09-13-2021, 03:55 PM | #23 |
Rep 6,803
All of the hardware is captive...you set it in place and tighten a knob, then snap the end cover down over the knob, repeat until all four ends are tight. They recommend that you go around and check the tightness after you've driven a bit, especially the first few times you use them, as the rubber protectors might compress a little.
09-13-2021, 05:17 PM | #24 |
Rep 810
The one thing I don't like about BMW bars is the cross-bars don't have an overhang section past the mounts.
I know Thule have the option of both, but I went for the overhang aero bars as its useful for tie-downs, cargo net covers and gives you a little extra bar room over the edge which can be useful if you're lifting heavy things onto the bars from ground level. The overhang isn't too much, only around 4 inches max past the rail mounts. |
09-14-2021, 12:53 PM | #26 |
535
Rep 364
Drives: 2011 AW E92 ZCP 6MT
Garage List 2021 Toyota Tacoma [0.00]
2020 BMW X5 [9.00] 2020 Subaru WRX [0.00] 2019 Ford Raptor [0.00] 2011 BMW M3 [0.00] |
We had Thule's Aeroblade crossbars on our 4Runner and really liked the lower profile, but they are $280/ea.
I happened across a smoking deal on a used set of BMW's OEM crossbars and couldn't pass them up. I'll keep an eye out for a good deal on Thule's lower profile setup . . . But not necessary.
AW 2011 E92 ZCP 6MT single hump w/speed cloth.
Alpine Stage 2 | Apex Manufacturing X-Pipe | Corsa | BayOptiks | Haimus Racing CF Plenum MW 2020 G05 X5 with delicious coffee interior |
Flying Ace4984.50 |
09-30-2021, 06:10 AM | #27 |
Rep 87
To the OP and others. What have been your experiences with the OEM rack/rails and box? They’re what I plan on buying. Where did you buy from, did you install yourself, tips, tricks, discounts, etc?Thanks in advance.
2020 BMW X5
2023 Porsche Carrera T 2022 Ford Bronco 2DR Wildtrak |
09-30-2021, 09:04 AM | #28 |
4985
Rep 11,891
Any outside chance my original OEM E70 bars for a non-low profile rails work on a G05 M Sport?
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
09-30-2021, 09:08 AM | #29 | |
57
Rep 42
I installed myself (really straight forward) but does take two people to reach over the vehicle and two people to physically lift the box and place it on the rails. One person can secure the box down to the rails themselves. The markers for where to place them are super subtle and you have to feel for them with your fingers. I was able to get a 10% discount just by asking. I am sure there are always coupons floating around but just asking nicely may score you the 10% off. I have been pleased with the look and utility. No issues except some minor wind/whistling noise that can be alleviated with some duct tape on the tops of the rails. Some wind noise just from turbulence is unavoidable but its minimal. The whistling is what I have trouble with and that is what I use the duct tape for. Hope this helps. |
09-30-2021, 12:14 PM | #31 | |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
By the way, do you get any whistling noise from the bars?
2021 X5, Excellence, M Sport, DHP, DAP, RSE, MW, Merino.
09-30-2021, 11:04 PM | #32 | |
Rep 11
Drives: 2022 BMW X5 45e
Length of Bars
10-01-2021, 12:50 AM | #33 |
Rep 2,704
The side plastics come off (the ones with the locks), brought them to the paint shop, they sanded them (you loose the Thule logo) and painted gloss black. Was like 100 bucks for all 4. Whistling noise is not too much (more with soundroof, but its really quiet. I discovered that if you remove the rubber which is on top of the bar (if you need to add a bycicle holder there or smthg) then it whistles more. After you carry something then just place those rubber lines back in (as when out of place they make noise).
SmartSaves462.00 |
10-01-2021, 01:37 AM | #34 |
Rep 810
10-01-2021, 06:15 AM | #35 | |
Rep 2,704
SmartSaves462.00 |
10-01-2021, 11:22 AM | #36 |
Rep 268
Here's a side profile of my car with OEM bars and cargo box. I don't know what the noise level is without the cargo box because I take my bars off when I am not lugging the cargo box. With the Thule box on, I can hear wind noise at 65mph+.
beegee22736.50 |
10-01-2021, 11:50 AM | #37 | |
Rep 153
The one that Thule site configurator shows is N/A anywyere in the US (184023)... BUT, some googling surfaced another possibility FitKit 4023... notice the same last 4 digits between the two. The latter is available in few places and it seems like it "may" work, but looking at the manuals between the two fit kits I get an impression that 184023 is newer, but basically the same thing as 4023... but since its not shown on the official Thule site/configurator I am hesitant since the may have made some tweaks recently to the bars and the old one may no longer fit or something. |
10-02-2021, 04:58 AM | #38 | ||
Rep 2,704
Thule Edge Flush Rail 7206 Thule WingBar Edge 104 (black) 7215B Thule WingBar Edge 95 (black) 7214B Thule Kit 186007 G05 and F15 are the same part numbers |
10-03-2021, 07:49 PM | #39 | |
Rep 153
Also not whats on your pic no? What you have on your pic is the AeroBlade... They are more aerodynamic, flush and don't have overhangs. Wingbars are the ones with overhangs. On Thule site, if you identify your car as 22' G05 / X5, it says you need: 2 x AeroBlade Edge 7603B 1 x FiKit 184023 Cool to hear G05 and F15 have the same fit kits... I can use it on both cars then Last edited by 5pacey; 10-03-2021 at 07:56 PM.. |
10-03-2021, 09:10 PM | #41 |
Rep 558
For some reason shopbmwusa.com says 420 Liter Roof Box (Part #82732406460) isn't compatible with G05 X5 at all?
https://www.shopbmwusa.com/PRODUCT/6...LITER-ROOF-BOX |
10-04-2021, 12:50 AM | #42 | ||
Rep 2,704
You need to select your BMW model and make. These guys are reliable as I needed to order an extra key unique to my Thule roofbars, they delivered. I know know that with these you always need to have it locked or you might loose the sides. Its should be Option C Thule WingBar Edge Package You can additionally spec the ones in black. Here should be able to see all the options: https://www.roofracks.co.uk/thule-fit-guide/1963 |
10-04-2021, 08:02 PM | #44 | ||
Rep 2,353
Thule T-Track Adapter 697-4 for attaching The roof Box Directly in The T-Slot https://www.amazon.com/dp/B001CODRXU...UTF8&psc=1 |
