      08-22-2023, 02:32 PM   #23
christwinzbmw
christwinzbmw's Avatar
74
Drives: BMW 2019 X5 xdrive 50i
The dragy looks awesome. How’s the connection? The app reviews look pretty bad based on that.
      08-22-2023, 02:53 PM   #24
tbolts1010
Drives: X5 M60i, Model Y
I've had 0 issues and i've had mine for a few years now.
      08-22-2023, 04:27 PM   #25
weinerbarn
Unapologetic Tool Hoarder
weinerbarn's Avatar
734
Drives: 2020 X5 M Competition
Uses Bluetooth and is super simple to use. Open the app, click connect, wait for it to find the satellites and then do some runs. The dragy is magnetic so you can stick it on the center speaker in the dash if you want. Otherwise, in the cup holder sometimes works.
      08-22-2023, 05:11 PM   #26
cobramite
1228
Drives: '24 X6 M60i, '22 Macan GTS
Draggy is a super cool piece. I know that they have been around for a while and that kind of technology still amazes me.
      08-22-2023, 05:21 PM   #27
postbox1918
postbox1918's Avatar
Drives: 2022 BMW X5 M50i
Yeah i heard good reviews about it , I'm thinking about buying it and check my cars 0-60 too
      08-22-2023, 06:54 PM   #28
cobramite
1228
Same here very soon.
Best 0-60 I've seen from the auto press testing for an X5 M50i is 3.8 seconds which is smokin for a 5,300 lb. SUV. Really fun vehicle to own.
      08-22-2023, 06:58 PM   #29
postbox1918
Wow thats great numbers, is it stock with launch control or with any Piggyback tuner + launch control?
      08-22-2023, 07:47 PM   #30
cobramite
1228
Great #s for sure and in stock form.
Here ya go:
https://g05.bimmerpost.com/forums/sh....php?t=1687329
      08-22-2023, 08:27 PM   #31
postbox1918
Here ya go:
I'll be happy to get these numbers with my carbahn tuner lol, I'm gonna order dragy
      08-23-2023, 07:30 AM   #32
cobramite
1228
+2 and that 3.8 was likely obtained under ideal conditions as they should be for a realistic evaluation of optimal acceleration.
It is luck of the draw with atmospheric conditions on test day which can make a huge difference. Density altitude(DA) plays a big role here where engine power is reduced by 3% for every 1,000 ft. Vehicle X at a 0 DA is going to generate significantly better #s than at a 5,000 ft DA when the engine is making 15% less power.
The 3.8 may also have been recorded at a drag strip where traction is optimized and far better than the street.
The reality here is that very few SUV owners are going to be doing full blown launch 0-60 runs with their X5/X6s. The 0-60 is just a popular metric used for comparitive purposes and obviously does not matter to those focused on miles/kw or mpg.
      08-23-2023, 07:40 AM   #33
postbox1918
Thanks for the info , and yes you are right those numbers must be obtained under ideal conditions, i just wanna check the numbers on my car because i never tested my car when it use to be completely stock and I'm thinking about getting the dme tune from carbahn next month so I'm gonna test it with dragy so i can see the real difference in 0-60 pre and post tune.
      08-23-2023, 08:19 AM   #34
cobramite
1228
Go for it!
This kind of stuff is sure fun to play with. Look forward to hearing your stock and tuned results.
      08-23-2023, 08:24 AM   #35
postbox1918
Go for it!
Thanks
      09-02-2023, 11:30 AM   #36
GCL-N63
GCL-N63's Avatar
24
Drives: 2022 X5 M50i & 40i
Reach out to Burger - he’ll make sure your on the right map and getting the most out of it. I use Map 2 on my 22’ M50i but in the process of going stage 2. Should be done in a week or two
      09-02-2023, 11:53 AM   #37
cobramite
1228
JB4 Map 2 on 93 oct., how do you like it?
      09-02-2023, 02:38 PM   #38
GCL-N63
GCL-N63's Avatar
24
It's solid, no issues. Started off with a Dahler pigtail and wound up setting a light after a few months. Removed then went with JB4. Been on Map 2 since. Noticeable power gains but want more now lol
Only add on top of JB4 now is the Dahler exhaust from cat back & a flap controller. Nice added sound but want more now as well.
Intake next
DME's unlock
BootMod
Turbos?
      09-03-2023, 10:15 AM   #39
cobramite
1228
Intake next
DME's unlock
BootMod
Turbos?
Sounds like a plan my friend. Go for it!
      09-22-2023, 11:04 PM   #40
christwinzbmw
74
Finally ordered a dragy. Going to try to play with it this weekend. Any tips for a quick 0-60 time?
      09-23-2023, 06:03 PM   #41
weinerbarn
weinerbarn's Avatar
734
Practice Launch Control, run the fuel tank down to about 1/4 to shed some weight. Maybe lay off on the whip cream triple latte too
      09-23-2023, 06:34 PM   #42
christwinzbmw
74
Good thing I went back to black coffee so I'm off the latte's for now!
Lose the spare tire? Guess I should also remove my 2 car seats as well.
      09-23-2023, 08:12 PM   #43
postbox1918
I also got the dragy 2 weeks ago 😆
      09-23-2023, 10:45 PM   #44
GCL-N63
GCL-N63's Avatar
24
It will wake it up but it's never going to have the feel and power band of the X5M. My M50i always felt like it started to run out of steam after the first couple of gear changes and higher rpm band. That was even with the JB4. The X5M feels like it will rev to the moon and beg for more. I'm guessing a lot of it has to do with the different manifold/downpipe configuration and turbos.
Facts even with the JB4
With a flash tune the M50i begs for more too
