7.3KVIEWS
44REPLIES
14APPRECIATES
10ACTIVE PEOPLE
05-06-2026LAST POST
05-15-2025
yzhou2004 wrote
I searched left rear suspension yesterday. Unfortunately A-premium web site only offers front.
The other options I have:
1) $300-400 aftermarket on ebay (made in china some shipped from US warehouse. Feel may be same source from A premium)
2) $500 OEM rebuilt from a company Rebuildmastertech.com based in FL. with $150 core deposit. Their website looks very professional
3) $900 from aerosus based in Germany. They replied my email said they have manufacture around the world complying with same high standards. Price includes shipping and tariffs with 2 year warranty.
4) $1500 from online BMW dealer.
I am opt for either 2) or 3)
What do you think given your experience.
I have more questions regarding installation later. Thanks.
I'm cheap, so I would be leaning towards 2)
The ebay one's I agree are more than likely same source as A-Premium. I believe the A-Premium I bought came with a 2-year warranty based off their website but who knows if they honor it on DIY install
05-16-2025
Yeah, I am leaning towards to 2) now too. Contacting them regarding warranty policy, though i don't mind risking $400 w/o warranty.
This afternoon I opened my hatch and try to replicate procedure from interior. To my surprise, I can skip most of steps. Those may be applicable to your 3 row version.
What I need to do are only 1) lift trunk floor trim panel 2) remove a plastic cover 3) remove a foam insert. Then four top mounting bolts reveal. I should have plenty room to remove and reinstall from the top.
Hope I am not overly optimistic here.
05-16-2025
Oh yeah that’s much simpler, the third-row sits practically on top where the struts mount
05-16-2025
Now I am researching how to swapping out air struts. Could not find YouTube videos on G05.
A few questions in my mind
1) did you use a lift or floor jack/stands to lift the car? I don’t have a lift but only 3 ton floor jack, a pair of 3 ton jack stands and a pair of car ramps. The max cleanable I can get from my set up is around 17 inch. Wonder if it will give me enough room to work underneath.
2) was it easy take off 4 bolts and nuts from camber (lower) control arms before removing air strut once the car is up in the air? Any sequence matters? Preload or not matters? Any thing got in your way? Did you mark eccentric bolt position before removing it?
05-17-2025
1) did you use a lift or floor jack/stands to lift the car? I don’t have a lift but only 3 ton floor jack, a pair of 3 ton jack stands and a pair of car ramps. The max cleanable I can get from my set up is around 17 inch. Wonder if it will give me enough room to work underneath. I remember using the rear center jacking area (was it the rear differential?) and having the two jack stands at the two rear jacking points along the side of the car
1) Just a 3 ton lift and jack stands, all done in the driveway. Best bet is playing with the suspension levels before turning on jacking mode, lowest setting should give you the greatest amount of jacking height but would cramp the working area a bit.
2) Taking off the bolts is easy, have a breaker bar on hand. I had a 1/2” breaker bar and a set of 1/2” impact sockets that I used with it. At the time I didn’t mark the bolts but I remember the lower control arm bolt (closest to the diff) is to be installed in a specific orientation according to ISTA. Everything else is regular unscrew then tighten and tighten again with preload.
One little side note, one of the forward sway arms is bolted in such a manner that I could not get it out, after checking ISTA it turns out to remove that bolt you have to lower the entire rear end. So you’ll have one arm that can’t be removed but shouldn’t affect being able to remove & install the strut.
05-17-2025
For tighten with preload, did you measure the distance between center of wheel hub to the edge of wheel arch fender and lift the suspension with a second jack on wheel hub or control arms? or you lower the vehicle on a ramp or something. I have seen people did both on youtube videos when changing tension struts.
Also, on the side note. do you mean you only remove three bolts (one eccentric to subframe and the closest to differentials, one to wheel carrier and, of course one to air strut joint bush) and leave one connecting to one forward sway arm loose without being removed?
From attached ISTA (left rear forward view), there are four bolts to remove to take off camber control arm.
I can tell the outermost bolt is connected to wheel carrier, the second to the outter is the bolt mounted through air strut joint bush. The innermost one should be the eccetric one to subframe which should be positioned in a specific way. From the diagram I am not the clear what's the 3rd bolt connected to. Maybe that's the one to forward swing arm you are referring?
Are you saying you don't have to take 3rd one out (red circled) to remove and reinstall air strut?
weird I did not see the requirement of lowing rear to remove 3rd bolt. Maybe I am misunderstanding something.
05-18-2025
Sorry, ignore the side-note I said. That was about a different suspension piece I was replacing back then, not related to the air strut.
