07-06-2014, 07:39 AM | #1 |
Rep 201
Intakes for better sound?
After seeing Fog's insanely beautiful CF intake and the talk of better sound in the cabin, I was wondering if folks could weigh in on a more economical way to get a better cabin sound with an intake.
I don't see a lot of intake threads on this forum. Are people not doing intakes? Or if so, what is popular? thanks! |
07-06-2014, 09:42 AM | #3 |
24
Rep 368
Drives: E92 M3
I simply have a drop-in filter from BCM......and that simply does the trick! However, I do think about picking up the Dinan CF intake from time to time however, I wonder if there's truly any benefit over a simple drop-in filter for the factory air box is very well made.
2009 E92 M3 DCT: BPM tune + DCT tune & Servotronic | Velos Solo VII 19x 8.5, 19x11 | Michelin Pilot Super Sport 255/35/19 front 295/30/19 rear | M Performance Exhaust | BCM Air Intake Filter
07-06-2014, 09:43 AM | #4 |
Rep 542
I think OP is asking abt a plenum airbox mod. I'm all ears, too...
* '11 E71 X6 M MCB
* '16 Z51 M7 C7 Corvette--SCCA Solo/DE Weapon * '90 Corvette ZR-1 (Fast) |
07-06-2014, 09:59 AM | #5 |
Rep 3,633
Well I have had both drop in filters and a full intake replacement and the sound is much much different running the full replacement. Also that other thread with the technocracy junk..... I can't see how the plenum cover would add any noise at all as it's just a cover for aesthetic purposes only.
07-06-2014, 10:44 AM | #6 | |
Rep 816
07-06-2014, 11:31 AM | #7 | |
Rep 3,731
Drives: 2018 M2
07-06-2014, 12:12 PM | #8 | |
Rep 201
Way back in the day, when I was a Mustang Cobra guy, I would drop in a K&N and notice a bit more intake sound and throttle response. Wondering if the same is true for Ms and if I should go drop in or more. Thanks for the responses so far! |
07-06-2014, 12:24 PM | #9 |
Rep 2,400
The Dinan or Macht Schnell elbows with filters will help improve sound fairly dramatically (I've had both). Think Dinan also now sells just the intake elbow without the filter, so you can keep the stock filter or bolt on the AA filter as keeps the stock charge pipe whereas the more expensive Dinan intake includes elbow, charge pipe and filter (K&N).
http://dinancars.com/product/d760-00...ries&mid=1113/ http://dinancars.com/product/d760-00...ries&mid=1113/ Also, for a cheap way to potentially increase engine/cockpit noise, maybe try these out: http://www.m3post.com/forums/showthread.php?t=932472 I was thinking of getting the BMS filters and seeing if the Technocraft CF cowl covers would fit properly so that adds more sound. Otherwise, can install the BMS filters and get rid of the cowl and see if sound is improved. Would be much cheaper way than getting a CF covered plenum (thx for the compliments btw ). |
07-06-2014, 12:27 PM | #10 |
Rep 2,400
This thread was the source of my "inspiration":
http://www.m3post.com/forums/showthread.php?t=886565 |
07-06-2014, 01:37 PM | #11 |
Admiral
933
Rep 3,886
My Dinan CF Intake makes nice sounds.
The OEM box is already so well engineered, there's hardly reason to spend money on something else.
2020 FORD RAPTOR 2014 F15 X5 | M-SPORT SOLD 2011 SG E90 M3 | 2008 AW E90 M3 | 2004 E46 M3 |
07-06-2014, 01:38 PM | #12 | |
101
Rep 701
On this car, intake mods are more cosmetic than performance. You can't really improve significantly on what the car came with from the factory |
07-06-2014, 01:58 PM | #13 |
Rep 2,400
Agree, though I think the OP was seeking sound enhancement, which various intake components will definitely accomplish.
07-06-2014, 04:04 PM | #14 |
Advansolosis
218
Rep 1,448
I have the AFE full replacement intake, it's inexpensive and works like a charm. If you get cowl filter deletes you will get better "cabin" noise.
2011 E90 M3, ESS VT2-650, 2015 GL550 |
07-06-2014, 10:02 PM | #15 | |
BimmerPost Supporting Vendor
3387
Rep 7,542
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
07-06-2014, 10:27 PM | #16 |
Newbie
Rep 143
07-08-2014, 04:13 AM | #17 |
Rep 478
With Dinan or MS, you don't soon forget about the intake noise after a few weeks of driving.
Only Full CF plenum will remind you of the 8 ITB singing at full song. Goke Intake is ok but for few thousand euros, you are only getting the top half plenum in CF. The bottom half is OEM. |
07-08-2014, 05:53 AM | #19 |
31
Rep 496
Interesting if you click those links it says the elbow only is cosmetic only and adds zero performance. Which then you click on the elbow and filter and realize the only thing that is adding power is the drop in filter as that's the only difference! Quite interesting they even recognize the 800 dollar part is cosmetic only and the 100 dollar filter adds the 5 hp
[ QUOTE=FogCityM3;16243881]The Dinan or Macht Schnell elbows with filters will help improve sound fairly dramatically (I've had both). Think Dinan also now sells just the intake elbow without the filter, so you can keep the stock filter or bolt on the AA filter as keeps the stock charge pipe whereas the more expensive Dinan intake includes elbow, charge pipe and filter (K&N). http://dinancars.com/product/d760-00...ries&mid=1113/ http://dinancars.com/product/d760-00...ries&mid=1113/ Also, for a cheap way to potentially increase engine/cockpit noise, maybe try these out: http://www.m3post.com/forums/showthread.php?t=932472 I was thinking of getting the BMS filters and seeing if the Technocraft CF cowl covers would fit properly so that adds more sound. Otherwise, can install the BMS filters and get rid of the cowl and see if sound is improved. Would be much cheaper way than getting a CF covered plenum (thx for the compliments btw ).[/QUOTE] |
07-09-2014, 12:00 AM | #20 | |
Rep 2,400
Inner charge pipe is also different with the intake kit vs elbow cosmetic piece (which uses the stock inner charge pipe). It comes down to whether you believe Dinan and their dyno testing or not. He explained in a video that the inner charge pipe change alone added 5+ bhp to the M5, which is interesting. At any rate, elbow completely worth it IMO for the sound alone (same with the MS piece,) which is why I suggested that if you want to save a couple hundred bucks, get the Dinan elbow piece (not the intake) and add the AA green filter with your stock charge pipe and get what you believe to be the same HP gain, but significant increase in intake sound, which is what this thread seems to be about.
07-09-2014, 12:14 AM | #21 | |
Rep 2,400
Yup, exactly...you are being charged for the "core" part that Goke (or the 2-3 other guys that do it) uses which is like 700 EUR. Ideally would be nice to send in your own plenum and have them fuse it (it only takes 5 days), but no one I know offers this service. Also, don't know of anyone who has made a full CF intake for the S65 (incl trumpets)..only seen them for the S54.
07-09-2014, 01:11 AM | #22 | |
Rep 478
Motorsport24 does at 4450 euros. http://www.motorsport24.de/motorspor...ort::2054.html I love intake sound but don't love them enough to part 4450 euros for it. Had it been closer to 2000-2500 euros I can still consider. There is no doubt this airbox will sound wicked at WOT. Then of course there is this: http://www.motorsport24.de/motorspor...ace::1546.html Quite a bit of ancillaries will have to be relocated to make this work. |
