224VIEWS
5REPLIES
5APPRECIATES
4ACTIVE PEOPLE
05-16-2026LAST POST
05-08-2026
Just got these in the mail yesterday from the land down under.. for my 2024 M60i.
Any tips or tricks to get these installed quick and easy? hopefully i can just slide under and hook'em up without having to remove anything!
Please guide me wise people!
05-09-2026
Extremely easy to do. Get under the car and disconnect the valve wires. Then just place the 11mode between the wire and the valve controller. I didn’t need to do anything but crawl under and feel around a bit with my hands. You will feel everything click when it connects. It’s tight but doable and probably took me 5 minutes in total.
05-09-2026
I crawled under and looked today, it is tight. I was able to unplug the valve cables but they didn’t click into the 11mode connector. I didn’t want to tug on the cable to hard so I just plugged it back into where it was. Did u have any issues with it fitting into the 11mode?? Maybe I just didn’t press firmly enough. I’ll have to give it another try.
05-11-2026
My approach was a bit different. I backed my X6 up onto my four inch ramps, then I removed three or four screws holding on a small splash guard, I could now see and get to everything very easily. I unplugged the the stock valve connector and then plugged in the 11 Mode controller and made sure I heard all the proper clicks and gave each connection a soft pull to make sure everything was correct. Re-installed splash guard and rolled down off of my ramps and everything worked out as it should. I spent probably 45 minutes start to finish. OCD for sure. YMMV
05-16-2026
Here's a decent video if you haven't installed yet
I had some 4 inch ramps which helped give me some elbow room
05-16-2026
Thanks I haven’t yet! Appreciate it!
