      03-21-2021, 04:17 AM   #265
ifr
ifr's Avatar
United Kingdom
1202
Drives: Tesla MY LR AWD
Originally Posted by phayze View Post
Hi,
Ok, i try get esysx and code those line that bimmercode dun support.
That is your only option. SAS is where the region locks are, so you can code whatever you light for TLA but it will never work.
That's why the spreadsheet states to code them and that's why I told you to code as per the spreadsheet, not cherry pick what you think might work.
No idea if it will work in Singapore. You could buy esysx, code it and find it doesn't work. Your choice, but do report back the result.
If you get it fully working, the idrive advice I gave 'should' disable the Drive Assist intervention part
      03-21-2021, 05:25 AM   #266
phayze
Drives: BMW
Hi,
Understand. I will try out and revert whether it will work in Singapore or not.
Usually I will try to code one by one to know what actually each line of code does. Like the coding for the "Additional display" for HUD that you share to solve to display the tach display when in sport mode, i learn as i code one by one at each time and see what it does. I will indicate in my own record as per below so that i know i am doing next time if i were to do it again if the coding get erase after software upgrade.
CB_HUD_FAS: aktiv [01]
Driver Assistance Checkbox
CB_HUD_LIST_AUS: nicht_aktiv [00]
Additional Displays Menu
CB_HUD_LIST_AUTOMATISCH: nicht_aktiv [00]
Additional Displays - Automatic Option
CB_HUD_LIST_FAS_PERMANENT: nicht_aktiv [00]
Additional Displays - Driver assistant Option
CB_HUD_LIST_SPORT_PERMANENT: aktiv [01]
Additional Displays - Sport displays Option
CB_HUD_LIST_SPORT_AUS: aktiv [01]
Sport Displays Menu
CB_HUD_LIST_SPORT_FES: aktiv [01]
Sport Displays Menu - Display in Sports
      03-21-2021, 05:40 AM   #267
ifr
ifr's Avatar
United Kingdom
1202
Hi,
Sport Displays Menu
aSLA and TLA is advanced coding. You have to go all in, know what you are doing, and understand the pre-reqs.
I spent a lot of time working out the interdependencies between all the systems, while also unblocking the region locks. You can't expect help if you ignore the advice and choose to do your own thing, then come back and ask for further help without revealing you ignored the original advice. it's a waste of your time and more importantly my time and pees me off.
volodp199.50
      03-21-2021, 05:45 AM   #268
phayze
Drives: BMW
Hi,
I appreciate for your time. Sorry about that and i will take your advise and try out. Will revert and contribute after trying.
ifr1201.50
      03-21-2021, 08:30 AM   #269
phayze
Drives: BMW
Hi,
I had code all and now Speed limit will be accepted automatically where possible, no more without anticipation.
But i got 2 thing that i am unable to code.
C_SLA_UCC_Land_aktiv and C_SLA_aUCC_Land_aktiv
There is no option for me to change to FFFFFFFF.
      03-21-2021, 08:36 AM   #270
srbs73
srbs73's Avatar
United Kingdom
561
Drives: BMW i4 M50
Hi,
You need to change Werte to FF, FF, FF, FF. It’s a manual edit not a drop down.
      03-21-2021, 08:42 AM   #271
phayze
Drives: BMW
Hi,
I am unable to manual edit. It is blur out. Is there anyway to do?
      03-21-2021, 08:53 AM   #272
srbs73
srbs73's Avatar
United Kingdom
561
Drives: BMW i4 M50
Hi,
Trying to remember, but I believe there’s a little edit icon in the bottom right area of Esys and then you edit it in a window below.
      03-21-2021, 08:58 AM   #273
Fpgiuliano
Fpgiuliano's Avatar
Italy
43
Drives: Bmw 320d Touring xDrive Msport
You need to edit and insert manual value in the bottom box (where you see “FF”)
Then click on the little button on the right side for save
      03-21-2021, 09:01 AM   #274
phayze
Drives: BMW
Hi,
Ohh, thank you. I will try out.
      03-21-2021, 08:38 PM   #275
mlavio829
Drives: 2020 BMW 330i X Drive
Just wondering has anyone in Canada been able to get the stopping at Traffic light function to work?
I was able to code everything successfully thanks to the chart/excel file from ifr, however, for some reason the car hasn't stopped at the Red light. I also enabled "Automatically adjust speed" in iDrive.
Upon testing, it seems to detect the Red light and I click set, however, it doesn't apply the brakes.
As I got even closer to the traffic light, it started to slow down, but if I let it go further it would be in the middle of the intersection. (Sort of defeats the point)
I just got OTA 11/2020.50 and coded it this evening.
Any ideas?
      03-21-2021, 10:37 PM   #276
phayze
Drives: BMW
I had change both the value to FF, FF, FF, FF.
But still does not work.
Hi,
      03-21-2021, 11:07 PM   #277
phayze
Drives: BMW
Hi,
Can check, how did u resolve “Function not available in this country.”?
