01-08-2022, 02:02 AM | #1 |
SDStyle
Rep 4
Charging Options for X5 45e
Hi all! New here!
I am expecting to pick-up the X5 hybrid soon. I have not seen it or inspected the charger it comes with. I believe it comes with a Level 1 110V (standard home outlet) cable...right? I see a lot of posts regarding people installing wall chargers. I do not plan to do this. Alternatively, we have a 240V 30A receptacle in which we can charge a Tesla with the NEMA 14-30 adapter. We just use the outlet with the NEMA adapter and Tesla cable. My questions are: 1.) Does the cable the car comes with literally plug into any standard USA home outlet (110v?) 2.) If I want to use Level 2, can I buy a charging cable that fits the NEMA 14-30 that is compatible with the X5? 3.) If I want to use my Tesla cable (with NEMA 14-30 adapter), do I just get the adapter to convert the plug to be BMW-compatible? 4.) I have read 15+ hours for full charge with 110v, and 5-7 hours with 240v. Does that sound about right? 5.) If you had the 14-30 outlet with the Tesla cable, and also access to a standard outlet to use the provided BMW cable, what would you do? Use the 110v provided cable, buy a new separate cable that fits the NEMA 14-30 outlet to charge BMW, or buy the adapter that converts the Tesla plug to BMW-compatible. I have slight concern that adapter would damage the Tesla charger....? Not sure... I am definitely a rookie here and appreciate all help. Thank you! |
01-08-2022, 08:16 AM | #2 |
Rep 210
Since you already have 240V, 30A outlet - that is your best option. The included cable is pretty useless if you want to charge it on daily basis.
People on this forum have used Tesla adapter, so that might be the way to go. |
01-08-2022, 08:52 AM | #3 |
Rep 3,825
1. Yes
2. Yes 3. Yes 4. Yes 5. You should definitely use the power since you already have it, but keep in mind you can't charge at the same time, which could be an issue with the Tesla. Regardless, I wouldn't own a 45e without a level 2 charger. |
Flying Ace4987.00 Angiekeating6734.50 |
01-08-2022, 09:42 AM | #4 | |
Rep 8,828
Drives: eVeRyOnE mAD!
i'm not clear on something. you keep saying NEMA 14-30 adapter which is the plug that goes into the outlet. my answers below assume you have a Tesla Wall Connector that isn't hardwired, but that its power supply cable has a NEMA 14-30 plug fitted onto it.
for US-spec 45e (17.1kWh usable capacity), answers highlighted below: Quote:
01-08-2022, 09:59 AM | #6 |
Rep 8,828
01-08-2022, 06:27 PM | #7 |
Rep 6,911
A level 2 device is more convenient, but unless you deplete your battery on a daily basis, and the vehicle can sit long enough at home, the supplied level 1 device sold with it in the USA will work. Those where 220-240-vac is the standard, get a 10A, 220-240 device which is twice as fast, but still not as fast as one that can provide the full 16A the vehicle can pull. AC charging on any EV today is maximum current restricted both by the EVSE you have, or the draw in the vehicle (think of it like a light bulb...using a 75W light bulb pulls a certain amount, while a 100W one will pull more, but they both work fine plugged into the same circuit). The EVSE and vehicle are smarter as the EVSE sends out a signal that tells the vehicle the max it can pull, and it adjusts (the vehicle, not the EVSE). The EVSE is a smart on/off switch...all of the AC-DC conversion and smarts about what it will use is determined in the vehicle.
01-09-2022, 12:16 AM | #8 |
SDStyle
Rep 4
If I decided I wanted to park the x5 in my driveway more regularly.
1. Do you guys see a problem with running the charging cable under the garage door letting the garage door close on the cable, with the rubbery weather strip pushing on the cable? 2. I have an outdoor weather-protection covered outlet that I can use the level 1 charger with. Is the stock level 1 charger safe to use outdoor left overnight like this? I wouldn’t do it in rain…I’m in cali. Thank you! |
01-09-2022, 01:35 AM | #9 |
Rep 6,911
1. If locking your garage door isn't a problem, I suppose. If using a garage door opener, you might want to find a board that was the right thickness to allow the cable to not be compressed. What I did is I put a box you might use to have the paper put into on the wall (if you could find one that would!) on hinges, and a hole through the wall behind it, and ran the cable through the wall. When it wasn't being used outside, from the inside, I had fashioned a foam plug to close it off and had a second one with a notch cut out of it to go around the cable to keep wind and bugs out. I did this when I had an ICE in the garage and an EV parked outside. Now, I got rid of the ICE and EV, and just have the PHEV, so I park that in the garage.
2. the unit shouldn't be left where it could end up submerged, but it shouldn't be hurt by being wet. |
01-09-2022, 02:47 PM | #10 | |
Rep 123
If you already have a level 2 Tesla charger, just get the Tesla-to-J1772 adapter. The one that came with my Level 2 ‘bundle’ from Lectron works great…tried it on a public Tesla charger the other night. https://www.amazon.com/Lectron-Adapt...461867119&th=1 Last edited by 91Eunos; 01-09-2022 at 02:57 PM.. |
01-09-2022, 07:41 PM | #11 | |
184
Rep 326
01-09-2022, 07:54 PM | #12 |
Rep 8,828
DC charging is not supported on the 45e. whoever were to use the Tesla to J1772 adapter and plug a 45e into a Tesla Supercharger will have a bad day!
91Eunos105.00 |
01-09-2022, 09:49 PM | #13 | |
4987
Rep 11,891
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
01-09-2022, 09:53 PM | #14 |
Rep 6,911
The X5 only supports ACV inputs in either level 1 or level 2 through it's J1772 connector and protocol. It supports about 110-250vac inputs. The Supercharger network supports DCV inputs at approximately 400VDC...i.e., not compatible!
There are three different DC, fast charging standards: - CCS - Tesla - CHAdeMO and basically one ACV standard, in level 1 or level 2 which is basically 120 or 240 vac respectively. Tesla's destination chargers are ACV devices, and there are conversion cables for it, and from a standard EVSE to Tesla, but you can't change DCV to ACV devices. |
91Eunos105.00 |
01-10-2022, 05:29 PM | #15 |
Rep 6
Anyone seen the new BMW Flexible Fast Charger? It seems to be dual level 1/2 with detachable plug adapters. Wondering if the Hybrid models will come with this as well or just the fully electric models.
01-10-2022, 10:10 PM | #16 |
Rep 6,911
If you want to stay with a BMW device, BMWUSA has this level 1/2 device. https://www.shopbmwusa.com/product/5...boCord-Charger.
01-11-2022, 07:46 PM | #19 |
Rep 5
As an engineer and master electrician I would highly recommend a hard wired Level 2 charger. An outlet will work initially. However, over time, oxidation will build up on both the plug prongs and the outlet's internal contacts. Combine that with being in a non-temperature stable garage and the possible exposure to road salt etc, the outlet is guaranteed to fail at some point. Very nasty things can happen when you try to pull 40+ amps through a bad connection. If the 240 VAC circuit is already in the garage it is very easy to wire in a wall mounted charger.
01-11-2022, 08:51 PM | #20 |
Rep 6,911
The units between wired and plug-in are identical, and in a worst case scenario, it wouldn't be hard to add a plug to the hard-wired version if you needed it (probably easier to add a pigtail with a plug already on it).
Installing the hard-wired unit one, the wires are run is a few minute operation to connect three wires and put the cover back on. So, unless you're planning on taking the EVSE with you on a regular basis, there's no good reason to buy it with a plug. |
01-12-2022, 04:38 AM | #21 | |
Rep 3,825
Jrg317022.00 |
