06-19-2014, 05:58 PM | #1 |
Rep 136
Brake wear
Had new pads and disks replaced all round on my 125i manual after 65k km. A bit surprised, since I'm very light on brakes by using gears for virtually all stopping. The mechanic at BMTS here in Brisbane said that BMW OEM disks are pretty soft, presumably to ensure good stopping performance. Had them replaced with after-market disks of German origin, plus ceramic pads. After a couple of weeks city driving, I'm quite happy with the performance. Nice progressive feel, no grabbing, and the wheels seem to be much cleaner (presumably since the ceramics use copper instead of iron as the heat conductive medium). Hopefully they last longer than the originals.
Another thing I have noticed is that the after-market disks don't seem to rust so much when I wash the car. With the OEM disks, a rust film would form rapidly. That would indicate a different steel alloy, I suppose. |
06-19-2014, 10:29 PM | #2 |
Rep 3,099
BMTS told me at 100,000km i wouldn't make another 5,000km - i drive the same as you do, engine brake mainly.
i made another 30,000km and still had a couple mm of pads.. loads left on the rotors. i wouldn't necessarily trust what they say about brakes. |
06-20-2014, 05:14 PM | #3 |
Rep 1,448
Drives: M2
I just had a service down at a local dealer, said my 2 front discs and pads need replacing. I've just done 59xxx km.
They just said it was "low" but weren't able to give me a figure on it. Anyway, they want to charge me $449 for the pads, and $351 for the rotors fitted. What sort of price did you guys pay, and how do i measure how much you have left on the rotors and pads? |
06-20-2014, 08:20 PM | #4 | |
Rep 3,099
Pads you can look at how much is left before its just backing plate If theres enough left (rotors should last at least 2 sets of pads)... Parts alone: Pads from USA for like $100-$150, rotors are not much more. And a garage should take no more than an hour at it |
06-21-2014, 07:24 AM | #5 |
Rep 809
06-21-2014, 07:41 AM | #6 | |
Rep 809
Yes you're correct in assuming the chemical composition of the rotors are different from oem, a high Fe content in the oem rotors is what causes them to corrode whilst this isn't aesthetically pleasing the higher Fe content is great for pedal feel & iron rotor has a higher rate of friction and improved thermal resistance (less likely to warp) |
06-21-2014, 07:56 AM | #7 | ||
Rep 3,099
it's almost impossible for a rotor to warp, and you don't want a rotor to be resistant to heat, iron is actually better at absorbing heat, hence they make good rotors.. absorbing the friction of the pads quickly! i'm not entirely aware of any rotor being not cast iron, unless they're ceramic/carbon ceramic or something? Even brembos are simply high quality cast iron. Last edited by flinchy; 06-22-2014 at 06:23 PM.. |
06-22-2014, 04:53 AM | #8 | |
Rep 809
06-22-2014, 06:18 PM | #9 |
Rep 3,099
haha, no not drunk
hold on i'll proof-read it .. yeah i had trouble explaining it, and i can't find the pic i found in the first place. Just disregard it. It worked for me when comparing my used ones to the new ones is all. either way, unless you want to spend $50 on a micrometer just to make sure you can get another pad change out of the rotor... if you think it's getting low, just spend the not-all-too-much money it costs to replace them. Last edited by flinchy; 06-22-2014 at 06:23 PM.. |
06-22-2014, 07:00 PM | #10 |
Rep 136
A little disturbed about BMTS, Flinchy, however, we're moving interstate (driving down to NSW) and I will require a roadworthy within a few months prior to re-registration. I didn't want any issues with the car, as I'll be busy enough getting our house sorted out down there. The mechanic told me at my last yearly service that the rears would need replacing at the next service. He reported at this year's service that the front rotors looked pretty chewed, and it might be a near thing if they were still thick enough after re-facing.
Thanks for your comments, drjekyl. You reminded me that I know nothing of brake rotor composition. This article gave me a quick tutorial: http://www.sae.org/events/bce/tutorial-ihm.pdf It seems that all commonly available rotors are fabricated from "gray" (cast) iron, with varying carbon contents and processing conditions strongly influencing the range of properties considered desirable. Rusting appears to be dependent on the microstructure and chemical composition of the rotor. BMW appears to specify a material which gives it the range of properties it considers most desirable. |
06-23-2014, 04:47 AM | #11 | |
Rep 809
Hmm I disagree!!!
You can buy a set of 0-25mm mic's for $10, whereas rotors are a few hundred each for some decent quality rotors. |
06-23-2014, 04:52 AM | #12 |
Rep 1,448
Drives: M2
So how much have you guys previously paid to replace the front rotors and pads on a 125i?
06-23-2014, 05:01 AM | #13 | |
Rep 809
That article is a fairly in depth insight in basic metallurgy and would take some time to understand the phase transformations, terms and terminology!! |
06-23-2014, 05:28 PM | #14 | |
Rep 3,099
stoptech disagrees with your disagreement! :P - Even if you got it glowing then doused it in a few liters of water.. MAYBE then? or you might have a rotor that's already out of spec from factory (too much runout say) that's installed, used, and then goes further out of spec with uneven wear. And yeah fair enough, mettalurgy is one of the most complicated areas i've ever encountered, so many different alloys/compositions/states of any given material, that may as well be entirely unrelated. wait, $10? where from, i tried having a look and could only find 50mm for $50 as the cheapest. I'd love to grab a set for $10! Last edited by flinchy; 06-23-2014 at 05:34 PM.. |
06-23-2014, 06:54 PM | #15 | |
Rep 809
Whilst I would much rather my mitutoyo mics, these would be perfectly fine to measure brake rotors with. |
06-23-2014, 09:58 PM | #17 | |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
That only measures up to 25mm. My stoptech rotors started as 32mm thick, and after a fair amount of abuse are now 31.5mm thick with lots of heat checking. Apparently they are good until 30mm but will be replaced before then if the heat checking turns into cracking. |
06-23-2014, 10:46 PM | #18 | |
Rep 809
06-24-2014, 07:32 PM | #19 | |
Rep 780
How much if u don't mind me asking? I just change akebono ceramic pad with EBC disc on a 530d for $1500 so curious to see how much u paid.
2020 BMW G07 X7 3.0d M Sport
2018 Audi FY Audi SQ5 2016 BMW F36 440i GC M Sport |
06-25-2014, 07:33 AM | #20 |
Rep 136
I'll have to ask about the brands, but the total cost for new rotors and ceramic pads was around $1500. I'll report back when I get the information.
