20.7KVIEWS
28REPLIES
45APPRECIATES
16ACTIVE PEOPLE
04-28-2026LAST POST
08-26-2025
Here you will find all of the service bulletins BMW has submitted to NHTSA for the X5/X6 (G05/G06). Bulletins usually take several weeks to appear in the NHTSA database after they are published internally in BMWTIS.
This thread will be updated with recent bulletins after they land at NHTSA and a reference is published here: https://itsanalogue.github.io/bmw-tsb/G05.html. You can find all of this information on the NHTSA website if you know where to look, but this is a consolidated list and should help search engines find and index the SIB PDFs faster.
08-26-2025
Recent Bulletins
SIB 01 14 25 (2026-05-07)
BMW X5 HYBRID 2021,2022
(plus 2 other models)
ENGINE
The EVAP systems purge (vent) valve limited warranty for defects in materials and / or workmanship has been extended to 15 years / 150,000 miles as determined from the original first in-service / delivery date.
MC-11032734-0001.pdf
SIB 01 03 24 (2026-05-06)
BMW X5 2019,2020,2021,2022,2023
(plus 10 other models)
ENGINE
The EVAP systems purge (vent) valve limited warranty for defects in materials or workmanship has been extended to 15 years / 150,000 miles as determined from the original in-service date.
MC-11032731-0001.pdf
SIB 65 20 25 (2026-05-05)
BMW X5 2023,2024,2025,2026
BMW X6 2023,2024,2025,2026
(plus 12 other models)
ELECTRICAL SYSTEM
After replacing the Multifunctional Display (MFD), the Central Information Display (CID) is black. The backlight of the CID is illuminated, and touch function does register an audible sound.
MC-11032744-0001.pdf
SIB 64 12 24 (2026-05-04)
BMW X5 2023
BMW X6 2023
(plus 5 other models)
STRUCTURE: BODY
1. Use of aftermarket accessory hang-on cellular phone holders and/or air fresheners can break the instrument panel air vent slats. Damage and/or issues caused by outside influences are not covered under the BMW limited warranties. Originally, the air vent slats were only repairable by replacing the entire front center dash vent assembly; which in some applications, also included the IHKA control module.
MC-11032743-0001.pdf
SIB 64 03 20 (2026-05-04)
BMW X5 2019,2020,2021,2022,2023,2024,2025
BMW X6 2020,2021,2023,2024,2025,2026
(plus 1 other model)
EQUIPMENT, STRUCTURE: BODY
The center console and front cup holder get noticeably too warm to the touch on long journeys with the interior "Heating on".
MC-11032741-0001.pdf
SIB 61 09 26 (2026-05-04)
BMW X5 2025
BMW X5 PLUG-IN HYBRID 2026
ELECTRICAL SYSTEM
An error in the Battery Management Electronics (SME) can lead to an interruption in communication, which can lead to the high-voltage system being turned off. The error is indicated by a Check Control message, and it is generally possible to continue driving until the vehicle is parked.
MC-11032739-0001.pdf
SIB 61 03 24 (2026-04-09)
(plus 14 other models)
ELECTRICAL SYSTEM
Gen 5 BEV/PHEV vehicles may set the Combined Charging Unit (CCU) in programming abort due to no communication to the HV charge socket electronics.
MC-11031576-0001.pdf
SIB 32 01 23 (2026-04-06)
BMW X6 2020,2021,2022,2024
BMW X6 M 2020
(plus 17 other models)
STEERING, SUSPENSION
When turning the steering wheel while stationary or when driving on uneven roads; cracking, creaking, or knocking noises may be heard.
MC-11031574-0001.pdf
InVeh-InApp-Comm (2026-03-25)
BMW X5 2025
BMW X6 2025
SERVICE BRAKES
It was determined that your vehicle was fitted with a brake booster that potentially has a faulty hydraulic valve. This may result in a modified pedal feel and a sporadic red Check Control message. The brake booster should be replaced.
MC-11030319-0001.pdf
SIB 12 03 26 (2026-03-19)
ELECTRICAL SYSTEM, ENGINE, UNKNOWN OR OTHER
PROGRAM CONTROL UNITS (OBD)
MC-11030305-0001.pdf
SIB 51 22 24 (2026-03-18)
BMW X5 2024,2025
BMW X6 2024,2025
(plus 9 other models)
STRUCTURE: BODY, UNKNOWN OR OTHER
On the main door seal, detachment behaviorcan be detected at the sealing joint . Over time, the seal gradually and increasinglydetaches which can cause it to- Dangle Become visible to the customer Prevent the door from closing properly
MC-11030306-0001.pdf
SIB 63 07 25 (2026-03-17)
BMW X5 2024,2025,2026
EXTERIOR LIGHTING
The check control message(s) for the (brakelights, taillights, side lights, turn indicator,daytime driving lights) taillamps (highlightedin orange in the photo) is intermittentlydisplayed. Possible fault codes entries 80801E- LED driver: Communicationfaulty 80819E- LED driver: Communicationfaulty 80831E- LED driver: Communicationfaulty 80849E- LED driver: Communicationfaulty
MC-11030308-0001.pdf
SIB 65 08 26 (2026-03-16)
BMW X5 2025
BMW X6 2025
ELECTRICAL SYSTEM
After the software update to version …25-07-5XX, existing activation points for the “Automate My Habits”function no longer work.
