      03-04-2020, 06:19 PM   #23
VTENGR
1053
Drives: 2020 X5 M50i
Originally Posted by James_G0530d View Post
Originally Posted by VTENGR View Post
I have both and the enet cable is a lot faster at reading the ECUs vs the bluetooth adapters. If you plan on doing any coding above what Bimmercode app supports using E-sys I would get the enet cable with an adapter for your phone. For one, it's cheaper. Second, it's faster. Third, will allow you to VO or FDL code using E-sys later on if you choose to go down that path.
Is the eNET adapter you use for your phone an Ethernet to USB-C converter, assuming you're using an Android?
Yes but I have ethernet to lightning adapter since I'm on an iPhone.
      03-04-2020, 06:48 PM   #24
James_G0540i
Australia
446
Drives: 2021 X5 G05 40i M Sport
OK thnx.
From the Bimmercode site, under Android Adapters - it seems it doesn't support this setup for G series cars, only E-series cars.
Looks like I'm stuck with the OBDLinkMX++ Bluetooth adapter for now.
      03-05-2020, 04:47 AM   #25
Ninefourteener
Ninefourteener's Avatar
1346
Drives: 2020 X5 M50i, 2020 Alfa 4C
SWEET!!!! Got the car coded to automatically revert to Adaptive on startup, now that I'm using "Demo" mode..
And..... bonus feature:
Now I can lock my doors after starting my car in the morning to warm it up, without waking up the neighbors because the horn honks..... which was actually a question I posted in another thread.
Very successful day.
I'm very weary of switching to the M layout, because I keep hearing about people losing the X5M50i logo..... then switching back to the factory BMW layout.... and the logo is still missing.
Still waiting on firm clarification on that.
Otherwise.... quite happy with how this is going
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019
690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813
6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342
      03-05-2020, 06:47 AM   #26
VTENGR
1053
You do lose the M50i logo with M Layout. When I switched it back it didn't come back automatically. I had to go into expert mode and manually switch the logo back to M50i.
      03-05-2020, 01:09 PM   #27
bhe
Belgium
105
Drives: X5 G05 45e
I have a belkin usb-c ethernet adapter. when I plug it in my S10 I see an icon it has an ethernet connection.
Didn't use it yet with my e-sys cable I have from my older car because I didn't buy bimmercode app yet. No reason for the moment. I did use the cable with a laptop to disable start stop on a F11. But kind of idiot doing that on a 45e
      03-05-2020, 01:37 PM   #28
Mikli
88
Drives: G05F36F16F82E90E86E46E36E30
OBDLinkMX+ are hard to buy in Canada. Price too high! LOL
      03-05-2020, 01:47 PM   #29
jpichardo91
Drives: 2023 M3Cx / 2020 BMW x5 M50i
NineFourteener, are you using android or iOS? and are you a beta tester?
      03-05-2020, 04:59 PM   #30
Ninefourteener
1346
Android..... and yes, as of this morning I'm on Beta, which is how I was able to accomplish what I did.
Definitely worth the extra effort
      03-05-2020, 05:39 PM   #31
jpichardo91
Thanks Nine,
I am on iPhone and have emailed the developer for beta access.
      03-05-2020, 08:04 PM   #32
MaCaY
X5 M50i
MaCaY's Avatar
Are you talking ab M logo at startup. I did that and still have M50i on my cluster.
      03-05-2020, 08:08 PM   #33
VTENGR
1053
No that's different. We're talking about changing the gauge cluster layout from standard to M Performance or Alpina. When you do that you have to also change the logo in the center of the cluster. Not all logos will work with all the clusters. For the M Performance layout, the M50i logo doesn't work.
      03-06-2020, 12:01 PM   #34
Wtfitzvi
Wtfitzvi's Avatar
Drives: ...
Is the coding on the new G series linked to driver profiles?
I coded my wife's car to enable video in lotion and M start up logo and everything works fine.
Whenever I'm using the guest profile instead of hers none of the features I coded works. When we switch to her profile the VIM works immediately.
I was under the impression when the vehicle is coded it should be the same across all driver profiles.
CURRENT: 97 E36 | 15 Huracan 610-4 | 18 F80 Competition | 22 F95 Competition | 24 G80 Competition | 23 Escalade | 24 Civic Type R
      03-06-2020, 01:59 PM   #35
VTENGR
1053
That's odd - definitely shouldn't be specific to driver profiles. Do you have a profile setup? It could be something unique to the "guest" profile.
