04-27-2023, 09:19 AM | #67 |
Rep 544
In Central NJ we are paying Jersey Central Power & Light about $0.14 - $0.15 per kWh. Doing some rough math, if the 50e can do about 40 miles per charge, and each full charge uses about 24kW (80% of 30kWh battery capacity), that translates to approximately $3.50 to travel 40 electric miles. I have an X5 40i and I average about 20mpg, so that electric range would typically utilize 2 gallons of premium fuel. I pay about $3.90 per gallon, so on gasoline that 40 miles would cost me about $7.80. Effectively driving, electric only reduces my fuel costs (on the electric only portion of my mileage) by about 55%. I drive about 10,000 miles per year and 60% of that is local driving (6,000 miles). Driving 6000 miles (at 20mpg), enables me to avoid approximately 300 gallons of gasoline. I save about $2.15 per gallon (gallon of gas $3.90 replaced by electricity equivalent which costs $1.75), yielding annual fuel savings of about $645. Now there are other factors that probably improve this a little more. I assumed that my combined average mileage is 20mpg. In reality local driving probably averages 15mpg and highway driving probably averages me closer to 25mpg so in reality the portion of driving replaced by electric use probably yields even more savings. Effectively my actual cost savings are probably closer to $700 - $750.
Not factoring in the environmental benefits, looking at this purely from a financial standpoint, if the 50e costs about $5000 more than a 40i, the payback ends up being about 7 years. Now if our brake use also decreases (by 50%) because of regenerative braking perhaps we save another $2000 in brake/rotor replacement costs per each 5 year period (or about $400 per year), that reduces the payback period to about 4.5 years. Not bad. You also get to drive a vehicle that provides an extra 100hp of power and an extra 100 lbft of torque. Last edited by akin67; 04-27-2023 at 09:27 AM.. |
04-27-2023, 09:23 AM | #68 |
301
Rep 382
You will also save a few $ compared to a 40i when driving in the city or stop/go a lot since the PHEV is a lot more efficient there.
akin67450.50 AloneAlien67.50 |
04-27-2023, 09:45 AM | #69 | |
Rep 114
AloneAlien67.50 |
04-27-2023, 10:17 AM | #70 | |
4987
Rep 11,891
https://g05.bimmerpost.com/forums/sh....php?t=1866591
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
akin67450.50 |
04-27-2023, 10:18 AM | #71 | |
Rep 839
This is the #1 thing electric cars need to solve in my mind. Especially with electricity prices increasing. |
akin67450.50 |
04-27-2023, 05:45 PM | #72 |
Rep 6,881
Many BEVs use a heat pump that can be 3x more efficient with power uses versus resistance heating (which it will typically also have as a backup, the same as with home units). My i3 had a heat pump. Preconditioning the vehicle when plugged in can help minimize the impact of heating the cabin entirely from the battery (well, it always comes from the battery, but while plugged in, it can be at least partially replenished while that's happening). A heat pump is a little more complex, and you'd still need the resistance heating backup, so the cost for a PHEV often doesn't justify the additional costs.
05-03-2023, 05:05 PM | #73 |
4987
Rep 11,891
I just did a 2nd road trip since this LA trip. It was between SF and sierra mountains. On the way up (with a full charge), I returned 28 MPGs. On the way down with a 40% charge, I returned 36 MPGs.
Overall, this is all within expected results as total distance was almost exactly 200 miles each way with about 15%-20% of that distance covered on EV. On the way down, notably, my mileage on EV was an amazing 40+ miles because I was able to benefit from regen and coasting. It wasn't until I ran into traffic when I completely ate away at my electric capacity. My best return down the mountain on a full charge has been 45 mpgs with no traffic. I was able to charge at the house I stayed in. Went skiing, and the ski resort had its own chargers, but it was expensive. $3 fixed session fee + $0.38/kwh + idle charges. No thanks.
05-03-2023, 05:47 PM | #74 | |
Rep 3,708
Yes, charging on this route is almost impossible.
2022 G05 B58/PHEV
+ a few very old BMWs |
05-04-2023, 08:28 AM | #75 | |
Rep 547
Last week I topped off my fuel tank for the first time since August 1 of last year. Bottom line is I spent $30 on gasoline over 8 months. |
admranger2986.00 SwissBeemer301.00 |
05-04-2023, 09:05 PM | #76 | |
4987
Rep 11,891
On highway l, I always put the car in sport suspension level. |
eelnoraa2058.00 |
05-05-2023, 05:57 PM | #77 |
Rep 547
I've never done that. None of my previous cars had a sports mode. What's the benefit on plain vanilla interstates?
05-05-2023, 06:02 PM | #78 |
Rep 6,881
Sport mode, at least at some road speeds, will lower the suspension. In theory, that could lower your drag, and because it compresses the air springs some, makes their spring rate a bit steeper. Some may like it, some may not, and some won't be able to tell the difference!
Guy Fleegman420.00 |
05-06-2023, 12:54 AM | #79 | |
4987
Rep 11,891
I also like to think it helps a bit with aerodynamic drag |
05-06-2023, 12:57 AM | #80 |
4987
Rep 11,891
Not in SoCal, but in Monterey area for the weekend. Had empty j1772 stalls for me at my hotel. $1/hr, which is a good rate. Decided to charge up to 5 hrs and 99% and passed on the last half hour of charge
05-08-2023, 04:05 AM | #81 | |
301
Rep 382
05-08-2023, 06:29 AM | #82 |
Rep 26
I took my 45e on a cross-country trip. I did so on gas only and never gave a thought to my trip. As to planning my trip based on charging. I do all my in-town driving on electricity. My local rate for super off-peak charging is 0.07 cents between 11 pm and 6 am not including that nasty distribution fee. Seem to be close to $2.00 for the overnight charge. The moving target on the charge is between 33-44 miles. The latest update seemed to give me more range or it's much warmer out now. Vehile is parked in a heated garage.
05-08-2023, 12:48 PM | #83 |
Rep 6,881
While lowering the pressure in the air spring does lower the vehicle, a smaller movement is a larger percentage, so the progressive rate is higher. IOW, what's left gets compressed more on a bump, which raises the pressure to keep it from bottoming out.