MC-11030312-0001.pdf
SIB 52 01 26 (2026-03-09)
SEATS
The customer brings vehicle in with one or both of the second row 60/40 split seats in the folded position.The seat does not respond to any requests from the second seat row seat switch button(s).
MC-11030063-0001.pdf
SIB 01 03 25 (2026-03-06)
(plus 3 other models)
STRUCTURE: BODY
The Radiator Grilles Lower Active Air Flap Assembly limited warranty for defects in materials and/or workmanship has been extended to 15 years / 150,000 miles as determined from the original first in-service / delivery date.
MC-11030060-0001.pdf
SIB 61 03 26 (2026-03-05)
(plus 4 other models)
ELECTRICAL SYSTEM
Several complaints are possible: Vehicle does not start Gear cannot be engaged Various Check Control Messages Malfunction indicator lamp (MIL) on Several Check Control messages are possible: “It is possible to continue driving. High-voltage system.” “You can continue driving. Drivetrain.” “Restart not possible. Drivetrain fault.” “Call Roadside Assistance. Drivetrain failure.” “Information: Total error of vehicle.” The following fault memory entries are stored in the CCU: D796D9 - Message (- 0x91) not up-to-date, receiver CCU, transmitter EME D796DC - No message (- 0x91), receiver CCU, transmitter EME D796D8 - No message (- 0x91), receiver CCU, transmitter EME Other fault codes below may be stored in the EGS BA09B8 – Inverter, Voltage Sensor, 5V HV AUX: Out of range or open connection detected BA0A45 – ECU internal: Internal error of the synchronous serial data bus. Additional fault memory entries are possible. Similar fault memory entries indicating a missing EMEmessage (Traction E-Machine Electronic) can also be stored in other control units.
MC-11030054-0001.pdf
SIB 61 19 25 (2026-03-04)
BMW X5 2024,2025
ELECTRICAL SYSTEM
The malfunction indicator lamp (MIL) is triggered by the erroneous fault code 031BFC- AC charging,charging electronics 2, internal fault: No internal capacitor discharge stored in the CCU. However, AC charging is operating as designed without a charging concern or issue. Affected PHEV vehicles have the CCU-03 (7.4 kW / 11 kW) with I-levels from …24-07-500 to …25-11-5xx.
MC-11030053-0001.pdf
SIB 61 23 25 (2026-03-04)
BMW X5 2025
ELECTRICAL SYSTEM
The malfunction indicator lamp (MIL) is triggered and 0318E2 AC charging, charging electronics 1,component protection: Overload current on AC side fault may be stored during AC charging Level 1(120 VAC). Note: Despite the fault memory entry (and the malfunction indicator lamp), the AC charging process willcontinue operating as designed and there is no related drivability complaint. Affected PHEV (plug-in hybrid electric vehicle) vehicles with CCU-03 (7.4 kW combined charging unit).
MC-11030051-0001.pdf
SIB 61 22 25 (2026-03-03)
BMW X5 2025
ELECTRICAL SYSTEM
Malfunction indicator lamp (MIL) is triggered by the erroneous fault code(s) BA0023 - Control unit: internalfault (software group fault) In addition, the BA0008 - CCU, internal coolant temperature sensor:Signal implausible faults may be stored in the CCU memory. However, AC charging is still operating as designed, without any related drivability complaints. Affected PHEV vehicles have the CCU-03 (7.4 kW / 11 kW) with I-levels from 24-07-500 to 25-11-5xx.
MC-11030052-0001.pdf
SIB 51 04 26 (2026-02-24)
BMW X5 2024
STRUCTURE: BODY
A slight depression or outline (circled) may bevisible on the top passenger side of theinstrument panel.
MC-11029069-0001.pdf
SIB 31 03 26 (2026-02-23)
BMW X5 2024
BMW X6 2024
SUSPENSION
Various external influences can cause premature aging of the tension strut hydro-mount elastomer; which can lead to cracks in the material, and leakage.
MC-11029047-0001.pdf
SIB 61 01 26 (2026-02-20)
BMW X5 2025
BMW X6 2025
(plus 8 other models)
ELECTRICAL SYSTEM
During vehicle start-up the Secure Element (SE) of the BCP may fail causing communication errors. TheCheck Control message “Drive carefully. Driving stabilisation.” will appear. In addition, the fault memoryentries below will be stored within 40 seconds of each other. ACSM: 02010A - Coding: Coding data not qualified VIP: 02390A - VIP control unit: Coding data not released, signature IB: 02290A - DSC control unit: Coding data not released, signature HKFM: 020D0A - HKFM: Coding data are not qualified
MC-11029070-0001.pdf
SIB 65 27 25 (2026-02-11)
BMW X5 2025,2026
BMW X6 2025,2026
(plus 13 other models)
ELECTRICAL SYSTEM
The vehicle may experience various operational issues with the infotainment system such as: Resets of the head unit Delayed start-up of the head unit (longer than 30 seconds) Failed start-up of the head unit Sporadic or permanent problems with navigation Sporadic or permanent Bluetooth connection problems Sporadic or permanent audio problems Sporadic or permanent speech / IPA (international phonetic alphabet) problems Missing displays, radio stations, camera images or applications
MC-11028927-0001.pdf
SIB 54 01 26 (2026-01-30)
BMW X6 2024,2025,2026
STRUCTURE: BODY
A “rattling” noise may be heard from the rear portion of the headliner when traveling over rough surfaces.