For the preload, I pretty much just let the car sit on the ground and then tightened everything as much as I could. I didn't take the technical route back then.
The 3rd bolt you have circled is the sway bar end link; you have to remove that and the other bolts in the diagram to get enough space to remove the air strut. I kept the bolt closest to the wheel, cracked it loose, but left it connected to pivot it down after the other bolts were removed.
The eccentric bolt will probably give you the most trouble on install with trying to align it if I remember correct.
05-18-2025
Thanks for your replay again !
The max clearance with highest air suspension is about 10 1/2 inch.
Very impressive you can get under to tighten the bolts.
1) Did you use extension bars to do so? Or you got under the car and manuver torque wrench in the limited spaces?
2) Did you always need to use either socket or wrench to hold one side and then torque wrench to tight the othr side? I guess if not always holding the opposite, the bolt or the nut will keep spinning.
As shown in ISTA diagram and also as I craweld under and visually checked tonight, these bolts and nuts are installed in different directions.
Let me refer #1-4 bolt/nut sets as from the knuckle (outter) to the subframe (inner). And front and rear are of vehicle.
#1 knuckle bolt (rear)/nut(front) set:
E22 bolt head facing the rear and 21mm hex nut facing the front. I found no enough room to put torque wrench to tighten front 21mm nut because it is very close to another adjacent arm. So, I am thinking to use 21mm combination wrench or a pass through socket to hold the nut and then use a torque wrench with an extension to tighten the from E22 bolt.
#2 air strut bolt(rear)/nut(front) set:
There are enough room on both sides. But it'll still much easier to tighten the rear 21mm hex bolt than the front 21mm hex nut.
But I have a question why a special tool is needed "to make joint bushing tension free" as ISTA required. I could not figure out where the tension comes from during the installation steps. Still need to think a bit more how I should loose the tension w/o the special tool. Maybe a bottle jack with an arc adapter to push from below?
#3 Swing bar link bolt(front)/nut(rear) set:
Should have enough room to tighten and loose both front E14 bolt and rear 16mm nut. Seems easiest among all.
#4 Eccentric bolt(front)/washer(don't know where it is yet )/nut(rear) set:
A cross bar is somewhat in the way of tighten and loose the front 18mm hex bolt. It is a similiar similar situation as in #1 knuckle nut. I am planning to use a pass through socket to hold it while tighten the rear 12mm nut with torque wrench.
I snaps some pictures of the current position and will compare with ISTA and watch a FCP Euro video again about how to mark and replace/renew eccentric bolt/washer.
3) when you replace air struts, did you reuse all bolt/nuts/washer or you renewed them?
4) one more thing:
do you remember how to uplug the connector to air strut (last picutre)? I am always super panoroid about the connectors and afraid of breaking them off.
05-18-2025
I had a 3-foot breaker bar and used that to tighten while the car was on the ground.
Yes, you will need another wrench (either adjustable or the proper size) to fit over the nut/bolt to tighten everything. I believe the sway bar link nut comes out, but the 'bolt' is welded into the lower control arm as the only exception. When you are torqueing it, it shouldn't spin if you've tightened it enough the first time around.
Reading ISTA's explanation, they say the special tool has to be used to ensure that the lower strut mount (connecting strut to lower control arm) is installed correctly. If I remember right, the lower control arm has molded metal that essentially allows the bottom of the strut to slide into place. I honestly am unsure what the special tool really does, maybe it allows the strut to be installed at the bottom without the weight being exerted on it?
The bolt you can see as #4 in the photos, the washer can be seen on the nut side between the nut and the lower control arm. I believe it says it has to be installed oriented up. This is the part number 33306874239. If you Google the part number, you will find photos of a specifically shaped washer, hence the importance of keeping it oriented properly.
I want to say that I used a chrome socket instead of the larger impact sockets but I had a great amount of different sockets in the removal/installation, whatever fits I used.
We bought an entire used set of all the RR corner suspension as the accident had essentially torn through it all (It was also cheaper with the one listing we found on eBay selling the whole thing).
The state of the suspension when we received the car:
yzhou2004 wrote
4) one more thing:
That connector is easy, a simple tab on the wire side you push while pulling the connector back, and it will unclip. I had to replace my RR strut due to that connector being damaged on the strut itself, as you can see in the above image.
05-18-2025
Very though. Greatly appreciated.
Your toque specs link is extemelh helpful too :thumsup:
05-21-2025
Bumbleboy92 wrote
If you can get another person to help it’ll cut a lot of the time needed as I only disconnected one side of the lower control arm. Had my brother leverage the strut up and out from the front drive axle. Hardest part was doing the same on the new strut, I could easily compress the old strut but the new one was incredibly more stiff hence needing two people.
