      03-27-2024, 03:18 PM   #309
Hmarga98
Drives: 2020 bmw x5
If the rear fog light situation was figured out I’d love to see or know how, maybe Pm me if possible?
      03-28-2024, 05:31 AM   #310
Ninefourteener
Ninefourteener's Avatar
1469
Drives: 2020 X5 M50i, 2020 Alfa 4C
Funny you should mention that.
Yes, it was figured out (sort of)
No, I haven't done the installation yet. Since the car is now due for it's first Belgian inspection, it's on my list of things to do as well.
Long story short - The local BMW dealer (in Belgium) had my X5 torn apart... sitting right next to a European X5... also torn apart.
The wiring harness that exists on European X5s for the rear fog lights??? The wiring harness doesn't even EXIST on a US Spec X5.
So...... the solution is:
OEM rear (European) foglights..... plus an aftermarket relay/switch to operate them.
Or.... one of those stupid little lights that hang off the rear bumper... which I won't do.
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019
690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813
6pot/4pot Big Brake Kit:https://g05.bimmerpost.com/forums/sh....php?t=2097342
      03-29-2024, 09:13 AM   #311
Ninefourteener
1469
Just in case you are "considering" this "upgrade"?????
Don't. It's not worth it. What a pain in the ass.
If you are like me and require rear fog lights for "legal" reasons..... just get the cheap aftermarket dangly rear fog light.
It's done. It works. I'll pass Belgian inspections now.
Never again.
      03-29-2024, 03:50 PM   #312
PNWM50I
PNWM50I's Avatar
647
Drives: 21' x5 M50i
thanks for giving us closure!
      03-30-2024, 02:04 PM   #313
Ninefourteener
1469
And..... after MUCH research, I've decided to go back to stock-sized tires..... but the tread width and section width between tire manufacturers varies WILDLY..... I had to start digging into the technical specifications of each tire manufacturer, each tire, and figure out who made the widest street tire in stock sizes.
Why? Because OEM rims are 9.5 and 10.5 inches wide, respectively.
My wheels are 10.5 and 12.0 inches respectively.....
So to minimize the "stretched" tire look as much as possible..... I needed to find the manufacturer and model.... that is the widest, in OEM sizes.
PS4s? Nope
P Zeros? Nope
The winner?
Continental Conti Sportconstact 7
In the exact same size (315/30/22)..... the Pzeros have a tread width of 10.8 inches. The Contis? 11.6 inches. On a 12 inch wide rim? that'll work just fine.
Just over $1500 USD, they are on the way.
As soon as the wheels come back from powdercoat (satin black), they are going back on the car.
TGMcCoy27.00
      04-07-2024, 11:00 AM   #314
Ninefourteener
1469
I "think" I can add this to my 6-piston X5M front brake retrofit to my list of "first person to do it" mods.
F95 X5M quad-tip exhaust retrofit. I did another full post on this..... but the finished product belongs here.
Appreciate 4
chicagofan0020327.00
dpie92.50
playswcars4901.00
      04-07-2024, 04:20 PM   #315
JujufromNYC
JujufromNYC's Avatar
98
Drives: Bmw X5 M50
Was installing these straight forward ? What needed to be modied ? Sounds abosolutly amazing speacially higher RPMs , great work
      04-07-2024, 04:52 PM   #316
chicagofan00
chicagofan00's Avatar
Drives: 2024 X5 M60i
Sounds great, like a V8 should!
Instagram: @Phxrisingphotography
Current - 2024 G05 X5 ///M60i in Java Green
Past - 2005 E53 X5 3.0i in Titanium Silver; 2008 E92 335i in Montego Blue; 2019 G01 X3 M40i in Glacier Silver; 2022 G80 M3 Competition in Twilight Purple
      04-07-2024, 05:13 PM   #317
Ninefourteener
1469
It was definitely NOT a direct install. The pipes, and the hangers are in identical places, but there were a couple of concessions I had to make:
rear (muffler) hanger brackets had to be re-used from the M50i.... they are shorter, because the M50i muffler hangs lower.
Almost the entire undersidenof the car (including chassis braces, and center chassis mount) had to be removed for removal & installation
(AKA.... it was a LOT of unexpected work)
exhaust bezel removal was more of a PITA than the rest of the underside of the car.