MC-11027997-0001.pdf
InVehicle-InApp-Comm (2026-01-23)
BMW X5 2024
BMW X6 2024
AIR BAGS
The ACSM control unit, which controls the driving safety and driving dynamics sensor system, may be faulty. Cracks could have formed on the printed circuit board during production. In very rare cases, the crack can enlarge due to mechanical load and lead to failure of the control unit. In this case, the driver will be informed accordingly by various warning displays about the failure and deactivation of the driving safety functions as well as restricted driving dynamics functions.
MC-11028296-0001.pdf
BMW X5 2025
BMW X6 2025
POWER TRAIN
The right rear drive shaft may not have been manufactured correctly during production and may break. In the event of a fault, you will hear significant noises in the area of the rear axle and the driving performance will be noticeably reduced. At the same time, warning lights and Check Control messages will be shown on the Central Display.
MC-11028294-0001.pdf
SIB 01 01 22 (2026-01-21)
BMW X6 2019
(plus 31 other models)
COMMUNICATION, ENGINE, EQUIPMENT: OTHER: OWNERS/SERVICE/OTHER MANUAL
N63TU1 CLASS ACTION SETTLEMENT SVC CAMPAIGN: OIL CONSUMPTION DIAGNOSIS/REPAIR
MC-11028000-0001.pdf
SIB 24 02 25 (2026-01-09)
BMW X5 2025,2026
BMW X6 2025,2026
ELECTRICAL SYSTEM, UNKNOWN OR OTHER
The threaded connection at the 48 power electronics (EME 48) may not have been properly secured. Further loosening of the connection could lead to a no-start or breakdown .
MC-11027760-0001.pdf
SIB 51 01 26 (2026-01-06)
BMW X5 2025
BMW X6 2025
UNKNOWN OR OTHER
A reference label for the tailgate SmartOpener (SMO) function (aka “touchless open,or “kick to open”) was mistakenly applied tothe bottom edge of the tailgate trim panel(either of the general locations circled) duringvehicle production.
MC-11027767-0001.pdf
SIB 31 01 22 (2026-01-03)
BMW X6 2019,2020,2021,2022,2023,2024
BMW X6 M 2019,2020
(plus 15 other models)
SUSPENSION, WHEELS
During inspection and/or diagnosis there is noticeable dirt/grease buildup on the axles near the inner and/orouter CV boots.
MC-11027761-0001.pdf
SIB 11 04 25 (2026-01-03)
BMW X5 2024,2025
BMW X6 2024,2025
ENGINE
Due to an assembly error the upper oil pan screws may not have been torqued correctly.
MC-11027758-0001.pdf
SIB 64 13 25 (2025-12-18)
ELECTRICAL SYSTEM
When performing a vehicle test, diagnostic trouble code “ 8013FE Software run time error” is found in theIHKA module. If this fault is set for two consecutive life cycles, it will turn on the check engine light on vehicles with an I-level lower than 24-11-570. This fault memory entry does not cause an impairment of functionality of the automatic air conditioningsystem.
MC-11026960-0001.pdf
SIB 65 28 25 (2025-12-10)
BMW X5 2026
BMW X6 2026
ELECTRICAL SYSTEM
The vehicle may experience various operational issues with the Multifunction Display such as: Intermittent black screen Permanent black screen Intermittent head unit functions not displayed (i.e., Navigation screen only is black)
MC-11026964-0001.pdf
RECALL 25V837000 (2025-12-08)
Affecting 25 total vehicles built between 2025-11-15 and 2025-11-15
BMW X5 2026
BMW X6 2026
AIR BAGS: CRITICAL FASTENERS
BMW of North America, LLC (BMW) is recalling certain 2026 X6, X7, X5, and X5 Plug-In Hybrid vehicles. The instrument panel may have been manufactured incorrectly and prevent the passenger-side air bag from deploying properly.
RCRIT-25V837-0097.pdf
SIB 65 27 24 (2025-11-25)
BMW X5 2021,2022,2023,2024,2025
BMW X6 2021,2022,2023,2024,2025
AIR BAGS
A check control message (CCM) for the restraint system (Air bag) appears. In the instrument cluster, the redair bag warning light lights up permanently. One of the following fault codes is stored in the ACSM (air bag control unit): 930949 - Knee airbag, driver: Short circuit to negative terminal 93094F - Knee airbag, front passenger: Short circuit to negative terminal 93094C - Knee airbag driver's side: Resistance too great 930952 - Knee airbag, front passenger: Resistance too great
MC-11025835-0001.pdf
SIB 62 04 25 (2025-11-21)
BMW X5 2026
BMW X6 2026
STRUCTURE: BODY
DELIVERY STOP: INSTRUMENT PANEL
MC-11025833-0001.pdf
SIB 16 01 24 (2025-11-12)
BMW X5 2024,2025
BMW X6 2024,2025
(plus 6 other models)
ELECTRICAL SYSTEM, FUEL SYSTEM, GASOLINE
RSU availability. The engine cranks but will not start.
MC-11025670-0001.pdf
SIB 61 29 24 (2025-11-07)
BMW X5 2024,2025
BMW X6 2024,2025
ELECTRICAL SYSTEM
RSU availability. Due to a software error in the BCP, the Calibration Identification Number (CAL ID) and the Calibration Verification Number (CVN) of the vehicle are not stored correctly. They are generated with eachprogramming session and are used to identify official BMW software.