      03-06-2020, 02:08 PM   #36
Wtfitzvi
Wtfitzvi's Avatar
Drives: ...
The other profile is set up for her. It's linked to the connected drive app so it pulls the info from there.
I'm going to try and code the guest profile when my new reader and cable comes in. I'll plug the reader in first to see if the m start up and VIM is active before I code. If it's not active then the coding must be linked to specific profiles.
      03-06-2020, 02:10 PM   #37
VTENGR
1053
Why not create a profile for yourself?
      03-06-2020, 02:12 PM   #38
Wtfitzvi
Wtfitzvi's Avatar
Drives: ...
Because it's my profile lol. She's using my connected drive profile. She's doesn't want to make her own log in for the app so she uses mine and it displays all of our cars with my log in.
      03-06-2020, 04:51 PM   #39
ifr
ifr's Avatar
United Kingdom
1198
Drives: Tesla MY LR AWD
The coding for ViM should apply to the car, but you might need to deactivate the speedlock again for the additional profile using the speedlock hidden menu?
LexxM31698.50
      03-08-2020, 05:15 AM   #40
AshD
AshD's Avatar
United Kingdom
102
Drives: BMW iX 40 2022
Qq re adapter. I've got obdlink Mx that I got years ago. What is the difference between that and the MX +? Also as a complete novice do I need to get the full version of BimmerCode?
Looking to enable :
Remote start
Adaptive driving view - I think that is what it's called Where the camera will show other cars on the screen
Default to adaptive drive mode
Also is it possible to backup the whole current baseline config before I make any changes
Thanks
      03-08-2020, 07:40 AM   #41
VTENGR
1053
Looking to enable :
Remote start
Thanks
You will need the full version of bimmercode. The free version is just a demo. It doesn't actually allow you to code anything.
You can code ASS and adaptive Drive view (search forum for how), but won't be able to code Adaptive mode yet.
Can't really tell you the difference between adapters. I would strongly encourage using whatever the developer recommends.
AshD101.50
      03-08-2020, 09:18 AM   #42
James_G0540i
Australia
446
Looking to enable :
Remote start
Thanks
Are you on iPhone or Android phone?
If you're on an Android, you can definitely code Assisted Driving View (ADV) and default your driving mode to "Adaptive".
Enabling ADV requires you to go into "Expert mode" and change around 4 x parameters individually. Its not supported from the standard/base User Interface. I posted the instructions on how to do this on page 1 of this Thread - so check it out.
Driving mode default can be modified from the standard menu.
You definitely can't do Remote Start, that's more advanced because it needs your local Connected Drive system in the UK to support it via your Connected Drive App on your phone. For us in Australia, this is not available (yet...).
Also I notice you are in the U.K, what model do you have?
If you have a Diesel/30d, I've worked out how to enable Sports Plus driving mode, which is a little more aggressive over plain Sports mode which is the standard from the factory. Let me know and I can send you the instructions on how to code that.
      03-08-2020, 02:21 PM   #43
AshD
AshD's Avatar
United Kingdom
102
Looking to enable :
Remote start
Thanks
Thank you! Yes in the UK. I've got the 30d - got various options including the full camera view.
Keen to get the adaptive mode by default and the assisted driving view. Shame I can't get remote start.
I have got the Mx adapter but not the Mx+ so wondering g if that would do the job. Also will be getting bimmercode on iOS.
      03-08-2020, 04:28 PM   #44
ifr
ifr's Avatar
United Kingdom
1198
That's not the full story for Remote Start.
You can't use bimmercode due to a lack of ECU support on some of the modules that need coding, but it is possible to code Remote Start using esys.
The main issue is the need for an FSC code which can only be obtained via the BMW network. There are 3rd parties that are able to acquire these codes but the car needs to be technically ready for it. Unfortunately, based on mine and others experiences, the diesel G05's don't seem to support 1CR and associated FSC.
The system doesn't depend entirely on CD app support. I've been able to trigger the Remote Start process in the UK using the CD app, keyfob, display key, and even my apple watch. It doesn't start the engine though - it generates an error in idrive and flashes the blinkers 3 times, clicks and whirs like its about to start the engine but fails at the last second.
Those with a petrol G05 and access to the FSC should be able to retrofit remote start in any region.
AshD101.50
