01-02-2022, 06:20 PM | #45 |
TGTBTU
84
Rep 140
2022 X5 40i
Driving back from Tampa, FL to Orlando, FL and came across some patchy fog. Perfect opportunity to use my automatic laser lights. What I discovered was astonishing - the laser lights made visibility worse. I had to turn it off.
The fog lights would've helped… |
Bimmerfun827201.50 |
01-02-2022, 07:12 PM | #46 |
805
Rep 1,790
Just another example of one of BMW's epic fails.
01-02-2022, 09:53 PM | #47 | |
Rep 8,698
Drives: eVeRyOnE mAD!
sure, fog lights would've helped, but so is knowing what the proper use-case is for the laser lights. https://g05.bimmerpost.com/forums/sh....php?t=1592918 hmmm I don't think so. it's user error/lack of understanding |
01-02-2022, 10:14 PM | #49 | |
Rep 8,698
the bottom line is you shouldn't turn on high beams in fog. that's basic driving 101. the lasers that support the high beams are of no utility in fog. that's not what they are designed for. not trying to offend, but it appears you don't understand how the laser lights work, what situations they're of benefit, etc. that link I posted should help if you read it or Google. |
thereef5101165.00 |
01-03-2022, 10:24 AM | #50 |
TGTBTU
84
Rep 140
I mis-understood the laser lights capabilities and should've done more research before spending extra money on that option. My SA led me to believe otherwise.
That said, I am still eagerly waiting more information on retro-fitting fog lights. |
01-03-2022, 10:30 AM | #52 |
Rep 2,072
Having no foglights isn't odd looking (I actually tinted mine so they wouldn't look as bright/white), but having the aperture for foglights and then putting a little grille in there definitely does look off IMO. Maybe it would have looked better if it was blanked off with gloss black solid plastic.
Its obviously worse if you are used to seeing the same model with foglights there - when you see one with them missing in favour of grille, well... it looks like something is missing. Its not a big deal though - most people would probably never notice. |
01-03-2022, 11:18 AM | #53 |
Rep 744
Not saying fog lights don’t have utility but 40+ years of driving I have never intentionally used them. I’m sure there were a couple of case in that time which I could have/should have switched them on but they aren’t even on my radar. That said, I lived most of my life in the flat Midwest and although we get fog, it’s not that common.
01-03-2022, 11:58 AM | #54 |
Rep 1,354
Drives: 2022 X5 m50i
I use them 75% of the time when driving at night on my F15 and used in all my previous BMWs as they helped to illuminate the sides and also the first 20 feet in front of the car during heavy rain.
BWW Xenons and LEDs were never very good at illuminating the peripherals, which is a necessity if you drive in heavily wooded areas and on the hills with many nocturnal animals and with occasional fog patches. They help to see you better without blinding oncoming traffic like the high beams do. Also, BMW has to have a better LED system algorithm (like I have it on my MB S Class) that do not over illuminate the street signs and create excessive glare, which is like shooting yourself with your own gun.
2022 BMW X5 m50i
2024 MB S63 on order '18 X5 50i / '16 BMW F10 550xi / '13 BMW F10 535i / '07 BMW E64 630i / '03 BMW E65 745i / '95 BMW E34 540i / '89 BMW E30 M3 |
kkratochvil313.50 Surgx572.50 |
01-03-2022, 12:27 PM | #55 | |
Rep 459
I'd posted this over in the thread surrounding the Laser Lights: https://g05.bimmerpost.com/forums/sh...5&postcount=86. The short version of which is: "One thing I had always noted with the F15 and notice as well with the G06 is that with just the low beams, when on an interstate or busy 2-lane where there is too much traffic for the high beams to ever come on, I feel a bit like they're so focused that I don't have much of the ditch/median illuminated to see animals. So, in that case, my solution is to almost always drive with the fog lights on. They do almost nothing to illuminate the road directly ahead in normal conditions, but because they're fairly unfocused light, they do a lot to illuminate the ditch/median."
2020 BMW X6 (G06) M50i - Manhattan Green/Coffee - 11/2022.63
hufington3120.50 |
01-03-2022, 12:53 PM | #56 | |
Rep 1,354
I intentionally did not get the laser lights in my 2022 m50i because of all the bull**** US legislation regarding the laser and LED lights - that they need to be decoded to meet the archaic regulations! I will not spend any money until they come from factory as they were intended and engineered. I already have Baja S1 lases lights which I will transfer to my '22 and find a solution for rear fogs as well (auxiliary not OEM lights). The best lights on any BMW I drove were the headlights of my M3 (E36).
2022 BMW X5 m50i
01-03-2022, 05:39 PM | #59 |
Rep 3,408
01-03-2022, 06:59 PM | #60 |
Rep 1,354
They were halogen and they illuminated the road perfectly.
2022 BMW X5 m50i
01-18-2022, 12:04 PM | #61 |
Rep 1
Interior?
01-18-2022, 12:19 PM | #62 |
4985
Rep 11,891
Again I think fog lights is a misnomer. It makes visibility worse in fog. The light reflects off the fog, and it inhibits the driver. It made aid other cars to see your car however. On the older BMWs, and likely to 2019s, they're part of the turn lights.
On my old E70, I used to fog lights mostly in pitch black areas where I need to illuminate a wider patch (road shoulders, sidewalks), mostly to look for animals
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
01-18-2022, 12:33 PM | #63 |
Rep 512
I only find fog lights useful when it rains. It helps provide illumination to down to the pavement so i can better see the lines in the road.
Otherwise...I've found the fog lights provide little benefit...even in foggy conditions. |
01-18-2022, 02:01 PM | #64 |
Rep 3,006
The newer adaptive headlight almost make the fogs obsolete. If BMW USA started enabling the anti-dazzle then they are definitely obsolete.
Thought, I would miss them on my M2C. I don't. Just like I don't miss the sunroof. I miss fogs as much as I miss the headlight washers on non-LED vehicles /s My only complaint is BMW could have done a better job w/the trim instead of filling the gap w/the mesh look. IMHO the recent US anti-dazzle approval will signify the end for fogs going forward. Is there a limited number of circumstance where fogs are useful. Yes, just like there are for HDC. Most people rarely have a need for either. Last edited by omasou; 01-18-2022 at 02:07 PM.. |
Flying Ace4984.50 |
01-18-2022, 07:15 PM | #65 |
Rep 117
I used front fogs quite a bit on my previous car - 2017 Q7. They were narrow but wide-coverage lights. Have to admit that most of the the usage was on late evening trips to Arrowhead for spotting deer on road's sides when dark and wet, - especially helpful in Minnesota's October-November season. Used both - rear and back fog lights a few times in very bad fog situations. Was pulled over once by State Trooper for "too bright rear lights" and was let go after proving that they were part of standard Q7 package.
My 40i does not have fogs, but it does quite OK without them. |
01-18-2022, 10:51 PM | #66 | |
MGySgt
637
Rep 1,256
Drives: See Garage List! ;-)
Garage List 2010 M5 [10.00]
2016 BMW 340xi M Sport [9.00] 2019 X5 50i M Sport [5.50] 2010 535xi [0.00] 2013 M5 [0.00] 2012 X5 M [0.00] |
And how could I have forgotten the M1
JMD