I order a refurbished strut. It should arrive tomorrow. Also went to a dealer to get all bolts/nuts.
Now going through ISTA procedure in my mind and studying your early posts again to prepare for challenges in the procedure. need to borrow your brain for some more questions below.
You mentioned the strut was incredibly more stiff above. Did you have to compress it somehow at installation? Since the new strut should have no air it, did you have to compress shock absorber? I hope not ;) I know this post was referring to front, but I have questions on installing new strut on rear camber arm as well.
ISTA procedure shows to remove old strut
1) deactivate air suspension
2) jack up the car
3) remove four sets of bolts/nuts on camber arm in the order from inner (eccentric) to outer (knucle). Did you have hard time to remove any these bolts/nuts given the suspension is dropped somewhat while car is on jack stands. Could removing one bolt/nut cause more tensions on the rest so that it is harder to remove?
4) remove wire connector from old strut
5) remove top mount screws with a second person holding old strut to prevent falling off
6) lower old struct slightly to crack banjo bolt to bleed air strut for two minutes and thenremove banjo bolt and air hose
7) guide out old strut
At this point, I assume old air strut after being fully bled will 'shrink' from pre-deactivation height before being jacked up to stands? Say, if I leave air suspension at highest level before deactivation and jacking up, the strut will shrink the most after being removed?
Then ISTA shows to install new one basically in reverse order of removal:
1) guide in new strut
2) connect air hose to new strut
3) tighten top mount screws
4) plug in wire connector
5) install bolts/nuts to camber control arm in the order from outer to inner. First set of bolt/nut (to knuckle) could be tighten without pre-loading suspension, while the rest three sets should be hand tighten at the moment.
did you remember how hard to align bolts with holes on camber arm? did you have to use a second jack to fiddle suspension height somewhat along the way to make bolts and holes lined up one after another, for the strut, sway bar end link and rear axle assembly in sequence
My main concerns are
1) if knuckle bolt/nut is tightened to spec 165nm first, will it be hard to rotate/fiddle camber arm to align the other bolts and holes?
2) The bolt/nut to air strut joint bush was removed before the old strut was full decompressed. When new strut was put back in and it should be fully decompressed and may be somewhat 'shorter' than the old one before being bled and unbolted? Did you need to fiddle camber arm for proper alignment.
Not sure if I am describing my concern clearly here.
Once the new air strut is in place and the car is lowed on the wheels. Before turning on engine and activating air suspension to fill the new air spring the new air strut has no air in it yet. Did you have to do something special to prevent air strut from being damaged? or it should be fine just sit on wheel without air for a short moment?
All these questions mostly come from my wondering why that special tool is needed to 'relieve' strut joint bush before re-tighten to specs and where the extra tension on joint bush could possibly be introduced at installation.
I came across a YT video shows the replacement of front air suspension on G11. The guy had to use ISTA to clear up some codes after the installation to make air suspension adjustable again. Did you remember having to do so?
Sorry for long post with many questions.
05-22-2025
I couldn't get either the new or old strut to compress, way too stiff even with the air completely out. That's most of the issue with maneuvering the front strut over the lower control arm and front axle, the rear is easier in that aspect since you can just unbolt one side of the rear control arm and swing it down.
With a breaker bar, it wasn't an issue at all, just be sure not to strip the sway bar link bolt, as it's not a regular hex if I remember correctly.
I did all mine at normal height, so I am unsure, unfortunately.
The bolt with the eccentric washer was probably the hardest struggle, I did use a jack to fiddle with the suspension on the rear especially with everything bolted in.
I'd leave the tightening until all your other bolts are at least threaded onto their nuts, once tightened it looses some mobility imo.
I believe all my struts when taken out where practically the same 'height' as the new struts, may need a little movement to get the bolt through the bottom of the strut but you have more play with the strut, I wouldn't tighten the top strut bolts until you have the bottom bolt through the hole.
Ensure you have the air line fully tightened to the strut and that the bolts are tightened to the best of your ability. You are perfectly fine sitting it without air, don't drive on it or it would rub on something. I actually drove on 'no-air' when we first got the car since we thought the front strut was fine, but it didn't hold air, which rubbed the front axle a little.
No codes for me, once the new strut was installed and everything was plugged in properly, it attempted to level the vehicle after turning off the jacking mode. The car can tell what angle it is on, so it will compensate. There's a chance you may have to do the ride-height level relearn method with measuring the center of the wheel to the wheel arch, but shouldn't have to if everything's put together the way it was taken apart.
