      03-16-2019, 10:25 AM   #23
AndroidRobot
AndroidRobot's Avatar
  [0.00]
Originally Posted by salfeet84 View Post
Originally Posted by IND-Distribution View Post
Originally Posted by ssadri View Post
I'm waiting on the factory #668 Jet Black or Gloss Black M caps to be released!
We have the factory ones painted in Gloss Black (668)
https://ind-distribution.com/product?sku=IND-G05-MC
[img]https://farm1.staticflickr.com/794/3...9d059e6d_b.jpg[/img]
Do u have some installation instructions for these? I would be interested in getting if easy to do myself without having to drive to dealership
It is the same steps as F15/F16 X5/X6 or F85/F86 X5M/X6M.
You can search in that subforum.
Thanks, I went ahead and ordered them...will install next week when here and update u guys
So you bought the normal mirror caps but in black?
      03-16-2019, 10:28 AM   #24
salfeet84
Drives: 2024 X7 M60i
Yes, I had mine wrapped in dark carbon fiber wrap by my local guy when he did my xpel fron hood and bumper but due to the small size of the mirrors it keeps peeling and I didn't like how everything is black on the trim except mirrors so I got the black ones yesterday...
      03-16-2019, 10:29 AM   #25
AndroidRobot
  [0.00]
Makes sense. I'm going to try the M mirror caps from the F85 X5M and see how it plays out. That guy in Russia said they're a drop in fit but who knows the winged mirror caps should make aero noise a little better too
      03-16-2019, 10:32 AM   #26
salfeet84
Those would look awesome, I had them on my old F85, let us know if they actually fit plz
      03-16-2019, 10:33 AM   #27
AndroidRobot
  [0.00]
Will do, I'm probably getting the Autotechnik ones since they make good quality parts in CF and don't gouge you like the OEM BMW ones
r33_RGSport12971.00
      03-16-2019, 10:36 AM   #28
salfeet84
Looked them up, they're still pretty expensive...
https://autotecknic.com/products/aut...6m-atk-bm-0144
      03-16-2019, 10:50 AM   #29
AndroidRobot
  [0.00]
that's the old gen, dry CF ones are still $500 but that's better than $800 for OEM BMW ones. Id rather have gloss black to match the trim but CF will work
salfeet84309.00
      03-16-2019, 10:53 AM   #30
salfeet84
I saw the IND ones were $800 something, I agree that's way too much
      03-16-2019, 11:00 AM   #31
AndroidRobot
  [0.00]
IND over charges for many things. They don't like me because I bluntly stated that a few times I still bought $1200+ worth or parts from them for my X5.
edit: I might need the whole mirror housing too depending on which one I buy. I'm still checking into things before ordering
Appreciate 3
      03-19-2019, 05:03 PM   #32
salfeet84
Can you take a few install pics for forum reference??
So I got my gloss black mirror caps and installed them today, pretty easy process as described in the video on this sub forum
1) Tilt mirror up all the way then use your wide prying tool to lift up till you start hearing some clicks and start feeling mirror is loose on bottom
2) I tilted the mirror down (using car controls) then applied a small amount of prying pressure from above and viola mirror is not attached to ring anymore
3) one difference between video is the G05 mirror is attached with 3 cables rather than 2 (as in video), 2 cables for electronics I guess and the third for the blind spot monitoring sensor on mirror. I didn't have to detach any cables to remove the mirror cap
4) the G05 mirror cap has 2 clips attaching it to the base, so I used two prying tools, one to push one of the inside clips to the side while using the other prying tool to apply pressure from the outside of the mirror cap, then did the same thing with the other clip and mirror cap just detaches while applying pressure on the second clip step.
5) I had to apply light prying pressure on the side and bottom of the mirror cap to get it to fully detach in a careful way, luckily none of the clips on either mirror cap broke.
6) attaching painted mirror caps was super easy and self explanatory, just align clips and apply pressure till you hear all the clicks and looks flush
7) final step is putting the mirror back in place, which is just applying pressure till you hear the clicks on the ring and mirror can move freely using car controls without any creaks or squeaking.
mhodx5111.50
Frenetic482.00
      03-19-2019, 05:07 PM   #33
salfeet84
Pics from mirror cap installation
LexxM31698.50
Frenetic482.00
      03-21-2019, 01:16 AM   #34
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
The F15/F16 and G03/G04/G05 side mirror looks similar. But the locking clips and tabs are not the same.
Not sure if you change the whole housing, I didn't got a chance to try it.
But AutoTecknic's for G03/G04/G05/G07 in Dry Carbon is coming soon.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      08-14-2019, 05:17 PM   #35
bizfiend
bizfiend's Avatar
146
Drives: Renting Corolla lol
Does anyone know if the mirror size is the same for 2019 X3, X4, and X5. Thanks.
      10-12-2019, 02:38 AM   #36
Ninefourteener
Ninefourteener's Avatar
1346
Drives: 2020 X5 M50i, 2020 Alfa 4C
I just spoke with Auto Technik last night on messenger.
The G05 mirror covers are NOT the same as the F85.
They plan to launch G05 carbon mirror covers next month.
      10-23-2019, 09:41 AM   #37
r33_RGSport
I have tested their prototype.
Everything seems to be good. Just minor detail.
It should be ready pretty soon.
joestl1.50
      11-05-2019, 03:34 AM   #38
Ninefourteener
1346
I am waiting..... patiently. I follow Autotechnic of FB, and check their website periodically. My car arrives in late January..... so if they don't release something by the end of December, I'll likely just buy the M Performance carbon mirrors, because I definitely want them "on hand" and ready to install the day I pick up my car.
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019
690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813
6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342
      11-05-2019, 07:13 AM   #39
r33_RGSport
Should be ready by then.
I'll check when I see them at SEMA. The should be releasing some new items.
      12-01-2019, 08:26 AM   #40
Ninefourteener
1346
Sooooo..... what's the deal with the Autotechnik carbon mirrors for the G05???
      12-03-2019, 11:24 PM   #41
r33_RGSport
Not yet.
Playing catch up with BMW releasing car every month, lol.
      12-05-2019, 09:48 PM   #42
r33_RGSport
It is finally here!!!
PM me for pricing. It is just released, so it is not on my website yet.
      01-01-2020, 06:11 PM   #43
atlas
Australia
383
Drives: F10 535i, M2 LCI, G05 X5 40i
What side decal is that on the side of the car? Looks great!
      01-01-2020, 06:32 PM   #44
Auricom
Auricom's Avatar
Drives: 2020 X5 xDrive40i M Sport
That? It's the X7 "hockey stick" in M Sport shadowline trim and not a decal. On the X7 xLine, it's chrome for that luxurious look.
