      10-16-2020, 10:34 AM   #1
Ninefourteener
Ninefourteener's Avatar
1346
Drives: 2020 X5 M50i, 2020 Alfa 4C
F95 X5M 6-piston brake parts diagram
Does anyone have a parts diagram, or an exploded view of the 2021 X5M 6-piston front brake system? I cannot find one anywhere online.
I need to obtain a set of (4 each side) OEM front caliper bolts. I have the 6 piston calipers, drilled rotors, and (by the grace of God) I was able to obtain the necessary OEM X5M brackets to attach them to the hubs.
I don't however..... have the OEM X5M bolts;
2 long bolts (each side), that go through the top side of the caliper, into the bracket.
2 short bolts (each side), that attach the bracket to the hub, from the back side.
My OEM X5M50i caliper bolts "might" be the same bolts as the latter (My calipers attach from the back, directly to the hub)..... but I don't want to risk it. I'd rather be 100% certain I have the correct bolts.
I "could" get a set of bolts from the F85 X5M older version (those are easily available).... but I know for a FACT that the brackets are slightly different. The calipers are slightly different too, and there's a significant chance the bolts may be slightly different too. The G05 and F95 are so new, there's so little info online about them.
There is a SIGNIFICANT language barrier when I go to the local BMW dealer, and considering the "unusual" nature of this mod, I'd rather have the specific part numbers with me.... or at LEAST an appropriate picture/diagram so I can point to what I need.
Can anyone help please?
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019
690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813
6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342
      10-18-2020, 03:28 AM   #2
Ninefourteener
1346
Bump???
      10-21-2020, 07:21 PM   #3
CaboM4
BMW Aficionado
1362
Drives: 23 i7,23 iX,24 Silverado
no part # ... only a photo
      10-23-2020, 07:11 PM   #4
Ninefourteener
1346
Thank you. Actually, those two bolts will be re-used, as they are the same bolts that attach the M50i 4-piston caliper directly to the hub.
The bolts I needed, were the round ones that go through the top of the caliper, and attach it to the bracket....... which then attaches.to the hub.
I've since located a set, and they are on their way to me. I'll be doing a full write up for an X5M 6-piston BBK retrofit onto a GO5 very shortly
Ironically.... the bolts I needed..... they don't have part numbers either