MC-11025678-0001.pdf
SIB 36 02 25 (2025-11-06)
BMW X5 2026
BMW X6 2026
STEERING, WHEELS
The wheel bearing and the brake disc are not correctly aligned; are not concentric (circled). When applicable work is being performed, it is therefore difficult to remove the wheel bolts from, or fasten them into the wheel bearing hub.
MC-11025672-0001.pdf
SIB 12 02 24 (2025-10-31)
BMW X5 2022,2023,2024
BMW X6 2022,2023,2024
ENGINE, ENGINE AND ENGINE COOLING
RSU availability. VOLUNTARY EMISSIONS RECALL 24E-A02: VALVETRONIC
MC-11024709-0001.pdf
SIB 61 28 24 (2025-10-29)
BMW X5 2024
BMW X6 2024
ELECTRICAL SYSTEM
RSU availability. Due to a software error in the BCP, the Calibration Identification Number (CAL ID) and the CalibrationVerification Number (CVN) of the vehicle are not stored correctly. They are generated with eachprogramming session and are used to identify official BMW software.
MC-11024716-0001.pdf
SIB 65 25 25 (2025-10-10)
BMW X5 2025
BMW X6 2025
(plus 7 other models)
ELECTRICAL SYSTEM
After the software update to I-level version …25-07-530, the Alexa app may disappear from the App Menu in the head unit (HU-H5).
MC-11024727-0001.pdf
RECALL 25V671000 (2025-10-08)
Affecting 3 total vehicles built between 2025-07-15 and 2025-08-06
BMW X6 2026
VISIBILITY: WINDSHIELD: CRITICAL FASTENERS
BMW of North America, LLC (BMW) is recalling certain 2026 X4 and X6 vehicles. The windshield may not be sealed properly, allowing water to enter the power distribution box or electronic control unit.
SIB 84 06 25 (2025-10-03)
ELECTRICAL SYSTEM
In some situations, an emergency call may be triggered in the vehicle without either the customer pressing the SOS Call button, or an airbag deployment event. In some cases, the customer may not even be inside the vehicle.
MC-11024211-0001.pdf
RECALL 25V644000 (2025-09-26)
Affecting 145102 total vehicles built between 2018-03-20 and 2025-02-11
BMW X5 2019,2020
BMW X6 2020
ELECTRICAL SYSTEM: STARTER ASSEMBLY
BMW of North America, LLC (BMW) is recalling certain 2020 340I, X6, 2020-2025 840I, 2020-2022 740LI, 2019-2020 X7, and X5 vehicles. After repeated attempts, the starter motor may overheat from an electrical overload.
RCRIT-25V644-4636.pdf
SIB 34 08 25 (2025-09-18)
BMW X6 2024,2025
ELECTRICAL SYSTEM
Starting from I-level …24-07-500, it is possible that the Automatic Hold function is not automatically storedfor the next journey. The function must be activated again by the driver at the beginning of every trip. After asoftware update to 25-03-500 and higher, this occurs more frequently.
MC-11024205-0001.pdf
SIB 11 05 25 (2025-09-18)
BMW X5 2025,2026
BMW X6 2025
ENGINE
MC-11023247-0001.pdf
SIB 33 03 25 (2025-09-03)
POWER TRAIN
The rear right driven half-shaft (aka output shaft/driven shaft) may not have been manufactured correctly during production and may break. In the event of a failure, there could be significant noises in the area of the rear axle and the driving performance will be noticeably reduced.
MC-11023120-0001.pdf
RECALL 25V556000 (2025-08-27)
Affecting 1406 total vehicles
BMW X5 2026
BMW of North America, LLC (BMW) is recalling certain 2026 X5 Plug-in Hybrid, X5, and X7 vehicles. The windshield may not be sealed properly, which can allow water to enter the power distribution box or electronic control unit.
SIB 65 19 25 (2025-08-26)
BMW X5 2025
BMW X6 2025
ELECTRICAL SYSTEM
Central Information Display (CID) in the vehicle is black or only displays “BMW”. The head unit (HU-H5) is not responding in ISTA. Additionally, the Receiver Audio Module (RAM), Instrument Cluster (KOMBI) and Telematic Module 4 (TCB4) may not be responding in ISTA.
MC-11022856-0001.pdf
SIB 63 06 25 (2025-08-26)
BMW X5 2022,2023,2024,2025
ELECTRICAL SYSTEM
The headliner light partially/does not illuminate.
MC-11022360-0001.pdf
SIB 41 04 24 (2025-08-20)
BMW X5 2025
BMW X6 2025
STRUCTURE: BODY
A groaning sound from the front of the vehicle while driving can be heard, particularly while cornering. The groaning sound can be heard in the A-pillar/instrument panel area.
MC-11022859-0001.pdf
SIB 51 04 24 (2025-08-20)
BMW X5 2023,2024
STRUCTURE, STRUCTURE: BODY, STRUCTURE: BODY: TAILGATE
While driving on rough/uneven roads, a buzzing sound can be heard from the upper tailgate interior trim panel.
MC-11022104-0001.pdf
SIB 11 06 25 (2025-08-04)
BMW X5 2024
ENGINE
Due to an assembly error, the oil pump screws may not have been torqued correctly.
