to go to Rochester or? and look at it this way, at least you get to claim winning the Golden Snowball award almost every year, except for just one year a few years ago when Binghamton won itThey wouldn't budge and my tech rep was insanely rude claiming "I'm the first car all year to have this issue" which based on this thread and the numerous other threads out there, is complete BS.
Has BMW admitted in writing that the wrong fluid was installed at the assembly plants?
Di3s3l_Power wroteAny further details about BMW using the wrong fluid?I could be wrong; some 2019 and 2020 had the wrong fluid in the transfer case thus higher rate of failures
rmorin1249 wroteAll I know is the date listed on the SIB so figured anything prior to that is suspectAnyone know the assembly date range for the G05 vehicles included in this TSB?
TurtleBoy wroteDon't the G05 rear wheels turn/rotate with the suspension? I think that would be differentiated from the E70.Welcome to the forum. I don't think there is any difference causing the issue. What seems to be causing the issue on some vehicles as that the wrong oil was used at the factory in some cases for the first two years or so of productions.
Marty in NY wroteGreat, I have a Feb 2019 build.All I know is the date listed on the SIB so figured anything prior to that is suspect
rmorin1249 wroteYou feeling lucky? Not all G05's in those years will have the issue. Spin the wheelGreat, I have a Feb 2019 build.
bangle butter wroteI'm not following what you mean, are you maybe referring to IAS (rear wheel steering)? That was not a standard feature until the M60i.Don't the G05 rear wheels turn/rotate with the suspension? I think that would be differentiated from the E70.
TurtleBoy wroteWelcome to the forum. I don't think there is any difference causing the issue. What seems to be causing the issue on some vehicles as that the wrong oil was used at the factory in some cases for the first two years or so of productions.
TurtleBoy wroteYeah. That's what I was referring to. Clearly it is not a factor then.I'm not following what you mean, are you maybe referring to IAS (rear wheel steering)? That was not a standard feature until the M60i.
charbaby wroteYou should’ve said That’s unreasonable. There’s a problem here I would’ve left. Said nothing kept driving it until it was not drivable. Now it’s your problem. It’s under warranty fix it.I'm going through this right now with my 2020 X5 that is under CPO warranty. My dealership told me they need to change the fluid at a cost of $880 here in Buffalo, NY. The procedure is to then drive it for 140 miles, which with my permission they did for me. According to them, the issue was fixed and I need to pay for the service since it's not covered under warranty. However, if the fluid change did not fix the issue (rumbling at lower speeds, jerking), they would then change the Transfer Case under warranty and would not charge me for the service.
rmorin1249 wroteNo, and BMW NA won't accept responsibility either. I had a case open with them and they stated they won't cover it.Anyone know the assembly date range for the G05 vehicles included in this TSB?
verruckt wroteAfter 13 BMWs I think I'm done. Between their "new designs" and lack of customer support I will likely move on but where I don't know. At my age I shouldn't be forced to go total BEV.No, and BMW NA won't accept responsibility either. I had a case open with them and they stated they won't cover it.
TurtleBoy wrote"Not recommended" can have at least 2 meanings, They recommend you don't change it; or they have no recommended service interval.It is not recommended to change the fluid in either of them for the non-M.
Personally I have absolutely no faith in the term "lifetime" fluid unless they're talking until the unit itself fails.
