11-11-2021, 10:34 PM | #67 | ||
18184
Rep 11,760
Drives: 2018 M4 Comp Indv
(a.) M+S tires are gonna wear pretty fast >70 degrees F and, (b.) Taking the shoreline exit off North 101 at 90 MPH in an M3 with M+S tires on an 80F day and hitting the green light so you can light 'em up on that big left uphill turn ... well, let's just say you shouldn't expect the same stability as you'd get with summer tires. The good news is, if you're running the Vreds they won't even squeal. |
11-11-2021, 11:13 PM | #68 |
Rep 6,805
The typical winter tire doesn't work as well on dry roads as an all-weather tire might, and an all-weather tire won't work as well in ice and snow...they each have their tradeoffs. Just like a summer tire can be lousy in the winter. But, a winter tire may not be anywhere near as bad in the warm, but may wear faster, so there is still a down-side.
Tires are nearly always a tradeoff...depends on what's most important, and what compromise(s) you're willing to accept. Personally, I'd take some increased wear on a winter tire in the summer. But, it may not have as good stopping or cornering capabilities...depends on how close to the edge you usually drive. One has to know both his and his equipment's limitations for best results. |
11-12-2021, 08:35 AM | #69 | |
Rep 528
11-12-2021, 02:32 PM | #70 | ||
Rep 842
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50 |
11-12-2021, 03:58 PM | #71 |
Rep 6,805
Any tires made after sometime in 2024 must have the mountain symbol with the snowflake inside to be considered legal as a winter tire. Prior to that, M+S suffices...IOW, depending on the age of the tire, it may or may not have the more modern symbol on it.
11-13-2021, 10:34 AM | #72 |
Rep 23
I have a 2022 BMW X5 M50....
These are the tires I have, they are listed as "performance", and don't say that they are specific for summer. Can I use these tires in the winter on snow/ice? 22" M Double-spoke bi-color wheels, style 742M with performance non run-flat tires |
11-13-2021, 10:38 AM | #73 |
Self-Deprecating Narcissist
7266
Rep 6,561
no. not for winter, snow or ice.
11-13-2021, 03:37 PM | #74 |
Rep 6,805
A winter capable tire will have a mountain with a snowflake molded onto the sidewall of the tire (or, if it's old school it will say M+S). If it has neither, it is a summer only tire. BMW only sells summer performance tires in the 22" sizes as delivered. Finding 22" winter tires that will fit those rims is really tough, and industry highly recommends you do a minus sizing when fitting winter tires.
iconoclast7265.50 CGG171.50 |
11-13-2021, 09:14 PM | #75 | |
Rep 148
Should be clear, however, that M&S (mud and snow) are NOT necessarily winter tires. It is very misleading that M&S is a designation that is used for "All Season" tires. Lots of people reasonably think that M&S means the tires are good for winter. Not so, tires with the M&S can be "All Season" tires - not winter tires. Don't look for a M&S symbol if you want winter tires. |
11-13-2021, 10:30 PM | #76 |
Rep 6,805
Well, yes, a M+S tire is not necessarily a winter tire, but will be far superior to a summer performance tire in the winter! It's an indication that it can be run in the cold with some snow capabilities, whereas, a summer tire will be terrible in snow.
Personally, I look out for the worst case scenario in the winter, and an all-season tire won't get me home and up my steep driveway. Your situation can easily differ. |
GrussGott18183.50 |
11-14-2021, 02:11 AM | #77 | |
18184
Rep 11,760
If you're like Jad and want the best winters, then mountain symbol; but if you live in a region that gets occasional snows & ice but overall is mostly dry, and you like performance, then M+S is the way to go (e.g., Vred wintracs) Personally I've mostly leaned M+S, but if I wanted full-on 'snow' tire then something like Nokian Hakkas; but I grew up in Minnesota and learned to drive a stick in rwd on ice so anything better than kmart tires feels like glue. |
11-14-2021, 02:30 PM | #78 | |
4985
Rep 11,891
Here in America that's communist progressive un-american bolshevik
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
GrussGott18183.50 |
11-14-2021, 06:06 PM | #79 |
Rep 6,805
I lived in Germany for about a year and a half way back. They have a bunch of rules, that while I consider useful, would not go over well in the USA for example:
- if you see a car accident, you are REQUIRED to stop and provide assistance unless there's emergency responders already there. That's one reason why you're also REQUIRED to have a first aid kit and warning triangle in your vehicle (you're also held harmless in providing that aid for the most cases) - if you leave valuables visible in the vehicle instead of locked up or at least covered in the rear (thus, the cargo cover on the X5), and they get stolen, you are partially liable with your insurance - you need to keep the sidewalk in front clear and clean so it's not uncommon to see people sweeping and hosing it down - recycling is not optional Those were the things that affected me most while there. I don't know what the current situation is...this was decades ago. |
11-14-2021, 11:38 PM | #80 | |
18184
Rep 11,760
No power tools of any kind, no loud noises, no bullshit. Just go the to lake, get a weisswurst & lager and shut the fuck up. |
12-07-2021, 06:13 AM | #81 |
Rep 154
Drives: X5 40d G05
Hi There. So I have fitted Pirelli Scorpion Winter to my G05 in following size (same size has my summer ones) :
275/35 R22 104V XL 315/30 R22 107V XL Spoke with my colleague that works at the BMW dealer parts department and he advised that there is no 22'' winter tyres for BMW (no BMW homologation - need to have a star) and this size shouldn't be used as winter. If something will fail I might have a trouble with my car warranty. So he suggesting 21'' winter ones which cost about £4k here in the UK - it is to late for me to do that and I dont want to have two sets of wheels. So, just wanted to check if some of you had any trouble with the 22'' winter tyres? I hope not. Please let me know your thoughts. Thanks |
iconoclast7265.50 |
12-07-2021, 11:32 AM | #83 | |
7266
Rep 6,561
https://www.bmwtirecenters.com/
12-07-2021, 01:10 PM | #84 | |
Rep 154
Drives: X5 40d G05
iconoclast7265.50 |
12-07-2021, 01:11 PM | #85 |
Rep 154
Drives: X5 40d G05
12-07-2021, 02:28 PM | #86 |
Rep 6,805
The issue is, if you use a product, including a tire, that is not BMW authorized AND it causes an issue with the vehicle, like with a tire, a harmonic, or vibration, or excess noise, then, the warranty won't necessarily pay for the diagnosis or repair. If it doesn't cause any issues, no harm, no foul.
12-07-2021, 06:54 PM | #87 | |
7266
Rep 6,561
12-09-2021, 06:26 PM | #88 | |
Rep 154
Drives: X5 40d G05