MC-11021816-0001.pdf
SIB 52 09 25 (2025-07-22)
BMW X5 2024
BMW X6 2024
ELECTRICAL SYSTEM
The seat lumbar system “Massage” will not function if the module needs to be initialized. This can occur toeither the driver’s and/or passenger side seat. Here is a list of possible faults: Seat pneumatics module front right SPNM VR 025908 - SPNMVR: Control unit is not coded 02590B - SPNMVR: Control unit is not encoded for the vehicle 806927 - SPNMVR: Installation location not taught in Seat pneumatics module front left SPNM VL 025308 - SPNMVL: Control unit is not coded 02530B - SPNMVL: Control unit is not encoded for the vehicle 8067A7 - SPNMVL: Installation location not taught in Seat Module Driver FAS SMFA 80301E - No seat adjustment because of engine start conditions Seat Module Passenger BFS SMBF 802C1E - No seat adjustment because of engine start conditions Seat Module Driver’s Side Rear FAH SMFAH 802E1E - No seat adjustment because of engine start conditions Seat Module Passenger Side Rear BFH SMBFH 802A1E - No seat adjustment because of engine start conditions
MC-11020931-0001.pdf
SIB 63 04 18 (2025-07-21)
BMW X6 2020,2021,2022,2023,2024
BMW X6 M 2020
(plus 44 other models)
AIR BAGS, ELECTRICAL SYSTEM, EQUIPMENT, EXTERIOR LIGHTING, EXTERIOR LIGHTING: HEADLIGHTS: DAYTIME RUNNING LIGHTS: BULBS, VISIBILITY/WIPER
One or more of the LED daytime running lights are dim or discolored.
MC-11020927-0001.pdf
SIB 12 07 25 (2025-07-17)
A quality check revealed that the DME in these vehicles has a programming error. This results in a deviation of the fuel-air mixture in the internal combustion engine.
MC-11020933-0001.pdf
SIB 66 03 25 (2025-07-14)
BMW X5 2020,2021,2022,2023,2024,2025
BMW X6 2020,2021,2022,2023,2024,2025
ELECTRICAL SYSTEM, STRUCTURE: BODY
Check control message is displayed indicating the parking assistance systems have limited functionality dueto errors detected within PDC sensors. The warning indicates parking assistance features have limitedfunctionality while the errors continue to be detected. Following faults may be stored 8031BA Ultrasonic Sensor Rear Side Left Software Error 8031CO Ultrasonic Sensor Rear outer left Software error 8031AE Ultrasonic Sensor Rear Outer Right Software Error 8031A8 Ultrasonic Sensor Rear Side Right Software Error 8031B4 Ultrasonic Sensor Rear Middle Right Software Error 8031C6 Ultrasonic Sensor Rear Middle Left Software Error
MC-11020916-0001.pdf
SIB 34 10 25 (2025-07-14)
BMW X5 2024
BMW X6 2024
SERVICE BRAKES
After programming from the I-Levels between …24-03-505 and lower than …24-03-540 to I-Level …24-11-530 or higher, the following CCM may be displayed: “CCM-2525: Brake system. Drive at moderate speed”
MC-11020910-0001.pdf
SIB 24 01 25 (2025-07-10)
BMW X5 2025
BMW X6 2025
ELECTRICAL SYSTEM, POWER TRAIN
A software error in the transmission control unit (EGS) will prevent OBD/emissions related information from being read out with a “scan tool”.
MC-11020908-0001.pdf
SIB 51 12 23 (2025-07-02)
BMW X5 2020,2023,2024,2025
BMW X6 2020,2023,2024,2025
STRUCTURE: BODY
After carrying out the vehicle test, one or more of the stored faults indicate that the operation of the front bottom active air flap is obstructed or blocked.
MC-11020911-0001.pdf
SIB 11 03 25 (2025-07-01)
BMW X5 2024,2025
BMW X6 2024,2025
ENGINE
The “Check Engine Oil Level” warning is displayed while driving due to one of the following: Shortly after a detailed measurement has been carried out Shortly after engine oil has been topped up Shortly after an engine oil service has been carried out
MC-11020906-0001.pdf
SIB 37 02 25 (2025-06-12)
BMW X5 2025
BMW X6 2025
ENGINE, SUSPENSION
The air line on the air suspension supply system may not be properly installed. In the event of a fault, residual pressure is maintained in the struts and corresponding check control message.
MC-11019565-0001.pdf
SIB 72 04 17 (2025-06-11)
BMW X5 2019,2020
(plus 19 other models)
AIR BAGS, ELECTRICAL SYSTEM, SEAT BELTS: FRONT: BUCKLE ASSEMBLY, SEATS
The Supplemental Restraint Systems (SRS) Front Passenger’s Seat Occupancy Capacitive Interior Sensor (CIS) Mat for defects in materials and/or workmanship that causes a false seat occupancy alert to occur has been extended to 10 years / 120,000 miles as determined from the vehicle's original inservice / first delivery date.
MC-11019578-0001.pdf
SIB 34 04 25 (2025-06-11)
ELECTRICAL SYSTEM, SERVICE BRAKES
As a result of a data input error, certain fault memories are permanently stored. The permanent storage offault memories does not comply with the legal specifications of the authority (California Air Resources Board– CARB). The fault has no effect on the use of the vehicle by the customer.
MC-11019563-0001.pdf
SIB 32 07 25 (2025-06-11)
BMW X5 2025
SUSPENSION
Rattling/knocking noise from the front axle at low speeds of less than 15 mph. The noises are induced by driving over rough road surface or by brake operation. The noises occur during straight ahead driving or cornering.
