10-10-2019, 07:44 PM | #419 | |
Starfleet Command
330
Rep 789
the obd reader is in first before diag mode? i have airplane mode on but wifi and BT are on. BT is showing connected to car and obd reader, maybe that's it.
2020 X5 M50i Phytonic Blue w/ Black Merino
22" 747M wheels, |
10-10-2019, 07:54 PM | #420 | ||
Rep 2,610
10-10-2019, 08:34 PM | #421 |
Starfleet Command
330
Rep 789
When I'm in diag mode, is it normal for climate controls to be on and blowing air? engine is off in diag mode
22" 747M wheels, |
10-10-2019, 08:35 PM | #422 | |
Rep 2,610
10-11-2019, 11:06 AM | #423 |
Member
902
Rep 2,032
Drives: 2019 X5 40i M Sport
Garage List 2023 BMW M2 (HEA) [10.00]
2021 330i xDrive [0.00] 2019 G05 X5 M Sport [0.00] 2017 Jeep Grand Che ... [0.00] |
Just got an update from Stephan that the Assisted Driving View will not be available in the App so if you are looking for it you will need to code it using esys
2019 X5 Alpine White M-Sport
Software Version 11/2022.31 2023 M2 (HEA) Brooklyn Gray 2021 330i XDrive Alpine White M-Sport |
10-11-2019, 11:53 AM | #424 | |
Rep 125
Cheers! |
10-11-2019, 01:18 PM | #425 | ||
Member
902
Rep 2,032
10-11-2019, 01:19 PM | #426 | |||
Rep 125
10-11-2019, 03:42 PM | #427 |
Starfleet Command
330
Rep 789
Bimmercode OBD Link MX+ M50i 07/2019.55 strange behavior
Tried again wifi off. and only OBDlink MX+ connected to BT. Only code to turn off seatbelt chime is avail. NO Auto SS to remember setting.
any other ideas why I don't see other ECU? Can someone on Istep 07/2019.55 and OBD Link Mx+ try to see if ECU list is same as mined? only ECU seen is first 2.
22" 747M wheels, |
10-11-2019, 08:45 PM | #428 | |
Rep 2,610
10-13-2019, 08:29 AM | #429 | |
Rep 126
I was updated to .55 a week or so back and had to redo the coding. I also use the ODBLink MX+. As others have noted, the options have been reduced down to ASS and a couple other minor things, but I was able to recode the ASS without any problem. |
10-13-2019, 10:11 AM | #430 | |
Rep 855
Anyhow, seems like still issues with .55 so no rush at all.
2018 540ix msport
2015 X5 msport 2013 750ix msport 2011 550ix msport 2009 e92 335i msport |
X54TH902.00 |
10-25-2019, 06:03 PM | #431 | ||
Rep 125
10-26-2019, 07:48 PM | #432 | |||
2020 Mineral White 30d MSport
527
Rep 2,146
Drives: 2020 Mineral White 30d MSport
10-26-2019, 08:02 PM | #433 | ||||
Rep 125
10-27-2019, 10:38 AM | #434 | |
Rep 984
I was able to code ASS memory via Esys, though. Last edited by spike5150; 10-27-2019 at 10:43 AM.. |
10-31-2019, 07:14 PM | #436 |
Starfleet Command
330
Rep 789
Now I successfully coded ASS off. some over stuff too, like disable warning nag message. I didn't see close trunk lid w. key fob, is that available?
22" 747M wheels, |
11-03-2019, 09:14 PM | #437 | |
Rep 125
Also, has anyone lost the screen that shows when you park the car. I think it usually shows a screen asking you to enable valet mode, etc. I'm convinced since I coded something it inadvertently removed that feature. |
11-03-2019, 09:17 PM | #438 | ||
Rep 684
2019 G05 X5 40i, Phytonic Blue, Black Extended Merino Leather Interior
11-03-2019, 09:18 PM | #439 | |||
Rep 125
gpitts247.00 |
11-03-2019, 10:28 PM | #440 |
Rep 252
I think you will find it if you pull up the notifications option off the top pull down menu. There are boxes on the right you can select for valet, in progress call, etc. if you want to check.