Originally Posted by Baron G15 View Post
FINALLY!!! I now have Traffic light assistant working on the car
It only took four coders before I found someone who could actually do this!!! (he’d done quite a bit of coding discovery with Shawn Sheridan over on Bimmerfest...so I knew he had the requisite skills).
A huge thank you to IFR for the coding sheet, which not only gave me TLA but also, emergency lane formation, adjust distance acc to situation, probable path bending etc etc
I only had a chance to test the system very briefly as it started to snow (not a good environment to try out stopping at red lights). On the two sets of lights I tried, one required me to tap ‘set’ to accept the light, the other light was automatically accepted and the car came to a graceful, perfect stop.
Setting off didn’t work for me but, I think this is a traffic light issue, not a coding issue. On one set of lights I got ‘grey traffic lights’, I may have put my foot on the brake when I’d come to a stop (probably deactivated assisted driving function) on the other set of lights I got grey traffic lights with a red X at the bottom (IFR, have you seen this symbol before).
Does the traffic light icon show red, amber and green, or just red and green....also, do you have drive off reminder set to early, normal or late?
To drive off, do you just tap the accelerator or push the set button on the steering wheel.
      03-22-2021, 03:15 AM   #278
ifr
ifr's Avatar
United Kingdom
1202
All,
This is the state of TLA world-wide.
It has only been officially released in a handful of markets, for MY21, and even those where it has been released, it appears there are some restrictions.
If you follow my coding exactly and meet the pre-reqs, one of the following scenarios is possible:
  1. Function not available in this country - hard-stop. It will not work and is blocked. Not at a coding level, but at a software level. This indicates that the system would not work well or safely if enabled with that regions TL systems. Examples - Russia, AUSY, Singapore(?)
  2. Function is supported but does not work well, or works intermittently - examples are US, CA, China. Important markets that BMW will want to support but the system is not developed enough to deal with all scenarios
  3. Function is fully supported - EU countries including DE and UK. The system will read 'most' lights and either auto accepts or requires manual SET for acknowledgement. Stops accurately and safely at the light, even if changing from Green to Amber, and will prompt the user to restart on Green. This system works 90% of the time but will still fail at times and is not totally reliable.
While I am seeing improvements to the system with each i-step release, the land mask for UCC has not changed since 07/2020. This means BMW have not changed the regions that are supported for Urban Cruise Control (UCC) which underpins TLA. Probably because the system is not fully baked in the regions it is supported yet. They may also have moved dev onto the SP21 vehicles. Hopefully the development for the system is supported on both platforms, but we will see.
It seems that aSLA is a dependency for the system, and the 'Consider Traffic Lights' option is in the same idrive menu area. Regions that do not natively allow aSLA, like North America, do not meet that dependency without coding.
In summary, it's complicated.
Appreciate 4
sahajesh2295.00
volodp199.50
      03-22-2021, 06:03 AM   #279
phayze
Drives: BMW
Hi,
Can i check, after i change C_SLA_UCC_Land_aktiv and C_SLA_aUCC_Land_aktiv to FF, FF, FF, FF, the Ausgelesen become "UNKNOWN". Is it suppose to be like that?
All,
      03-22-2021, 07:03 AM   #280
ifr
ifr's Avatar
United Kingdom
1202
Hi,
Yes.
The only other possibility is that there is another dependant system that is geo restricted. You could change ALL 'land' masks to FF, FF, FF, FF in SAS3 and VIP. That would ensure that all supported features are active for your model and region for SLA and all sub-systems such as TLA, UCC, aSLA, etc
      03-22-2021, 08:01 AM   #281
phayze
Drives: BMW
Hi,
My DSC_VIP do not have 3D14. It have 3D78. I also cannot find C_SLA_Vorausschua_Land_Altiv. It have C_SLA_Vorausschua_Land_Altiv_Erweitert instead.
Is 3D14 & 3D78 the same?
Yes.
      03-22-2021, 08:08 AM   #282
ifr
ifr's Avatar
United Kingdom
1202
Hi,
If its called VIP and has the same codes as the spreadsheet then yes.
if you find any land masks are set to 00, 00, 00, 00 then ignore these.
      03-22-2021, 09:04 AM   #283
phayze
Drives: BMW
I do not have this "C_SLA_Vorausschua_Land_Altiv" in the CAFD.
I have "C_SLA_Vorausschua_Land_Altiv_Erweitert" instead.
      03-22-2021, 09:21 AM   #284
ifr
ifr's Avatar
United Kingdom
1202
If you don't have it then you can't configure it? If you have it then configure it. If it's 00, 00, 00, 00 leave it alone.
That's it - you are looking at VIP, you just have a different model.
I fear there will be more and more questions. I'll leave others to answer them.
      03-22-2021, 09:27 AM   #285
phayze
Drives: BMW
Hi,
Haha, no more question. Thank you.
      03-22-2021, 10:45 AM   #286
ifr
ifr's Avatar
United Kingdom
1202
Hi,
Phew
Results always welcome ....
