788VIEWS
9REPLIES
12APPRECIATES
5ACTIVE PEOPLE
2 days agoLAST POST
03-07-2026
I changed front and rear differential fluids last month. The rear was super easy, and I reused the tools I recommended for transfer case in another thread. The front has very tight space. I was looking for the tool in the first picture, but it was unavailable from amazon, and I could not source it on time from elsewhere. So, I gave the other similar a try, same brand but slightly different shape. It could fit in the space but unfortunately left no room to turn due to its angled neck shape.
With my car on four jack stands, I had to improvise a tool set with a regular 14mm wrench and gearwrench hex-bit on the second/third pictures. It fits in the space, but required me to flip the wrench side to barely have room to loosen and tighten. I wish I had a 14mm flex head ratcheting wrench at hand. So, next time if I have to do it again in another 40k or so. I will get a LONG flex head ratcheting wrench (fourth picture).
Of course, there is no freaking way to fit a torque wrench to tighten it BMW specs. But I think as long as it snugged tight and probably give another 30-degree turn should be good enough. Or, if I want to be more precise, I can use torque wrench extender and recalculate lb-ft.
A couple of other things during front differential change:
1) there are different views on how much we should fill in front differential. FCP told me 600ml, some document says 400ml and some Youtubers said fill till spill. In my case, I drained just a little short of 400ml and pumped in 700ml without spill. My guess if I gave it one more pump, it may start spill. The fluid does look dark but did not seem to have metal shivers of any kind. The replacement is for my peace of mind.
2) To reach front diff, I need to remove underbody reinforcement plate. I know I am supposed to renew the hex bolts with new ones. But I did not have new ones in hand. Last week I had a starter recall performed at a nearby dealer, and they replaced the bolts at the time. Saved me from buying 10 bolts at $6 each :)
03-07-2026
yzhou2004's user avataryzhou2004 I assume you must have been trying to reach the upper fill bolt by coming up from below with the wrench. As you experienced, coming from below is a tight squeeze. When I did mine last month I approached from the drivers side of the car with a long (maybe 12-18 inch) extension on the same horizontal plane as the fill bolt. Pretty much a straight shot from near the drivers side inner tire to the fill bolt. And using that approach meant that I was able to easily torque it for tightness.
Thanks again for your other post on the transfer case fluid change. For filling the front differential I did come from below and used the nifty fill pump with the curved tube described in your other post for easy filling.
03-07-2026
Nice. Glad it helped. Thanks for sharing your experience. I assume you took off the wheel on the driver side for easy staight shoot? That’s certainly a good option.
03-07-2026
Are you sure you don't work for FCP Euro, like on the weekends or in your spare time? One of these days we will be seeing you in one of their DIY videos. :D Thanks for posting your process!
03-07-2026
yzhou2004's user avataryzhou2004 No need to remove the tire. There is room to fit the extension and socket into position while starting inboard (medial) of the tire.
03-08-2026
What fluid did you use? BMW G5?
I changed the fluid in mine ~5k miles ago, but I just picked up some high quality 75W-90 that I think I'll use instead. There's talks the G5 fluid's properties don't hold up
03-08-2026
LOL.. I like the picture very much. I am really flattered :)
Speaking of FCP, they recently start posting a series of G05 maintenance videos which are very helpful.
03-08-2026
Mine production date 10/2019 with air suspensions.
I used what FCP recommended to me in an email. I believe your M50i needs heavier fluid as BMW recommended.
Front (drained 400ml, refilled 700ml w/o overspills):
https://www.fcpeuro.com/products/75w85-gl-5-gear-oil-1-quart-red-line-50104
Rear (extraced 800ml, refilled 800ml until it overspilled):
https://www.fcpeuro.com/products/bmw-gl-5-70w80-differential-fluid-1-liter-febi-184247
My car runs perfectly fine over last month. I plan for next change in another 35K miles, since the fluids themselves are only $58 total and took me less than 2 hours.
2 days ago
thanks for the tip. while I inspected my front suspensions under the car and prepare some DIY work yesterday, I revisited the front differential fill plug. Last time I only hand tightend with 8 inch wrench and was not sure if it worked.
Thanks for your tip. I was able to tighten to spec with a short extension bar from wheel well. Very helpful.
2 days ago
I did the front diff on my X7 this past week. A 14mm hex bit along with a 6" wobble extender and a dual action ratchet (handle with lever and rotation action) worked better than the Capri specialty wrench.
