      06-30-2014, 09:35 AM   #1
froop
froop's Avatar
Australia
171
Drives: 08 AW 6MT E82
VAC Oil Pan Baffle
Is anyone else interested in a VAC N54 oil pan baffle? I'm looking at one because I do a lot of tracking. Maybe if we get enough peeps we can try do a group buy or at least share on shipping.
http://store.vacmotorsports.com/vac-...n54-p1435.aspx
      06-30-2014, 05:08 PM   #2
froop
froop's Avatar
Australia
171
Originally Posted by Ian///M
Perhaps. Oil starvation an issue on N54 at high G? What would install involve though?
I think it can be an issue on any motor depending on lateral g forces (track, grip etc) but it's cheapish insurance. I believe the install is relatively straight forward however it does require some welding. Basically drop the oil, drop the sump pan, weld in the baffle, change the gasket (I'm assuming) and reinstall.
      06-30-2014, 05:39 PM   #3
Kiwi Peter
Kiwi Peter's Avatar
New Zealand
162
Drives: E92 M3 2012 Edition 500
I think if you were on slicks and doing 62sec or 63sec at wakefield it would be worthwhile other wise don't bother.
The sump / oil pan is not to bad on this engine the pick up sits low in the sump, also the sump design does help to retain oil around the pick up.
If you are concerned, add another 500mil of oil or do it correctly and fit a oil accumulator along with twin oil coolers and large radiator.
In saying that, it still wouldn't do any harm.
      06-30-2014, 06:19 PM   #4
flinchy
Drives: E82 135i
i was thinking about it since it's all out already and 'i can'
so if better pricing or at least shipping could be had, count me in.
i haven't seen many, but there's been SOME videos of limp mode coming on around some sweeping right hand bends.
how does that help? (accumulator)
http://www.accusump.com/accusump_tech.html
well that sounds pretty damn cool, another 'relatively cheap insurance' thing. ($500 odd including electric valve?)
      06-30-2014, 06:32 PM   #5
drjekl
Drives: E92 335i
*Serious question* how's your build coming along flinchy?
      11-11-2014, 02:46 PM   #6
atv12
atv12's Avatar
Russian Federation
14
Drives: ///1M Coupe
if you guys are really tracking a lot and are running slicks - then oil pan baffles are really worth being installed! i had oil starvation on left hand bends with high lateral g force and the connecting rod bearings (between rods and crankshaft) cranked.
i put oil pan baffles and oil pressure gauge and waiting to the next track season. hope it will help.. if not - then oil accu has to be installed, but there is lack of space to set it..
also a major problem is to cool th n54 engine - additive larger oil cooler doesn't solve the problem - a large water radiator needs to be set instead of the oem one.
has anyone already been done with that on everyday car leaving air conditioner on its place?
The speed ​​is secondary, do not aim for it. You first need to learn the car and the track, and then they will introduce the speed to you.
      11-11-2014, 05:39 PM   #7
PeteA
PeteA's Avatar
Australia
127
Drives: E30, E82
I have one froop. Send me a whatsapp I have pictures. Works for E8/9x N55 as well for those who are interested.
1addicts
