      02-05-2019, 09:45 AM   #23
AndroidRobot
AndroidRobot's Avatar
  [0.00]
Originally Posted by X5_CC View Post
Just looked and my loaner doesn't have it. If I remember correctly, it's right behind the cool/heat buttons for the cup holders (like toward rear of vehicle). In that gap between the top of the cup holder and the wood trim.
I'll check it out, if they put one there I'd think any cups would block the flow
      02-05-2019, 01:09 PM   #24
Xeno
Xeno's Avatar
315
Drives: 2019 X5 M Sport 5.0i
Yes, I see the vent. It would be curious is this is a factor in this 'heated' debate.
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired
R360c + EL, V1G2 + V1Driver, Uniden R8
      02-19-2020, 11:58 PM   #25
thereef510
thereef510's Avatar
Drives: '16 X5 35i, '20 X5 40i
Just tried wireless charging on my (naked) iphone X after the PCD last thursday. On the drive back, the phone got incredibly hot, and carplay shut down. it was very sluggish for a few minutes till the phone cooled off. I've tried wiress charging a few times since then but it still heats up the phone and doesn't really charge it at all.
I still like that area as a good place to store your phone and I can use one of the USB ports to charge it (wireless charging degrades your battery faster anyway) Where in the settings can you go to turn off wireless charging?
      02-20-2020, 07:38 AM   #26
randybobandy
Rick James
randybobandy's Avatar
305
Drives: 2020 BMW M340i xDrive
I've noticed a huge difference in the phone's temperature after using the direct streaming Spotify through Connected Music instead of Apple Music in CarPlay. The phone is still connected via CarPlay, but only for Phone and Messages. Not an ideal solution, but I always worry about my phone heating up and doing a number on the battery.
Ghetto Trick: Plug the phone in and start the Cooling function for the cupholder. Place phone in cupholder!
      02-20-2020, 12:52 PM   #27
CMBX23
CMBX23's Avatar
Drives: 20' 540i M Sport
2020 540i  [0.00]
When I do actually use the wireless charger it does make my iPhone 11 Pro Max burn up, also did with my iPhone X. Besides it being placed in an awkward space if you have anything in the cupholder, this is why I rarely use it anymore.
      02-20-2020, 04:17 PM   #28
thereef510
thereef510's Avatar
i used the usb-c port in between the armrests today, and i was surprised and amazed how quickly it charged my iphone X. I know its not supposed to be a fast charging port but I swear it was quicker than the port on my f15. Never will I use the wireless charging port again, all it seems to want to do is hasten the demise of your battery without actually charging it.
X5 45e1090.50
      02-21-2020, 08:46 AM   #29
randybobandy
Rick James
305
The only thing missing for the port in the center console is a small cut out for your cable. I might be missing it, but I hate closing the lid on the cable.
X5 45e1090.50
      02-21-2020, 09:08 AM   #30
X5 45e
1091
Drives: BMW X5 45e
You could also use the usb C in the middle ?
      02-21-2020, 09:12 AM   #31
X5 45e
1091
Drives: BMW X5 45e
I'm my previous car the wireless charger had a blue light confirming the phone is charging. Didn't see it in the x5 until now. We are driving to the alps and my wife is behind the wheel. It's on the left side of the tray completely invisible from the driving position
In my previous car it also gave a signal when charging started. It doesn't do that anymore either. So I can only check if it's charging on the homescreen or CarPlay screen.
And yes my phone is also getting hot and not charging a lot. Was much better in the previous car.
      02-21-2020, 09:14 AM   #32
X5 45e
1091
Drives: BMW X5 45e
The middle console is 3A. The front usb is 1.5 and the two usb C on the back of the seat are 1.5 to.
      02-21-2020, 09:33 AM   #33
thereef510
thereef510's Avatar
are you sure about this? I was told the back ones are also 3A
      02-21-2020, 09:39 AM   #34
X5 45e
1091
Drives: BMW X5 45e
I read it on this forum I think. Or somewhere else. I am dricing to the Alps now and my wife is behind the wheel.
