10-14-2020, 08:20 PM | #1 |
Rep 121
Going up a bit on the profile, problem ?
So finding decent A/S tires for the 21" wheels that are coming on my X5 is going nowhere but if I add 5 to the profile of both the front and back (275/45 21 & 315/40 21) I get a lot more options, would this affect the car in any way other the the speedo being off a tad ? The winters here don't really call for a dedicated winter tire but I also don't want to chance it with the 3 season Pirelli's that it's coming with. Should I get the A/S in the + size or just do a dedicated Vredestein Wintrac Pro (my only option) in the OE size ?
Thanks |
10-14-2020, 09:23 PM | #2 |
12968
Rep 18,715
Possible issues,
1. Front tires rub on a full lock. 2. Transfer case damage due to oversize tire. Even if the transfer case wasn't damaged because of the oversize tire, if it has issues, BMW will point back to the oversize tires.
10-14-2020, 09:28 PM | #3 |
Rep 121
😬, guess I should go with the vredestein route
r33_RGSport12967.50 |
10-15-2020, 12:03 AM | #4 |
21
Rep 45
I was in the same predicament for the past several weeks. I just bought a winter wheel set with a square set up rather than mess with changing out tires twice a year. After 4-5 years, you'll essentially break even based on tires swaps (at a dealership), maybe. All depends on how long you think you'll keep the car...
Just another option for you to think about... https://www.shopbmwusa.com/product/6520/M-PERFORMANCE-20-INCH-STYLE-748M-BLACK-COLD-WEATHER-WHEEL---TIRE-SET |
10-15-2020, 01:28 AM | #5 |
Rep 1,241
Vrederstein makes good tires. They are made in the Netherlands, and quite popular here in Europe. I have a set myself and they are fantastic.
They are NOT Chinese tires. Nothing to be afraid of.
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019 690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813 6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342 |
10-15-2020, 01:31 AM | #6 |
Rep 121
I know their good tires, my problem with getting a winter specific set is that we don't have a lot of snow so a decent A/S tire would probably be a better choice but the size and staggered setup of these wheels leaves very few options
10-15-2020, 02:01 AM | #7 | |
Rep 1,241
Regarding going up +5 in profile: Technically, going up (or down) in profile isn't going to hurt the vehicle at all. The IMPORTANT part, is that you maintain a close overall diameter between the front and rear tires. (Your car will LOOK differently though, so be prepared for it. The visual trickery that will happen, is that your car will look like you put smaller wheels on it.) if you have a 275/40 and a 315/35 that are EXACTLY the same diameter, going up to a 275/45 and 315/40 will yield slight differences. (40% of 275 is different than 35% of 315) 0.2" inches, or 0.7% difference. Perfectly fine. Not much of a difference at all. Nothing to be concerned with with those specific tires. Our cars are rear-biased and designed to have a degree of slip. But.... again, the goal is to keep the overall rolling diameter as close to "perfectly equal" as possible. I run a 335/25 in the back, and a 295/30 in the front.... which are exactly .4" inches different fron one another, or a 1.4% difference. I'm ok with that. The difference is minor enough that it's not going to cause issues. The equivilent, would be running 10psi lower pressures in the rear. Not significant enough to worry about. I like this website, because it will not only give you differences in tires.... but it will also make suggestions for other tire sizes that are similar: https://tiresize.com/calculator/
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019 690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813 6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342 Last edited by Ninefourteener; 10-15-2020 at 02:11 AM.. |
10-15-2020, 02:04 AM | #8 | ||
Rep 121
10-15-2020, 02:16 AM | #9 |
Rep 1,241
No problem.
The other option.... is to buy a slightly used set of all-seasons in the OEM sizes. if it's only winter tires... who cares? This is EXACTLY what I did for my stock 21s. No regrets. https://www.ebay.com/itm/2-275-40-21...AAAOSwpIVednf8 https://www.ebay.com/itm/Set-of-2-Us...0AAOSwKyxfeHhj
10-15-2020, 02:21 AM | #10 | |
Rep 121
10-15-2020, 03:26 AM | #11 | |
Rep 1,241
... That includes 150mph+ bursts on the autobahn. I've had zero problems with mine. I mean... if you aren't happy with the condition, you can always return them. That was my rationale anyhow. It's just another option.
10-15-2020, 10:00 PM | #12 | |
21
Rep 45
https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm |
10-15-2020, 10:12 PM | #13 | |
21
Rep 45
https://g05.bimmerpost.com/forums/sh....php?t=1758397 |
10-16-2020, 03:09 AM | #14 | |
Rep 1,241
His 21" wheels however... now "visually" look like they are 19s
10-16-2020, 09:06 PM | #15 |
21
Rep 45