MC-11019562-0001.pdf
SIB 12 04 25 (2025-06-11)
BMW X6 2022,2023
(plus 11 other models)
ELECTRICAL SYSTEM
EMISSIONS RECALL 25E-A02: PROGRAM CONTROL UNITS
MC-11019554-0001.pdf
SIB 27 02 20 (2025-06-06)
BMW X5 2019,2020,2023,2024,2025
(plus 38 other models)
LANE DEPARTURE, POWER TRAIN, WHEELS
There is a jerking or shuddering during either or both of the following: Cornering or accelerating from low speeds Driving with low to medium loads
MC-11019579-0001.pdf
SIB 65 35 24 (2025-06-03)
BMW X5 2024,2025
BMW X6 2024,2025
ELECTRICAL SYSTEM
Customers may report that the Central Information Display (CID) side of the Multifunction Display flickersonce on and off. This flickering is not continuous but may occur once every 15 to 50 seconds. No fault memory entry is stored for this customer complaint.
MC-11019580-0001.pdf
SIB 66 07 25 (2025-05-30)
BMW X5 2024
BMW X6 2024
ELECTRICAL SYSTEM
The speed limit warning adopted speed, which is set by the customer, is automatically reverting to lowervalue after an extended duration of the sleep cycle.
MC-11018732-0001.pdf
SIB 51 10 25 (2025-05-28)
BMW X5 2024
BMW X6 2024
STRUCTURE: BODY
A whistling sound is heard coming from the front end of the vehicle while driving at various speeds.
MC-11018725-0001.pdf
SIB 12 05 25 (2025-05-24)
BMW X5 2024
Moisture may enter the start generator supply line and cause corrosion inside the line.
MC-11018723-0001.pdf
SIB 65 15 25 (2025-05-20)
BMW X5 2024
BMW X6 2024
ELECTRICAL SYSTEM
When initiating a phone call to a specific saved contact, Intelligent Personal Assistant may not be able tolocate the contact or may call the incorrect contact.
MC-11018549-0001.pdf
SIB 01 04 25 (2025-05-19)
BMW X5 HYBRID 2022
ENGINE
The high-voltage battery assemblys refrigerant circuit expansion valves limited warranty for defects in materials and/ or workmanship has been extended to 15 years / 150,000 miles as determined from theoriginal first in-service / delivery date.
MC-11018560-0001.pdf
SIB 01 08 25 (2025-05-14)
STRUCTURE: BODY
A vehicle listed above may arrive with a Check Control Message (CCM), and/or malfunction indicator lamp(MIL) illuminated. After carrying out the vehicle test, one or more of the stored faults indicate that the operation of the front bottomactive air flap is obstructed or blocked. Thoroughly inspect the front bottom air flap, when applicable, remove any contamination that is found caught inand between the bottom air flaps (aka “blinds”) and/or the housing.
MC-11018730-0001.pdf
SIB 84 02 25 (2025-05-13)
BMW X5 2025
BMW X6 2025
ELECTRICAL SYSTEM
When making phone calls via BMW Bluetooth (not Apple CarPlay) in the vehicle, the person in the calloutside the vehicle hears a distorted voice reproduction.
MC-11018554-0001.pdf
SIB 65 09 25 (2025-05-08)
BMW X5 2024
BMW X6 2024
ELECTRICAL SYSTEM
Customer may complain that Projected Modes (Apple CarPlay/Android Auto) do not connect in the vehicle. Itis found that the WiFi in the vehicle is also not active and cannot be turned on.
MC-11018546-0001.pdf
SIB 34 06 25 (2025-05-02)
BMW X5 2024
BMW X6 2024
SERVICE BRAKES
Brake “groaning” noises heard at the rear axle at slow speeds, i.e. close to standstill, stop and go driving;when parking or maneuvering.
MC-11018518-0001.pdf
SIB 51 30 19 (2025-04-29)
BMW X6 2019,2020,2021,2022,2023,2024,2025
BMW X6 M 2019,2020
A groaning noise is present from the door frame of any door, most commonly when driving over rough roadsor during body flex. This situation may be worse in vehicles which are regularly waxed in th e area of the door jamb.
MC-11017506-0001.pdf
SIB 65 08 25 (2025-04-28)
BMW X5 2025
BMW X6 2025
ELECTRICAL SYSTEM
Central Information Display (CID) side of the Multifunction Display may intermittently black out.
MC-11017569-0001.pdf
SIB 24 02 24 (2025-04-18)
BMW X5 2024
POWER TRAIN
Due to a manufacturing issue, the torque on the bolts of the transmission Mechatronics was not carried outaccording to the specification. The faulty torquing can cause a malfunction within the transmission, and as a result, the emergencyoperation of the transmission.
MC-11017286-0001.pdf
SIB 61 02 25 (2025-04-18)
BMW X5 2024,2025
BMW X6 2024,2025
ELECTRICAL SYSTEM, FUEL/PROPULSION SYSTEM, SUSPENSION
Due to unfavorable tolerances, the Power Control Unit (PCU) may switch off under heavy loads and nolonger charge the Lithium-Ion (Li-Ion) Auxiliary (AUX) battery. This leads to the failure of the roll stabilization,and loss of communication to the EARS modules (S 0421 & S 0422).
