09-17-2020, 02:00 PM | #199 | |
Rep 1,241
Still need to finish my Coyote mount. It fit perfectly, but then I put too many layers of epoxy resin on it to get it shiny.... and then my coyote wouldn't fit.... derp. I cracked it trying to jam it in there Fixed, and now waiting another 3 days for it to dry. Then I'll carve enough away with a dremel to get it to fit right. More to follow. I'll definitely document the sub build once I get started. |
09-18-2020, 08:38 AM | #200 |
Rep 1,241
Welp..... it works. Not my best work, definitely not my prettiest work..... but it's functional, and quite frankly, I'm kinda tired of messing with it.
I absolutely, brutally hate.... with the utmost of passions.... random "wires" hanging to various devices, plugged in to various outlets, attached to various accessories, hanging from various windshields, A/C vents, etc. Perhaps it is my OCD speaking, but I'd rather not have it at all. Coyote speed camera detection device. Worth it's weight in gold. Works FAR better than Waze, a radar detector, or anything else I've found. So how do I mount it, and wire it... PERMANENTLY in the car, so it isn't visible from the side (it's illegal in Germany), isn't obstructing an A/C vent, and is still visible from the driver's seat? You design a mount, make it out of clay, mold it into a large block of silicone, and then fill said silicone mold with black dyed epoxy resin. Mount it with double sided sticky tape, and then hardwire it into the fusebox with a voltage reducer. Again.... not the prettiest.... but it's my first time ever doing anything like this. It works. Go easy on me... lol Last edited by Ninefourteener; 09-18-2020 at 08:44 AM.. |
09-22-2020, 01:58 AM | #201 |
Rep 1,241
Soooo...... this morning was arguably, the foggiest morning I've ever come across in the 2 years I've been in Belgium. The initial plan was to just skip the rear foglight requirement, because we'd be gone before the car was ever due for an inspection...
But recently, circumstances changed, and we've decided to stay the full 5 years, and probably even extend a couple years. Which means.... I had to bite the bullet. Just spent $120 on a used headlight switch (with rear foglight button) from Bulgaria....... and a Pair of left and right rear foglight assemblies for another $250 from Latvia. Is the wiring pre-installed from the factory? No one knows. Will the switch work once everything is installed without coding? No one knows. But we will soon. More to follow.
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019 690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813 6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342 |
09-29-2020, 12:05 PM | #202 |
Rep 1,241
Custom made 3" double H-pipe, with cross sections 12" apart from one another. Resonator delete.
Happy with tone. Very rumbly and low. No crackles or pops (I hate that) Zero drone whatsoever I wish it were a "little" more volume. I didn't want "obnoxiously" loud. I just wanted "healthier". I did get a bit more volume, but not as much as I'd hoped. I definitely got the "healthier" tone I was looking for though. Overall very happy |
TomCat6065113.00 Dr. Jekyll209.50 |
09-29-2020, 12:19 PM | #203 |
Rep 1,241
09-29-2020, 02:37 PM | #205 |
Gear Head
113
Rep 303
Matt, Great work...sounds fantastic.
2021 X5 M50i, Carbon Black, Ext Coffee Merino interior, 21" Y Spoke wheels, Matte Poplar woodgrain trim. Adaptive M-Susp, DHP, Exec Package, Park Assist Plus, Driving Assist Pro, Traffic Jam Assist, Heated/Ventilated seats/armrests, Alacantara headliner, Increased speed limiter.
My wife drives a 2020 X2 M35i. |
09-29-2020, 04:45 PM | #207 |
Rep 1,241
I did. I had every intention of disassembling them and taking them to a powder coater..... only to learn that I'm in Belgium, the closest powdercoater was 2.5 hours away, and would need the calipers for a WEEK. The last calipers I had powder coated in the US were back in my hands in under 24 hours.
If this stuff doesn't work.... I'll rent a car for a week, put the X5 up on stands, and just do it. But..... so far, I must admit, I'm pretty impressed. They've withstood 135+ mph braking on the autobahn and still look great. After a ton of research, I went with the G2 system. It's not a "paint".... it's actually a dyed high-temp epoxy. It's more difficult and slow to use than paint, but the finish is phenomenal..... so long as you do the prep work properly. With a new car, it's easy. With old, rusty calipers.... they would need to be sandblasted. I wouldn't have used this stuff if that were the case. |
Dr. Jekyll209.50 |
10-07-2020, 03:39 AM | #209 |
Rep 1,241
And.... parts 2 and 3.
I really hope this works ok. I really hope the wires are re-installed from BMW I really hope I don't have to have them coded. I really hope I didn't just waste a ton of money.... lol |
10-07-2020, 05:47 AM | #210 |
Rep 1,241
I mean..... sometimes it's ok to splurge, right?
OEM F95 X5M 6-piston calipers, drilled rotors, and pads on their way from Poland |
10-07-2020, 01:34 PM | #211 |
Gear Head
113
Rep 303
You've done a lot in a short period of time!
10-09-2020, 09:13 AM | #213 |
Rep 1,241
Hey look! The sun is out in Belgium!! LOL
dananelson1226.00 NYCX5M50i63.50 |
10-09-2020, 10:25 AM | #215 |
Rep 8,815
Dayam! That looks awesome.
I almost feel like you need to redo the side stripe where the grey portion should be gold tone instead of grey to flow with the wheels/calipers. This thread reminds me of my F15 build thread. Sadly nothing is available for the F95 so mine is still bone stock at the moment which has never happened before lol. Alan
10-09-2020, 10:44 AM | #216 | ||
Rep 1,241
I did manage to pick up a set of F95 front 6-piston brakes recently. They should arrive next week, and I'm excited about installing them. And one of these days..... a reputable company will make a rear BBK that is compatible with our EPB. Still waiting though. I don't trust D2 and Ksport. |
10-09-2020, 10:58 AM | #217 |
Rep 704
10-09-2020, 11:49 AM | #218 |
Rep 1,241
10-13-2020, 11:21 AM | #219 |
Rep 1,241
If there was ever a vehicular version of "jizzing in your pants"..... this is it.
Drilled X5M rotors arrived (which are only a moderate 10mm taller, and a few mm thicker.) But...... the 6-piston X5M calipers also arrived.... which are MUCH bigger than I expected them to be. New M decals arrived today. The new gold epoxy paint should be arriving soon. Stupid excited to get these installed. I think it will make a dramatic impact to the vehicle. Oh..... and it'll likely help it stop a bit better too.... lol. Last edited by Ninefourteener; 10-13-2020 at 11:30 AM.. |
DCwell3er89.50 |
