08-27-2019, 06:15 AM | #353 | |
Owner
132
Rep 566
Drives: G05 30d M-Sport
I'm thinking of buying a OTG Ethernet adapter and a ethernet ODB adapter. I don't mind having wires around, as it's not like it's going to stay in the car anyway. Would you think this is the way to go?
Received 190911: X5 30d M-Sport:Artic Grey:Comfort Pack:Tech Pack:Visibility Pack: Driver Assist Pro Pack:Heat Pack:Glass Roof:Leather Dash
08-27-2019, 08:33 AM | #354 | |
Rep 5,463
Android does not support the cable, only Apple stuff can use the cable, so if you want to invest in the cable to use via Esys later, you will need an apple device to use bimmercode with that cable. If you need to use Android you will need a BT dongle.
2025 X5 Msport
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
buze132.00 |
08-27-2019, 10:42 AM | #355 | |
Guest
Rep n/a
Drives:
- no need to buy the android BT dongle - not dependent on the developer release cycle - many more features available for coding. Almost unlimited in fact - you can flash your i-step if feeling adventurous - VO coding Disadvantages: - you will need a Windows PC or macbook with bootcamp/vm such as fusion - Slightly more expensive as launcher pro is the cheapest option at $50. Much more expensive if you need to buy virtual platform software and/or a physical laptop - some additional risk dependent on capability Ultimately I think you need to ask yourself if all the features you need are covered by bimmercode right now. If they are then that's the best option as its quick, safe and inexpensive. If you want more though, I wouldn't count on those features being made available in bimmercode, and consider how much those additional features are worth to you. |
08-27-2019, 09:26 PM | #356 | |
Rep 272
08-27-2019, 09:29 PM | #357 | |
Rep 272
I just get error message saying 'Session has been terminated' I can see my iphone connecting to device under blutooth connections. |
08-27-2019, 09:32 PM | #358 | ||
The Dark Knight
423
Rep 1,262
OzJedi111.00 |
08-27-2019, 09:34 PM | #359 |
Rep 272
08-28-2019, 09:59 AM | #360 |
The Dark Knight
423
Rep 1,262
03/2019.48
08-29-2019, 05:12 PM | #361 | |
The Dark Knight
423
Rep 1,262
roadkillrob881.00 |
08-29-2019, 05:15 PM | #362 | ||
The Dark Knight
423
Rep 1,262
08-29-2019, 08:05 PM | #363 | |
Rep 5,463
2025 X5 Msport
08-29-2019, 09:06 PM | #364 | ||
The Dark Knight
423
Rep 1,262
08-30-2019, 02:31 AM | #365 |
13
Rep 32
Drives: 2019 G20 330i M-Sport
Guys, read at other forum that new head unit displays available through BimmerCode. Does anyone check this already? I cannot find it is mention in features on their web site. https://bimmercode.app/cars/g05/
08-30-2019, 07:35 AM | #366 |
Rep 5,463
How to code the gauges stuff is here https://g07.bimmerpost.com/forums/sh...1636904&page=2
2025 X5 Msport
KDDI12.50 |
08-30-2019, 02:38 PM | #367 | |
401
Rep 338
08-30-2019, 03:35 PM | #368 |
Rep 5,463
It is all coding in the Kombi, so you will need an e-sys setup or wait until bimmercode adds the kombi to the app.
2025 X5 Msport
08-31-2019, 12:10 AM | #369 |
13
Rep 32
09-01-2019, 07:23 PM | #372 |
Rep 5,463
Doesn't seem to work right in bimmercode, it codes it then tries to take you to the speedlock menu which doesnt work right.
Do this, once it reboots hold the iDrive controller up, then press media then home then media. This should open the speedlock menu and you can set it to no speedlock.
2025 X5 Msport
09-03-2019, 08:01 PM | #373 | |
Rep 99
09-03-2019, 09:46 PM | #374 |
Rep 252
qocerhuang29.50 |
