      09-11-2024, 04:39 PM   #67
elJames
elJames's Avatar
Drives: '23 BMW X5 xDrive40i
Originally Posted by Marty in NY View Post
The felt seal is a bit different and from my testing its this seal that is causing the majority of the squeak.
Yes, the squeaks and creaks are from the felt not the gaskets. Guys please don't start taping together your $80k vehicle and just use the Gummi Pflege
https://nextzettusa.com/gummi-pflege-rubber-care-stick/
Again, I liberally applied it to the felt after tapes and applying to the gaskets didn't work. It's now been eight months of silence and joy.
      09-18-2024, 11:46 AM   #68
j22stl
26
Drives: 2024 X5
Thanks for your comments. I applied this product in the area that the red trim removal tool is in. I spread the seal and made sure this area was covered. The creaks are gone and it's been silent for two weeks now.
elJames151.50
JoeAyalaM508.50
      09-18-2024, 11:59 AM   #69
Marty in NY
Marty in NY's Avatar
Drives: 21 X5 40i, 18 GTi, Snowblower
Seems like you found success, but where exactly did you add the Gummi Pflege? On surfaces 1 & 2? How about 3?
.Name:  IMG_0649.jpg
      09-18-2024, 12:27 PM   #70
j22stl
26
Drives: 2024 X5
I coated #2 heavily which also resulted in #1 getting some of the product on it. I did not apply any to #3.
      09-18-2024, 12:28 PM   #71
j22stl
26
Drives: 2024 X5
I also cleaned the #2 channel with a soap and water then allowed to dry before applying. That channel gets very dirty.
      10-30-2024, 08:45 PM   #72
nawktrebor
nawktrebor's Avatar
44
Drives: BMW - i4, M3, X5
Thanks for all the information! This is really helpful.
      01-25-2025, 02:26 PM   #73
nawktrebor
nawktrebor's Avatar
44
After several weeks of testing, I finally resolved the AAF squeaking/creaking noises coming from the internal water channel made out of felt that rubs against the door jamb when driving the car. Much thanks goes out to the Forum Members who provided their experiences with PPF Tape!!! You can see from the markings on the painters tape where the contact point is. After putting on the painters tape, the noise was completely gone. I drove around for several weeks to confirm. I replaced the painters tape with 3M PPF tape and the noise is still completely gone and I am not AAF. This is the only way to silence the noises. Liberal amounts of any lubrication (including Gummi Pflege) do not work and will end up attracting dust, grime, etc.
Gummi Pflege can be used on rubber surfaces, but not felt. The overall root cause of the noise is the felt side of the water channel rubbing against the paint on the door jamb. I can't speak for waxing, applying teflon, applying ceramic, etc to the door jamb, but having a surface that does not make noise when felt rubs on it is key.
Last edited by nawktrebor; 01-25-2025 at 02:43 PM.. Reason: Need to edit on computer instead of phone.