I've done the ride-height level relearn a few times, and it was pretty easy, best to use a flimsy tape measure with cm markings as you need the mm readings in ISTA.
05-23-2025
As helpful as always :clap:
I will consult you more about relearn process if I have to.
Unfortunately the rebuilt part came in with a bit beaten up dust cover. Very disappointed. See pic. Emailed the company to ask for an exchange or a return. It is apparently not up to what they described and showed on their website.
To your opinion how important of dust cover? Did all your used or aftermarket parts come with decent shapes?
Now I may have go back to source a part again. There is one OEM made in 2018on eBay claimed to be unused but missing pressure retention valve. It is for sale for less than $300 because the missing part. I found an aftermarket valve online or I can reuse my OEM one. I also came across YouTube videos how to remove and reinstalled the valve piece. Maybe worth of a try.
What do you think if you were in this situation?
05-23-2025
That’s unfortunate, sadly a lot of these parts get rough-housed. The boot had some creases but that looks maybe a bit too much for a part that’s supposedly remanufactured. I’d see what the company says about a replacement, in theory it should work but would feel better with a replacement. I’ll take some photos later today of all my replacement struts to see how they look.
I also did see that same struts on eBay but the missing valve housing is questionable, never seen any of these struts not have it already and it doesn’t have a separate part number. It’s all supposed to be one-piece, with that being an OEM part it definitely has something in its history. I’d avoid it but that’s my dislike of used OEM parts speaking.
05-24-2025
all fair points.
Unfortunately, customer service come back to demand 20% restocking fee plus shipping lable for return. or shipping cost of "courtesy" replacement of boot. or sending me a new boot to replace myself. To be honest, I could not figure how to replace dust boot without taking off the bottom piece.
Not happy with the way they conduct business and dismissive tones. Told them to issue a full refund or a paypal claim and credit card charge back on their way. What a shame.
I would suggest anyone else coming across this post for future suspension work avoid this "rebuild master tech' company. I should have done more review search before I placed the order. Fooled by their web pages.
Sigh, was very excited to do an DIY this weekend. What a waste of time.
10-21-2025
Any updates? I'm wondering what did you ended up using for struts?
yzhou2004 wrote
all fair points.
10-24-2025
I am living with occasional noise for now. Thought I will take another look a while later once it is cussing me real pain. But I do find more used parts on eBay lately when more cars are totaled over the time.
10-28-2025
Yeah, I was thinking the same thing eventually there should be enough low priced used parts on eBay with decent mileage to source to source those struts. But it would be nice to know the sourse those stupid noises, and why it mostly happens during the cold drives.
12-05-2025
Similar issues here on 2021 BMW X5 xDrive M Sport Air suspension with 58K miles bought in April 2025.
After swapping out the 315/21 & 275/21 for BMW OEM wheel set 275/45/20 All season squared.
Experiencing squeaking shortly, sounds rubber to rubber from rear, mostly passenger side under 10MPH, slow speeds over bumps.
Didn't engage "Jack mode" during swap, not sure if it really impacted anything.
X5 ride seems fairly normal with no visible, None observable sagging.
It has extended warranty via 3rd party.
In October it was in for transfer case fluid swap and transfer case mount replaced (covered under warranty).
Help needed on this, as not sure what the root cause is here.
ChatGPT keeps saying to silicone lube the "isolators." but is referring to X15 X5...
Unsure to contact dealership on issue since I swapped wheels but wheels are literally X5 factory wheels.
12-15-2025
I've returned, the first real cold day for us, and drove the car. Heard a suspiciously familiar squeaking...
Coming from the rear.
I'm taking a page out of yzhou2004's user avataryzhou2004's book and going to let it be. Only heard it while in the drive-thru at night. I don't drive it often, so until it starts physically failing, I won't touch that again.
I see on eBay that both rear air struts can currently be bought for $220 each, new aftermarket. However, since I have a 3rd-row, it was a pain to tear apart the rear seat area to reach those top bolts.
01-19-2026
I bought all nut and bots but still not the air strut yet. I will drive at least another few thousand miles. Just changed my front and rear differential fluids today. Suspensions still function fine other than the noises at low speeds on uneven noise. Feel it comes from shock absorber coz air bag is working just fine.
03-23-2026
Has anyone DIY'd the the front struts on a RWD? Is it more straight forward as you don't have to get the strut over the axle?
Yzhou2004 - What did you end up going with on your rears?
Any feedback on how the A-Premium struts perform after putting some mileage on them?
Thanks for your feedback
