Low coolant temperature
11-16-2016, 10:57 AM | #45 |
Rep 436
11-16-2016, 11:01 AM | #46 | |
Rep 281
11-16-2016, 11:58 AM | #47 | |
Rep 504
I was amazed on how transmission behaviour changed!! not jerky anymore. I also thought it might have been a placebo but your observation confirms my doubts. WIN!
JR Auto tune and Bohl Diesel Downpipe - KWv2 coils - Apex Racing 18" EC7 wheels wrapped in Michelin PSS 245/275 F/R - Zimmerman cross drilled rotors F/R with Hawk HPS pads - SS brake lines - Motul RBF 600 - ADD W1 oil catch can - BMW performance CF spoiler
11-23-2016, 07:20 AM | #48 |
Rep 529
This thread has possibly answered my concern with my car and the cold. My car seems to be jerky on cold mornings and I have noticed that the mpg is definitely affected to the negative.
Today on my 30 minute commute I decided to pull up secret menu #7 and monitor the engine temperature. Ambient was 1 C and the engine was at 14 C when it cranked. Temperature never got above 66 C on the entire drive and seemed to hover around 63 - 64 C. Obviously well shy of the optimal 88 C cited in other threads. I again monitored my temperatures on the drive home when ambient was right at 17 C. Again, the temperature just made it to 70 C. I am certain that I need a new thermostat.
2011 335d Deep Sea Blue on Beige (stock except for the cheap ass wheels from PO)
2010 328i Tasman Green on Saddle (stock) Last edited by rulonger; 11-23-2016 at 07:07 PM.. |
11-25-2016, 08:27 PM | #49 | |
2131
Rep 3,368
Took me about 1.5 hours from start to finish as the lower coolant hose clip decided to shoot out on me and play hide and seek up in the turbo area |
11-25-2016, 11:21 PM | #50 |
Rep 1,157
Looks like this will be the next "mod" on my list. Seems like general consensus is that this is rather simple work. However, I'm a little unsure about draining and refilling the coolant. Is there a good DIY guide somewhere for that?
11-26-2016, 07:02 AM | #51 |
Rep 2,410
As another data point... changed my thermostat this week. Previously the car would warm up to ~172-176F, unless in town stop and go driving, where it might get to mid 180's. New stat car warms up to ~186-190F. Based on cars predicted mpg's, under my normal drive cycle, and doing ~300 ml of Thanksgiving interstate driving, there is no noticeable change in mpg behavior. However, to really know if it affects mpg's, I'll need more data points. Fortunately, I've got every single fillup and hand calculated mpg data point since the vehicle was new, to compare against.
Chart of my vehicles lifetime hand calculated fuel economy and a studies of direct injected diesel engines lack of sensitivity to coolant temp can be seen here: http://www.e90post.com/forums/showpo...8&postcount=31 and here http://www.e90post.com/forums/showpo...5&postcount=34 I'm curious if those posting significant fuel economy benefits from changing their thermostat could describe their before/after coolant temps, and plot hand calculated mpg results over an extended period of time before/after their thermostat change? That would give some interesting comparison to see if the trend line significantly changes.
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods |
kydiesel35166.00 Persian Whisperjet166.50 |
11-26-2016, 07:47 AM | #52 |
Rep 460
Thanks for posting. I'm still on the fence, haha. Looks like it calls for 4 hours labor, is this true? Including flush?
I'm thinking I will wait... I usually leave all hvac off until the car fully warms up anyways. |
11-26-2016, 12:13 PM | #53 | |
Rep 504
Now within 10-15 minutes of my drive to work the temperature rises to 80+ C easily, and car drives and behaves differently. Tranny is more smoother. I have been driving this car for over 4 years now - everyday. I can feel the difference in behavior. May be it never got out of warm up cycle ever (never in closed loop) Another thing that i can relate to this is glow plug controller/glow plugs. Mine failed last winter, which caused me to monitor temperature. According to BMW training document, the glow plugs also work intermittently if your engine isn't warm enough - as a result low temps = overworked controller and plugs hence leading to failure.
11-26-2016, 02:04 PM | #54 | ||
Rep 1,289
11-26-2016, 06:12 PM | #55 |
Rep 2,410
That's a definite possibility and my car might have been right on the edge of where the DDE was still OK with the temp and doing proper injection timing and all the other things it controls... 60-63C is much lower than what I was seeing. Thanks for commenting on that data point.
11-27-2016, 08:17 AM | #56 | |
Rep 3,049
Drives: 2009 BMW 335d
Seems like I'm in between you and TA. Did some data logging last week and was seeing 70-72C (158-162F) temperatures with spirited driving including a highway stretch. Next on the agenda is a thermostat change. |
11-27-2016, 03:30 PM | #57 |
Rep 4
Here is a link to my experience/DIY guide for the thermostat replacement on the 35d - includes some part diagrams and a fair number of pictures:
http://www.xoutpost.com/bmw-sav-foru...-diy-pics.html Hope that helps. |
11-27-2016, 06:39 PM | #58 |
Rep 3,558
I drove 280 miles home on Saturday. We got stuck in a traffic jam and coolant temp got up to 89C. When cruising resumed, I ran at 83-84C. Anyone know temp the radiator fan comes on at?
11-28-2016, 12:04 PM | #61 |
2131
Rep 3,368
Not sure if it helps for another point of reference, but on my 40 mile commute this morning water temp was steady at 87-88C, after warm-up. This is with outside temps at 27F.
I'll report back on MPG after my next full tank is consumed next week. |
12-06-2016, 09:53 AM | #62 |
Rep 122
My temps are running in the low 70s so Tstat is on my list of to do's. Has anyone had any type of engine light for a T stat stuck open? My Indy seems to think that a stuck open Tstat should result in an SES light.
12-06-2016, 10:11 AM | #63 | |
Rep 281
Which is really surprising since engine coolant temperature is probably the SINGLE most important parameter for emissions. Emissions of soot and NOx are both increased with cold running engines. I really don't get why the manufacturers do this. Well I do know: it's to reduce warranty visits and customer complaints. But it's bad for your car (running cold and longer warmups increases engine wear), bad for fuel economy, and bad for the air. |
12-06-2016, 11:04 AM | #64 | |
Rep 183
But you will start loosing fuel economy if temp stays below approx 70~75 deg C. |
12-07-2016, 03:07 AM | #65 |
Rep 2,615
Interestingly, I have ever only got a shadow code. My stat was completely open and at around 0C/32F I was running way below 60C on the freeway. I'm sure there are potential conditions when a full ses will be triggered, but surprisingly BMW did not make it very sensitive.