Was reading your post and switched the USB C charging my iPhone from the back of the seat to the middle console and It goes way faster. So I think back = 1.5A
thereef5101165.00
      02-21-2020, 09:45 AM   #35
X5 45e
1091
Drives: BMW X5 45e
Hmm just found the post and like you mention the USB c should all be 3A.
Can't remember where I found the other info. And can't explain my personal observation ?
And the manual also says 3A for the back of the seat.
My son is charging his iPad on the second back seat. Maybe that's the reason?
Or maybe I should just take the wheel. We are approaching the last 100 km and I want to do the alpine roads myself. 😜
thereef5101165.00
      02-21-2020, 11:10 AM   #36
thereef510
thereef510's Avatar
I need to get a couple more of those stupid expensive apple usb-c cables and i'll test it myself in the next few days. I'll try to set a timer to see how long it takes to charge something, that's probably the best way to get a definitive answer. My ipad charges slow regardless of what i have it plugged into so i'm sure that's part of it for your son.
X5 45e1090.50
      02-21-2020, 12:09 PM   #37
kkratochvil
Drives: 2020 BMW, X6, M50i
I can't confirm accuracy, but this thread made me realize I should figure-out what types of cables I'll want to take with me for my PCD in April, so I searched the forum and found this: https://g05.bimmerpost.com/forums/sh...&highlight=USB.
So TurtleBoy's post would indicate the backseat ones are 3.0A.
      02-21-2020, 02:23 PM   #38
thereef510
thereef510's Avatar
i didn't know either, so I just took a regular USB-A cable and 1 USB-C to lightning cable for my PCD. I didnt end up using either, just used wireless carplay on the drive back but if you had both of those, you've more than covered your bases.
      02-21-2020, 04:14 PM   #39
zmm12345
Drives: x7 and 330i
Originally Posted by AndroidRobot View Post
Same, where are you seeing the vent? I'll have to look at mine and check
I I have the iPhone 11 and it gets very hot. It can can keep up with streaming and Waze but it won't charge higher.
I had a 5 series rental recently and drove for hours without it getting as hot and it charged higher
      02-21-2020, 11:18 PM   #40
thereef510
thereef510's Avatar
wireless charging is stupid anyway. even if it works as advertised, the physics of how it works unnecessarily taxes your phone battery and ruins its capacity over time. I'm actually fine with just charging my iphone with one of the fast charging ports either in the center console or the back seats. we have wireless carplay and we all still get notifications and having it inside a cabinet doesn't impede my use of it in any meaningful way so i'd rather be safe than sorry.
      02-22-2020, 11:29 AM   #41
mandomedic122
Drives: BMW 2019 X5M G05, Mini 2016 S
I really don't use it due to it's location. It's to cumbersome to try to put the phone in and also to take out. The should have designed that cubby hole a little further forward to where the shifter is at to allow for the charger to be in front and the cup holders to the back. Just my opinion. It doesn't work either, my phone gets super hot and charges really slow. I use an iPhone 11 Pro or whatever it's called.
      02-23-2020, 06:01 PM   #42
babyghost
babyghost's Avatar
95
Drives: 2020 X5 M50i
My S10 overheats on the charger. I think it's related to the inside ambient temperature. And the wireless charger heats itself up lol.
      03-02-2020, 03:12 AM   #43
Ninefourteener
Ninefourteener's Avatar
1346
Drives: 2020 X5 M50i, 2020 Alfa 4C
There can't be THIS many people all having the same problem.... and it be the problem of the people's phones.
I tried my Galaxy S9+... both with and without the case.... and it gets burning hot, stops charging, and never charges fully.
I'm actually kinda pissed about this. Has anyone found a solution?
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019
690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813
6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342
      03-07-2020, 06:52 AM   #44
zhangyi17
zhangyi17's Avatar
287
Drives: BMW X5
Not directly related to the post. But personally, I don't use wireless charging anywhere (at home, in car, at work). I get it's convenient, but it's radiating energy. How much is been transmit by the induction coil? How much is been received by the receiving coil? The rest is just radiated away. Not my favorite thing for sure.
