M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Engine, Exhaust, Drivetrain Modifications
      08-21-2014, 08:35 PM   #1
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
BMS Removal?
Who removes their BMS before taking in to be serviced?
How long does it take you to remove?
Who leaves it in? If so, has the dealer ever said anything about it?
Considering adding the BMS, but the M is my daily and not super interested in getting too 'involved' with having to spend time working on it just to take it in for service.
Build: '14 M5 - Space Gray / Full Sakhir Orange / Alum Trace / Black 343's / Exec / Driver Assist / LED
Mods: SunTek CXP tint - Vinyl-wrapped door handle chrome - Macht Schnell 12mm spacers - Pedalhaus pedals - iND Cosmetic Package - Polished 90mm exh tips - Coded by v12 - 21" HRE S107's polished lip/black center
      08-21-2014, 09:57 PM   #2
boots
Curve Thrasher
boots's Avatar
623
Drives: 2013 Bmw m5..White/Blk.
I leave mine in. No problems.
      08-21-2014, 10:31 PM   #3
znammzM6
Drives: 2014 SG M6
I also leave my, dealer didn't say anything. I'm in in WA.
      08-21-2014, 10:48 PM   #4
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
Nice...
I wonder what the dealer would do if they found it...? Would they void your warranty no questions asked?
      08-21-2014, 10:51 PM   #5
David 12
David 12's Avatar
127
Drives: 2019 BMW X5 50i BSM, M Sport
When I had a JB3 in my 335i, standard operating procedure was to remove the tune prior to any service. If the tune is discovered, the dealer can easily flag your car and while everything may seem fine, your warranty on a potentially related item such as an engine or turbocharger would be lost or voided if there was damage. Mind you, this is also very dealer specific as some are more tune friendly than others, although BMWNA may get involved and have the final say. The problem was made worse by some dealers voiding almost any part of the car because of the tune, which is supposedly illegal under the Magnuson-Moss Act.
When we approached the our local service advisor, he said in no uncertain terms that a piggyback or flash tuner will void the warranty on anything related to the tune.
I think most people that leave their tune in realize this and have no problem potentially paying for a new engine, turbo, etc. if there is an issue.
That said, other folks feel that it is safer to remove the tune and avoid having your car flagged by BMW.
It may be worth asking the local dealer or owners of tuned BMW's in your area before you tune your M5.
Dave
      08-22-2014, 07:13 AM   #6
akh23456
All I do is Win... Eat Race Sleep
akh23456's Avatar
Drives: 2018 Range 2011 M3 2019 600lt
Phil what dealership do you use jun the philly area? I have used Mt. Laurel Bmw and they are very mod friendly. I have left my JB plugged in and my SA doesn't say anything. If you use Mt laurel go to James D. the best guy in service and he will take care of you.
Rs7 : 10.4 133.50 with a 1.7 60ft Toyo R888
F10 M5: 11.308 131.96 with a 1.9 60ft Street Tires
E90 M3: 11.2 126.7 with a 1.8 60ft Street Tires
      08-22-2014, 08:39 AM   #7
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
Thanks! I actually go to BMW of Devon as they are close to home and have proven to be a good service shop.
I'm going to see about talking to one of their SA's about how 'mod-friendly' they are.
      08-22-2014, 03:17 PM   #8
M5Rlz
Drives: R8, f10m59(Rip), m4, GTR
I'd ask indirectly lol
Always left mine on even when I had a puma case and BMW engineer inspecting my m5 brakes.
That said still safest to take it off, but for simple mindless maintenance tasks they'll be doing its probably fine.
      08-23-2014, 03:40 PM   #9
boots
Curve Thrasher
boots's Avatar
623
Nice...
My SA and M tech both know its in as well as the can tool
      08-26-2014, 02:00 PM   #10
EuroKar
53
Drives: BMW
No dealership can void your warranty because of BMS or any type of aftermarket product.
They can only void your warranty if you have a component failure and the root cause is due to the aftermarket product.
There is a law backing this up. Don't let the dealerships scare you.
      08-26-2014, 07:54 PM   #11
M5TXGuy
M5TXGuy's Avatar
Drives: 2013 M5 BlackSapphireMetallic
I leave mine installed as well. SA knows and there is no issue.
BMS, Akra, Gintani Catless DPs, and Exhaustmeister!
      08-27-2014, 07:27 AM   #12
DrewM5
Drives: SG E60 M5
This is true and under that law the manufacturer (dealer) has to prove that the modification caused the failure. But don't believe for a minute that many dealerships will not use this to deny coverage and make your life miserable while you try to enforce your rights. There is what is "legal" and then there is real life practicality.
2014 M5 Competition|Space Grey|Black Merino Full Leather|Anthracite Trim|Executive package|LED Lighting Package|Drivers's Assit Package|B&O Sound System|Bel STiR Plus 9500ci|IND Side Markers and Side Vents|Exhaustmeister|HRE P101 Satin Charcoal/Michelin PSS (Summer)|601/Pirelli Sottozero Serie II (Winter)|Coded by V12
      08-27-2014, 10:39 AM   #13
shahano
231
Drives: 21' M2C 6spd ,11' 1M, 88' M3
Couldn't it be traced that your car was modded even if you remove it? I think that the computer would save that information? Anyone know about this?
Also how much time does it take to take in on and off?
Seriously considering it but need more information
      08-27-2014, 08:54 PM   #14
skioutwest
Drives: 2020 X4MC, 2017 M3ZCP, 2014 M5
Phil:
I use BMW of Devon as well. I never really asked them but, generally, I find them to be a-holes so I am not going to chance it. I personally don't think it is worth having the dealer flag your car. Tunes are generally pretty simple to remove, and hopefully you only have to go to the dealer 1-2 times a year....no biggie.
I will warn you, that you have to be careful to an extent when removing it. I only have experience with a Procede tune, but the wiring and plugs were not very durable, and I had to replace the entire harness twice. I don't have experience with BMS yet, but will in about a week....
-Mark
      08-27-2014, 11:21 PM   #15
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
Originally Posted by skioutwest View Post
Phil:
-Mark
Thanks bud. We'll talk about this next weekend when we get together.
      08-30-2014, 04:20 PM   #16
vcnyc_
Drives: 2018 Bmw M5 F90
Only remove it if some major happens with the car something like transmission or engine problems because they'll blame the tune on those things, if it is for regular service like oil change or brakes it shouldn't be a problem
      08-31-2014, 10:23 PM   #17
David 12
David 12's Avatar
127
I will just say be careful and make sure you have a solid relationship with your SA. If they know you have the tune, taking it out won't do you any good if your car is flagged.
Your advice would not apply to my local BMW dealer.
Dave
m5post
