7.5KVIEWS
56REPLIES
17APPRECIATES
14ACTIVE PEOPLE
05-08-2026LAST POST
04-08-2026
g07bg wrote
Tiny difference in suspension, a bit more in throttle response and coasting.
I drive in it just for the coasting, its like letting it roll in neutral on a manual car.
I’ve learned it depends on which ComfortWorld you choose in FES_ expert menu. ComfortWorld 0,1,2 have different effects. I chose 1 which which gives a smoother, more refined and balanced feel compared to World 0 which is closer to stock Comfort with slightly more responsiveness, and World 2 which is the softest and most relaxed, leaning more toward an Eco-like with coasting like you mentioned.
04-09-2026
This is incredibly helpful to know.
04-13-2026
I’ve been told that coding comfortworld 0-2 actually allows you to press comfort button more then once to access comfort plus.
04-14-2026
BimmerXdrive wrote
I’ve been corrected and told that coding comfort mode 0-2 actually allows you to press comfort button more then once to access comfort plus.
Yes, All I did was just follow the list OP had but the setting where when you start the car and automatically goes to Comfort+ I didn’t mess with.
05-03-2026
Alright some big news! After 2+ Hours with Communications with A BMW user's user avatarA BMW user over settings I can’t see, and the Bimmercode app Update I saw 2 new Modules! Front and Right Headlight Modules. We can now get 600 Meters from the Headlights with Lasers!
So how do you do it?
Go into each module and type in: Segments_Third_Level and set WERT_3
AHL_ENABLE and set WERT_2
REMEMBER TO DO THE SAME CODING TO BOTH MODULES.
05-03-2026
It would be great to have some photos or a video to see the difference?
05-04-2026
Both my light modules had AHL ENABLE set to werte 2 already.
When I set the Segments third level ones to werte 3 and coded, I got an error. However the value seemed to stick on both even after disconnecting and getting back into BC. Weird.
I'll test tonight once it finally gets dark around 10pm.
05-04-2026
Alright I tested. Looks to be even tighter tunneling just ever so much more. The lights are just incredible. Huge highbeam/laser hotspot and exceptional distance. I could see the yellow street signs a mile away on 1 straight. And illumination of the road ahead was greater than 400 yards.
Definitely no I'll effects and nothing 'lost' in the coding. No errors.
05-04-2026
Awesome to see my Coding worked!
05-05-2026
I'll say it again, it would have been really great if one of you could have made a video of the "regular" Anti-Dazzle function like the one suggested by TurtleBoy's user avatarTurtleBoy, and another video with your proposal! So we could all understand the difference...
05-05-2026
Unfortunately I can’t as I have a trip upcoming in a few days and can’t leave the House as I need to get ready for it. A BMW user's user avatarA BMW user Just got his G05 in for a Service and currently has a Loaner X5 so obviously it’s not coded. I’ll text him to see if he can make a video and send it in here whenever he gets his G05 Back.
05-07-2026
would this have any effect on a 2022 with LED headlights...non laser?
05-08-2026
As James May from Top Gear once said.. “Ask an Admiral how Deep his Submarine goes.. He doesn’t know until he tries it.”