MC-11017283-0001.pdf
SIB 01 07 25 (2025-04-15)
STRUCTURE: BODY
MC-11017102-0001.pdf
SIB 51 07 23 (2025-03-21)
BMW X5 2024
BMW X6 2024
STRUCTURE: BODY
This bulletin outlines known areas of upper and lower tailgate functionality, operational noise, or static noise for the vehicles listed above. It serves only as a diagnostic resource in troubleshooting complaints from the tailgate area. This bulletin and the associated attachment are designed to provide one single diagnostic resource for troubleshooting all known issues related to the tailgate of the BMW Sports Activity Vehicles/Coupes (SAV/SAC) which have quality improvement measures already in place.
MC-11015856-0001.pdf
SIB 64 03 25 (2025-03-13)
BMW X5 2024,2025
ELECTRICAL SYSTEM
Check Engine Light is illuminated, check control message indicates “bring in for service”. The faultsthemselves and the Malfunction Indicator Lamp (MIL) have no functional effect on the vehicle. There are multiple missing message fault codes (DTC) stored in the integrated automatic heating/airconditioning system (IHKA) control unit. These faults may include: E71458 - AC-LIN: Message EKMV20 E71459 - AC-LIN: Message EDH NOTE: These faults are secondary message faults and may not show up when performing the vehicle test.They will show up when looking at the operation report.
MC-11015821-0001.pdf
SIB 01 13 23 (2025-03-12)
BMW X6 M 2020
AIR BAGS, EQUIPMENT, UNKNOWN OR OTHER
CLASS ACTION SETTLEMENT: F95 F96 G05 G06 G07 FRONT CENTER CONSOLE CUPHOLDER
MC-11015850-0001.pdf
SIB 52 05 25 (2025-02-28)
BMW X5 2025
BMW X6 2025
ELECTRICAL SYSTEM
The customer states: The driver’s seat will not return to its last saved position. No seat memory. The heated seats settings in the menu are missing/different than in their previous BMW vehicle. They canno longer select, under the climate rules, at what temperature Fahrenheit the heated seats willautomatically turn on. Certain other “apps” and functions are not available The driver’s seat moves to an unknown memory position
MC-11014660-0001.pdf
SIB 62 02 25 (2025-02-26)
BMW X5 2024
BMW X6 2024
UNKNOWN OR OTHER
For certain model vehicles with the S68T engine, the Condition Based Service (CBS) data may show sparkplug replacement is due at a considerably “earlier” interval than specified in the Service and WarrantyInformational Booklet.
MC-11014663-0001.pdf
SIB 11 07 23 (2025-02-20)
BMW X5 2023,2024
BMW X6 2023,2024
ENGINE, ENGINE AND ENGINE COOLING, ENGINE AND ENGINE COOLING: EXHAUST SYSTEM
The return springs on the exhaust camshaft followers (switchable rocker arm) may break.
MC-11014420-0001.pdf
SIB 51 08 24 (2025-02-14)
BMW X5 2025
BMW X6 2025
UNKNOWN OR OTHER
The Augmented Reality Camera (ARCAM) shows up blurry when activated.
MC-11014509-0001.pdf
SIB 51 46 16 (2025-02-03)
BMW X6 M 2019,2020
(plus 70 other models)
Upon opening and closing the tailgate, a creaking/groaning sound can be heard from tailgate actuator.
MC-11014038-0001.pdf
SIB 34 01 24 (2025-01-29)
BMW X5 2024
BMW X6 2024
After replacement of the Integrated Braking system (IB)/Power Brake the total distance covered might be lower than when handed over to the workshop for the repair.
MC-11013438-0001.pdf
SIB 12 06 24 (2025-01-29)
BMW X5 2024
BMW X6 2024
ENGINE
BMW AG has decided on a service campaign for certain vehicles from the G0x, G12 and G20 series. Please have the starter motor checked and, if necessary, replaced in the vehicles concerned (according to the vehicle identification number selection) if possible before vehicle delivery. If vehicles have already been delivered, please have the measure carried out the next time the vehicles enter the workshop. A bolting fault on the long bolt screws can cause the magnets in the starter motor to twist. As a result, the power of the starter motor decreases. As a result, the engine does not start.
MC-11013434-0001.pdf
SIB 11 10 24 (2025-01-24)
BMW X5 2023,2024
BMW X6 2023,2024
ENGINE
The engine oil pump mounting screws may not have been tightened with the correct torque.
MC-11013114-0001.pdf
SIB 11 09 24 (2025-01-15)
BMW X5 2024,2025
POWER TRAIN
During manufacturing, the dual-mass flywheel has not been sufficiently greased. The insufficient grease may result in acoustic abnormalities and vibrations in the vehicle's powertrain.
MC-11013112-0001.pdf
SIB 65 02 25 (2025-01-14)
BMW X5 2025
BMW X6 2025
UNKNOWN OR OTHER
If the Head-Up Display (HUD) is deactivated when Navigation View is selected, upon reactivation the Head-Up Display (HUD) will revert to the Standard View. This is most noticeable when the Head-Up Display (HUD) deactivates for automatic mandatory reasons, such as rear camera activation or emergency call activation.
MC-11013062-0001.pdf
SIB 61 11 24 (2025-01-07)
ELECTRICAL SYSTEM
After performing a BMW Remote Software Upgrade (RSU), the functionality of the Comfort Access and Passive Go/Exit features may be reduced.
