01-31-2017, 02:16 AM | #68 |
Rep 2,856
Drives: BMW M2 CSL Turbomeister
My Czech dealer wants 2787 CZK which is 103 EUR (incl. VAT) for the part. That is not cheap... Now asking a Dutch dealership.
MR |
01-31-2017, 03:39 AM | #69 | |
Rep 791
Paid £27 for a used one via eBay. Hopefully a working one with minimal dinks.
YMB F80 M3 DCT (Gone but never forgotten)
AW F87 M2 6MT (Current whip) |
01-31-2017, 10:08 AM | #70 |
Rep 2,856
01-31-2017, 10:50 AM | #71 |
Rep 95
For BMW OEM parts in Europe, this is very good:
https://www.leebmann24.de/bedieneinh...319252912.html |
01-31-2017, 12:30 PM | #72 |
Rep 791
Part arrived - was easy to pry open and remove the rocker (Sport-Eco Pro) switch. I used a kitchen knife.
Any ideas how to remove the existing part on the console? Mine's a 6-MT. I inserted an old credit card on the lower left corner. But can't seem to pop it out. Some tips and advice is appreciated!
01-31-2017, 01:55 PM | #73 |
Rep 549
Drives: The Bus
Garage List 2017 Ford Focus RS [0.00]
1971 Mk3 Austin Min ... [0.00] 2013 MINI R56 GP [0.00] 2013 MINI R55 Clubvan [0.00] |
Dct or manual? I found it easier to remove the manual shift boot. Just grab the boot on a corner and pull straight up
01-31-2017, 02:16 PM | #74 | |
Rep 791
I placed an old CC bottom left hand corner. Managed to place it underneath the part.. but just doesn't lift up. I don't really want to use too much force to break some bits fitted on the console... will try again in the weekend.
01-31-2017, 02:18 PM | #75 |
Rep 549
Drives: The Bus
No guts no glory mate What's the worst that can happen? Just pull on the shift boot really hard straight up. Once it's off you can get under the boots and pry it up from the bottom.
01-31-2017, 02:25 PM | #76 | |
Rep 791
Ta.
01-31-2017, 11:06 PM | #77 | |
King of the World
281
Rep 301
I found it more effective to pry the button panel out from the top end (i.e., the end near the DSC Off button) than the bottom end which seems more flexible and delicate. I used a plastic pry tool that was shaped pretty much like a very wide flat blade screw driver. Took an uncomfortable amount of pressure (more than I had expected), but the button panel finally popped out. Good luck! -scr Edited to add: I started prying on the top right corner of the button panel, and worked my way to the left. Last edited by SoCalRob; 01-31-2017 at 11:19 PM.. |
M2wolf182.50 CantComplain116.50 |
02-01-2017, 12:53 PM | #78 |
Rep 220
I googled images of all 3 part numbers from one of the posts above; for the original switch, and the ones with the extra buttons. My theory was that there would be additional pins for each of the P/Ns that had more buttons, and that I could cobble/bespoke a switch to effect the same change as the button by putting a switch inline on the extra wire. But it looks like each switch has the same number of pins where the module gets plugged in. So there must be some momentary break on one of the wires that triggers the audio and video off. Without a wiring diagram, it's beyond my skills. But I bet it would be pretty easy.
Yes, all to save $100, but I like tilting at windmills. |
02-01-2017, 01:38 PM | #79 | |
Never underestimate the Home-Bowl
484
Rep 821
Drives: F87 M2<E92 M3<E46 M3
Garage List 2017 BMW M2 [0.00]
2016 BMW M235i [0.00] 2012 BMW 120d M Spo ... [0.00] 2010 BMW M3 - SOLD [10.00] 2002 BMW Z3 2.2i Sport [0.00] 2001 BMW M3 - SOLD [9.00] |
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT 2016 F22 M235i Coupe, MW, ZF8 |
02-01-2017, 02:12 PM | #80 | |
Rep 791
Will look into it at daylight during the weekend...
02-01-2017, 03:58 PM | #81 | |
King of the World
281
Rep 301
Regarding the shift boot - a few weeks back, I removed mine in order to swap it for a leather version (not a fan of Alcantara). It was exceedingly easy to take out. Just put a plastic panel removal tool under the bottom left corner and pry up. When I did this, the entire shift boot popped out easily and cleanly. It's held in by little plastic clips in each corner, and is very easy to put back in (just press down each corner clip). Having said that, as I mentioned before, you don't really have to remove the boot in order to remove the button panel. In fact, I used the top left corner of the shifter boot as a lever point when prying out the button panel. Keep at it - it will come out eventually. However, as I noted before, you may have to use an amount of force which seems excessive, almost scary. Good luck. -scr |
02-01-2017, 04:15 PM | #82 | |
Rep 220
How cool would it be to embed a switch in say, the knee pad? Just a tap from the knee to disable the annoying sounds. Would save you from taking your hand off the wheel or gearshift to press the switch. Admittedly it would be cooler to figure out how to just disable it when you took the car out of reverse, but apparently that's asking too much of BMW. Last edited by CantComplain; 02-01-2017 at 04:43 PM.. |
02-01-2017, 05:13 PM | #83 | |
Rep 549
Drives: The Bus
02-03-2017, 05:48 PM | #85 |
Rep 574
M2wolf182.50 MerlinPurple688.50 |
02-03-2017, 06:38 PM | #86 | ||
Rep 2,200
E9X Picture Game: 8 points: (High visibility jacket; Strip Club; Pizzeria; Sobriety Test; E9x dressed for Halloween, Billiards, Oil Change, Orange Cone)
02-04-2017, 12:57 AM | #87 |
Rep 791
I'd appreciate that!
02-04-2017, 04:15 PM | #88 |
Rep 287
I tackled the removal of the drive mode switch today and took some pics to help others.
There's different ways to tackle it, here is what I did: I removed the DCT cover using a card and non-scratch interior trim tools: I mounted a card and trim tool in the location circled below: like this... The drive mode switch has an 'elbow' on either side. I used my trim tool to pry it upwards and unit popped out. After this you'll need to unclip the connector on the drive switch panel - look for a tab on the connector, press it and pull the connector away from the panel. Hope this helps |
CommitConfirm474.50 kiysersosae437.50 Aust350z243.00 SoCalRob281.00 Prodigy.698.50 Enriquezar18.00 M2wolf182.50 AndrewC198910944.00 |