Much of the plastic.behind the OEM exhaust bezels had to be removed.
Much of the under-trunk (above muffler) heat shielding had to be removed to make space for the (higher-sitting) X5M muffler.
On a positive note though;
Pipes, hangers, and even the X5M flapper valve motors/electronics were all a direct fit. So, that helped a little.
      04-12-2024, 03:02 AM   #318
Ninefourteener
1469
Powder coater just messaged me. They are ready!
Appreciate 3
      04-15-2024, 04:04 AM   #319
Ninefourteener
1469
Rear BBK all finished...... front X5M 6-pistons refinished in red. Wheels re-powdercoated in satin black.
And..... the suspension back down where it belongs.
Thanks to @dentprotony@gmail.com for the rear BBK
Appreciate 5
      04-15-2024, 03:37 PM   #320
PNWM50I
PNWM50I's Avatar
647
Drives: 21' x5 M50i
Welcome to the Satin black club. Looking sharp!
      05-10-2024, 09:51 AM   #321
Ninefourteener
1469
First day in Belgium that got well into the 70s (Farenheit).
Cleaning up all my toys for a short, but enjoyable Summer.
Appreciate 3
LDT2274.00
      05-10-2024, 01:37 PM   #322
LDT
LDT's Avatar
2274
Now that's quite a collection of toys! Summer in Belgium...July and August just like Cleveland.
2024 X5M60i-- Skyscraper/Ivory
2020 Cayenne replaced by ^^
2017 X5 35d--still in my diesel phase
2015 GL350--diesel burner and highway Queen
2013 Audi S6
      05-11-2024, 12:17 AM   #323
Ninefourteener
1469
CLEVELAND!?!? Oh boy.... I thought my winters were long.
It doesn't get that "cold" here. Not nearly as cold as Cleveland. It does however... rain.... for about 8 months straight. Every day. All day. non-stop.
The worst part, is that we'll go months without ever seeing the sun, because of constant grey cloud cover.
I'm strictly a "warm-weather rider", and the 4C never gets taken out unless it's 100% dry.
So.... consequently, I own 4 vehicles, and 3 of them share usage only 3 months out of the year.
I miss Florida.
      05-25-2024, 11:14 AM   #324
Ninefourteener
1469
Now that I've decided to keep the car, I figure I might as well do the "lifetime" service from BMW..... but that literally EVERY expert recommends doing at 50k miles. I have just under 60k miles...... so let's get it done.
Engine oil (Royal Purple 10w40)
Engine oil filter
Transfer case fluid (BMW DTF-1)
Front diff fluid (Royal Purple 75w90)
Rear diff fluid (Royal Purple 75w90)
Transmission pan + filter
Transmission fluid (Liqui-Moly ATF 1800)
      05-25-2024, 11:16 AM   #325
Ninefourteener
1469
transfer case fluid, location, and the tool I needed to get to it. Had to reach over the cross member. Tight squeeze.
      05-25-2024, 11:18 AM   #326
Ninefourteener
1469
front diff..... has a drain plug AND a fill plug. Nice. Fill plug had to be reached by going through the wheel well, but not too bad.
      05-25-2024, 11:21 AM   #327
Ninefourteener
1469
rear diff.... only has one plug. Fluid has to be sucked out, and pumped back in. Special tool ordered online - an absolute necessity.
      05-25-2024, 11:26 AM   #328
Ninefourteener
1469
And the transmission pan and filter out (it's one unit).... new one back in.
It only took 3 liters, so I:
a) ran it up to operating temp.
b) shifted through all the gears
c) drained the pan AGAIN.
d) Refilled the pan w/ 3 liters
e) ran it to operating temp
f) went through all the gears
g) Left it RUNNING
h) added another 1.25 liters to top it off.
i) buttoned it all back up again.
      05-25-2024, 11:27 AM   #329
Ninefourteener
1469
And..... the mileage. 96k Kilometers.... whichbis just under 60k miles.
      06-17-2024, 04:13 AM   #330
Ninefourteener
1469
Wow..... all that money I spent having my rims professionally restored and re-powdercoated...... lasted 1 month before another pothole dented the front, and cracked the rear.
.... Again. F-ing Belgium.
For the 4th time.
Back on my stockers...... again.