MC-11013050-0001.pdf
SIB 65 02 22 (2025-01-02)
BMW X6 M 2020
AIR BAGS, ELECTRICAL SYSTEM, LANE DEPARTURE, VISIBILITY: DEFROSTER/DEFOGGER/HVAC SYSTEM: COMPRESSOR: MODULE (ACCM)
The limited warranty for the Knee Air Bag wire harness repair cable procedure for defects in materials and/or workmanship has been extended to 10 years / 120,000 miles as determined from the original first in-service / deliver date.
MC-11013061-0001.pdf
SIB 06 89 24 (2024-12-31)
BMW X5 2024
BMW X6 2024
UNKNOWN OR OTHER
Vinyl Rear Panel
MC-11012323-0001.pdf
SIB 65 38 24 (2024-12-13)
BMW X5 2024
BMW X6 2024
ELECTRICAL SYSTEM
Customers may report issue with Personal eSIM operation, to include: Personal eSIM does not finish the set-up process in the vehicle Telephone function via eSIM is not possible WiFi Hotspot function cannot be used Streaming video service via the BMW Theater Screen is not possible
MC-11012099-0001.pdf
This is an automated post created with code written by a human.
08-27-2025
Great. Thanks. How do we see a live version that updates as new bulletins are released?
08-27-2025
Anything new will automatically appear at the top of the second post in this thread, as well as the site referenced in the first post.
NHTSA updates their dataset each morning, and that is checked for any changes. BMW updates tend to occur once or twice per week in the dataset.
I thought about also posting a reply to the thread when new items appear, but I didn't want this to get too spammy. But maybe that is a desirable behavior to act as a digest to subscribers.
08-27-2025
Good Lord! I'm floored...such an extensive list. SMH!
08-28-2025
Ditto!!!!
The pages on the sunroof leak alone….wish I had this last year.
08-28-2025
This post needs to be a sticky so everyone can refer to it and kept updated.
08-28-2025
It is. ;)
08-28-2025
TurtleBoy wrote
It is. ;)
Great! Thanks 😊
08-30-2025
08-30-2025
Thank you
08-30-2025
Amazing! Thank you for putting this together!
09-04-2025
Thank you very much for this. You just armed me with documentation to support my driver door not properly aligned.
I see 2 structural issues in the list that fits the description of my issues and driving the experience.
2023 X5, x drive. March 2023 build.
Thanks again
09-06-2025
thank you, i have a few concerns that may be covered .
09-11-2025
Thank you for the list. I have a new 2025 (G05) X5 M60i and am hearing a loud cracking or creaking noise from the front axle or steering. The dealership looked at it 2 months ago and said it was fixed, but it’s happening again. I just scheduled another appointment.
Has anyone experienced something similar?
Thanks—Thomas
10-04-2025
A real goldmine, many thanks!
12-06-2025
Thanks bud.
12-15-2025
Wow, that's a long @ss list..thx for posting
01-07-2026
ELECTRICAL SYSTEM
BMW X5 2026
BMW X6 2026
ELECTRICAL SYSTEM
SIB 65 27 25 (2025-12-09)
BMW X5 2026
BMW X6 2026
ELECTRICAL SYSTEM
MC-11026963-0001.pdf
01-23-2026
SIB 65 20 25 (2026-01-15)
BMW X5 2025
BMW X6 2025
ELECTRICAL SYSTEM
After replacing the Multifunctional Display (MFD), the Central Information Display (CID) is black. Thebacklight of the CID is illuminated, and touch function does register an audible sound.
MC-11027777-0001.pdf
BMW X5 2025,2026
BMW X6 2025,2026
BMW X5 2025
BMW X6 2025
UNKNOWN OR OTHER
SIB 61 23 25 (2026-01-03)
BMW X5 2025
ELECTRICAL SYSTEM
MC-11027773-0001.pdf
SIB 61 22 25 (2026-01-03)
BMW X5 2025
ELECTRICAL SYSTEM
The malfunction indicator lamp (MIL) may be triggered by the erroneous fault code: BA0023 - Control unit: internal fault (software group fault) In addition, the BA0008 - CCU, internal coolant temperature sensor: Signal implausible faults may be stored in the CCU memory. However, AC charging will still operate as designed, without any related drivability complaints. Affected PHEV (plug-in hybrid electric vehicle) vehicles with CCU_P1 (7.4 kW and 11 kW) with I-levels from …24-07- 500 to …25-11-5xx.
MC-11027772-0001.pdf
SIB 61 19 25 (2026-01-03)
BMW X5 2024,2025
ELECTRICAL SYSTEM
SITUATION The malfunction indicator lamp (MIL) is triggered by the erroneous fault code 031BFC- AC charging, charging electronics 2,internal fault: No internal capacitor discharge stored in the CCU. However, AC charging is operating as designed without a charging concern or issue. Affected PHEV vehicles have the CCU-03 (7.4 kW / 11 kW) with I-levels from 24-07-500 to 25-11-5xx
MC-11027771-0001.pdf
BMW X6 M 2019,2020
SUSPENSION, WHEELS
BMW X5 2024,2025
BMW X6 2024,2025
ENGINE
02-03-2026
STRUCTURE: BODY
BMW X6 2019
02-05-2026
InVehicle-InApp-Comm (2026-01-27)
BMW X5 2024,2025
BMW X6 2024,2025
AIR BAGS, ENGINE, POWER TRAIN, SERVICE BRAKES
It was determined that due to bad data input of the DSC, there can be damage to the rear axle differential of your vehicle. It is necessary that the control units in your vehicle are reprogrammed.
MC-11028297-0001.pdf
