07-01-2014, 09:50 AM | #1 |
88
Rep 380
FYI BMW M4 H&R Springs have been released
Just saw on their website. Available.
The price is so good. I'll give it a try before the JRZ is available. I'll post some photos after install next week or so. Find By Vehicle Find By Make BMW M4 Coupe F32(2015-up) Suspension Stage Notes Approx. Front Lowering Approx. Rear Lowering Part Number Sug. Retail Sport Spring incl. Adaptive M Suspension 1.2 1.3 28877-2 $389.00 Kit H&R Special Springs, LP makes every effort to ensure that you are provided with the most accurate and up-to-date pricing and technical information. However, H&R is not responsible for typographical errors, pricing irregularities, or incorrect pricing. Prices subject to change. Photos are representations of product. May vary between actual products. All technical information found in the H&R Application Guide is approximate and may vary upon application. Additional suspension components may be needed in some applications, depending upon the make, model, engine and chassis of the vehicle. H&R is not responsible for any consequences resulting from manufacturer's technical mid-year changes. ©2014 H&R Special Springs, LP. :: Toll Free (888) 827-8881All rights reserved. Terms and Conditions of Use. |
07-01-2014, 09:57 AM | #2 |
Rep 3,262
So they are the same as the 435i Super Sport Spring
2022 BSM/FR M4 Competition X-Drive 2017 MW/SO M4 ZCP [SOLD] • 2015 MW/SO M4 M-DCT FBO [SOLD] • 2011 AW/CR 335is DCT FBO [SOLD] • 2008 AW/CR 335i 6MT FBO [SOLD] |
07-01-2014, 11:42 AM | #3 |
BimmerPost Supporting Vendor
9587
Rep 10,878
Correct- H&R lists the same part number for the 435i and the M4. Their argument is that the more softly sprung 435i sees a large increase in spring rate, and so H&R lists this as a "super sport" application for the 435i, but only a "sport" for the M4.
In my view this is far from ideal, but I do have immediate access to the H&R 435i/M4 springs if any clients are interested in purchasing some as a temporary solution.
07-01-2014, 11:52 AM | #4 |
Rep 949
FYI, i have this exact model number on my F80 and the rear is too low in my opinion.
talked to KW today and they are 6-8 weeks out. so for a temp fix, id suggest the F30 sport, not super sports. |
07-01-2014, 12:00 PM | #5 | |
9587
Rep 10,878
In any case, these springs were not designed around the F80/F82 damper or OE spring rate. They are inexpensive, however, so I suspect many will install them to get by for now.
07-01-2014, 12:08 PM | #6 |
10816
Rep 27,599
I plan on installing them for now till better options come available but before I do I would like to see a few more M4's on the set up which should be happening rather soon
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
07-01-2014, 12:21 PM | #7 | |
Rep 3,262
I don't want to sacrifice ride quality especially on an M for the sake of looking "slammed"
07-01-2014, 12:24 PM | #8 |
10816
Rep 27,599
^^exactly but at the same time my SUV look is killing me everyday I look at my car lol.
07-01-2014, 01:48 PM | #10 | |
Rep 3,051
2022 RAM TRX
2021 Ford Bronco 2022 BMW M3 |
07-01-2014, 03:08 PM | #11 |
Rep 496
Drives: 2015 BMW M4 (transporting)
They have to allow for chains to be added to the tires. If you don't need that BS, lower the car a little. What geometry? You've mentioned this before with no source of information.
07-01-2014, 03:14 PM | #12 |
Rep 549
I'm not sure that the suspension will work right with this springs. It is just for better looking, not for the better performance.
F80 M3 SO/SO |BM3 St.1 91 oct.|Cattless DPs|Tractive P'n'P|Brembo 6pot|Rays G25 with CUP2 tires|GTS coding|
1M VO FBO (KW DDC) PTF st.2+ sold e90 335i FBO jb4 sold |
07-01-2014, 04:29 PM | #13 |
JOSH SHOKRI.
524
Rep 5,881
Drives: 991 GT3RS, 964, Raptor
Current: 16 991 GT3RS , 91 964 C2, 17 Raptor | Past: 2015 991 GT3, 2015 i3,15 YMB F80 M3, 13 E92 M3 DCT, 08 E92 M3 6MT, 07 E60 M5, 02 E46 M3
Instagram: @josh_speeddistrict #SpeedDistrict @SpeedDistrict |
07-01-2014, 05:22 PM | #14 | |
Rep 495
http://trackdaytuners.com/tuner-cent...ng-your-vw-gti |
07-01-2014, 05:27 PM | #15 | |
Rep 2,991
07-01-2014, 07:01 PM | #16 | |
Rep 495
The problem is that these geometry changes are hard to compensate for with alignment work. Typically to get it as close as possible to factory spec when static, you need adjustable control arms, ball joints etc. To get it back to spec under dynamic conditions, now you're talking about different wheel hub carriers (with lowering spindles) or different ball joints with longer studs in the lower control arms, and/or ball joints with longer housings if mounted in the hub carrier. Lowered suspension also exaggerates (or created) bump-steer - a situation where compressing the suspension can result in the unwanted steering input. To compensate for this, you need to consider new steering arms with relocated positions for the ball joints and tie rods. Sometimes this can be compensated for by winding the tie rods in more tightly to shorten them, but not always. So yes, if you lower your car, you must consider all the factors from realignment (for McPherson systems, to full replacement components on multi-link or dual wishbone types. |
07-01-2014, 07:20 PM | #17 | |
Rep 496
07-01-2014, 07:33 PM | #18 |
564
Rep 1,983
Meh, I think I will leave suspension alone for now.
I may consider swapping it out with competition spring whenever it comes out. |
07-01-2014, 10:29 PM | #19 |
Law Enforcer
25100
Rep 22,288
Drives: '22 Chalk Gray Porsche C2S
Because we like our street cars to look a certain way. The "geometry" is fine for a boulevard machine. The daily commute isn't a time attack.
07-01-2014, 10:37 PM | #20 |
88
Rep 380
07-02-2014, 07:58 AM | #22 | |
Rep 949
Sedan_Clan, you get it! thanks. I have regular sports coming in tomorrow so that i can raise it a tad. Personally i dont like the look right now. I have the regular suspension, not active. the ride is a tad rough, but it handles just fine. |
