M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Engine, Exhaust, Drivetrain Modifications
      06-24-2014, 08:41 AM   #1
RajG
Drives: '14 M5 CP
Delete resonators on CP exhaust?
I'm considering a low cost mod to the stock CP exhaust setup to get a little more growl. I already have the Exhaust Meister. Do you guys recommend removing the resonators as the next step? My understanding is that an exhaust shop can remove the resonators and put them back on rather easily if there's a ton of drone or if it's too loud. Any insight would be appreciated.
Raj
Current Stable
?19 M5 CP
?19 X6M
      06-24-2014, 08:52 AM   #2
scottiekay
Drives: BMW 2013 M5
pretty sure there was a post that noted there was excessive drone. maybe someone can confirm.
      06-25-2014, 07:16 AM   #3
Spinny02
Spinny02's Avatar
Drives: '14 M5 CP Dinan Stage 2
No drone and sounds great. This is what I am running.
      06-25-2014, 07:50 AM   #4
RajG
Drives: '14 M5 CP
Nice. Do you remember what the labor charge was? I would think it's a straight forward job for an experienced muffler shop.
Raj
Current Stable
?19 M5 CP
?19 X6M
      06-25-2014, 08:31 AM   #5
Spinny02
Spinny02's Avatar
I received the Eisenmann center pipes from stealth pilot and had them installed. Cost was only a few hundred. I would assume cutting the res out and replacing the small section with like ss pipe should be about the same price. You just need to find a shop who can tig weld on stainless.
      06-25-2014, 08:52 AM   #6
akh23456
All I do is Win... Eat Race Sleep
akh23456's Avatar
Drives: 2018 Range 2011 M3 2019 600lt
You should check out Undercover Performance in South Jersey they did a full custom exhaust for me.They can deff do this for you.... You can check out the quality here http://f10.m5post.com/forums/showthread.php?t=962461
Rs7 : 10.4 133.50 with a 1.7 60ft Toyo R888
F10 M5: 11.308 131.96 with a 1.9 60ft Street Tires
E90 M3: 11.2 126.7 with a 1.8 60ft Street Tires
m5post
