06-16-2020, 03:39 PM | #1 |
Phil
41
Rep 79
Hi, can anyone with 22" alloys on factory suspension give me a measurement on all 4 wheels from the bottom of the alloy to the bottom of the wheel arch right through the centre of the wheel I start up / comfort mode on level ground. I have fitted bbm lowering links an could not get them right at all and since putting back the stock link the rear of the car is on it arse and real harsh at the rear. I have ista+ to calibrate the ride height again but don't have any standard measurements what it asks for. Any information would be great help.
06-16-2020, 04:08 PM | #2 |
Rep 182
I can't give the riding height. But did you try to lock the car and give it some minutes? Then it adjusts. I had some trouble to after changing the links and not deactivate the height adjustment or let the door so it doesn't adjust. The car lowered when both links where disconnected when I did want to adjust them a little bit. After connecting them again the car was bottomed out and I couldn't adjust with the switch.. until I locked it and waited a few minutes..
06-16-2020, 04:35 PM | #3 | |
Phil
41
Rep 79
06-17-2020, 06:23 AM | #4 | |
JoseSportM
415
Rep 371
That what I had stock. Can you read out the values you have at the moment and put here? I would like to see what values the sensor really read in different cars |
06-17-2020, 11:14 AM | #5 | ||
Phil
41
Rep 79
06-17-2020, 11:27 AM | #6 | |||
JoseSportM
415
Rep 371
The problem is this if you put 750mm an all it will not change nothing. Because that is the standard. You have to make the opposite. The standard is 750 and if you take the measure and you have 699 on the meter then you have to put 699 on ISTA it will raise till 750. Once the dimension of the meter and the read value from ISTA is the same then you have your car correctly leveled. If you want to drop 100mm later you just need to put 850mm as input value then it will drop the 100mm. I hope you could understand. |
06-17-2020, 11:32 AM | #7 | ||||
Phil
41
Rep 79
06-17-2020, 11:35 AM | #8 | |||||
JoseSportM
415
Rep 371
Once you have all around the same you can drop. But make sure the read values are also the same. |
06-17-2020, 12:03 PM | #9 | ||||||
Phil
41
Rep 79
06-17-2020, 12:06 PM | #10 | |||||||
JoseSportM
415
Rep 371
06-17-2020, 03:34 PM | #11 | ||||||||
Phil
41
Rep 79
06-17-2020, 04:19 PM | #12 | |||||||||
JoseSportM
415
Rep 371
06-17-2020, 06:05 PM | #13 |
Rep 1,248
This thread is proving to be very interesting...... and confusing.
I was getting ready to do a set of drop links as well. I had no idea it would be so complicated. I'd always assumed that after the install, the system would adjust itself accordingly. This makes me incredibly nervous. |
06-18-2020, 02:24 AM | #14 | |
Rep 148
06-18-2020, 04:23 AM | #15 | |
JoseSportM
415
Rep 371
With software you can do it easily in 5min. Both ways work good. I just don't see the reason to use links if we can do it with with ISTA. |
06-18-2020, 05:21 AM | #16 | |
Rep 1,248
So... you had no issues with the drop links at all like the OP? No problems with them getting all wonky? I'm assuming your suspension is on the lowest setting in that picture? If that is the case, I may start with: 3mm front extend 2mm rear shorten Thoughts?
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019 690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813 6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342 |
06-18-2020, 08:59 AM | #17 | |
Rep 182
I didn't had the problems like the opp. just remember. Front links are the longer ones, to lower you extend them. back links are the shorter ones and need to be shortened to lower Jack up , or disable height adjustment (keep selector switch up or down for +-11 seconds, see manual ) or open a door if you adjust them I think I have 2.5 and 1.5 at the moment, maybe a go a little bit lower but waiting for my 22" until I adjust any further. I have some foto's from the install when I did it. |
06-18-2020, 10:06 AM | #18 | |
Rep 1,248
Shorten the front to lower Extend the rear to lower. Is that correct, or do I have it backwards? |
06-18-2020, 10:23 AM | #19 |
Rep 1,077
Here is the M division interpretation of the ride height.
Have to be careful what you are trying to achieve. True performance and versatility (some off road capability) or just the looks. |
06-18-2020, 12:37 PM | #20 | ||
Rep 148
06-18-2020, 02:35 PM | #21 |
Rep 1,248
06-19-2020, 06:12 AM | #22 | |
Rep 182
Shorter ones in the back, shorten to lower. It was not clear in the translated german manual from bbm I received. I started with putting the short ones in the front and my car was not lowered at all :-) |
