      09-16-2014, 05:11 PM   #1
Moocow
Moocow's Avatar
Australia
24
Drives: 135i
2009 135i  [9.00]
Poor handling after replacing rear tires.
Hi all,
I replaced my rear Conti 5's with new Kuhmo 39's. I also had an alignment done.
The car now feels terrible! The rear end doesn't feel solid and planted like it did before. Prior the car with my Coilovers felt like a little go cart, and the rear end was so solid, now the rear feels like a cheap arse Falcon.
I've checked pressures on the new tires, we're fine.
Any suggestions, or should I take it back to tyre power and get them to look at it?
Should replace the Conti's on the front also?
Thanks
      09-16-2014, 05:35 PM   #2
flinchy
Drives: E82 135i
directional? (don't look as directional as the KU31 though :/).. old? (check the date on the sidewall?)
      09-16-2014, 05:52 PM   #3
dtcoff
Australia
49
Drives: 2014 F22 M235i
How many kms have you done on them? New tyres need a couple hundred kms to run in properly, especially noticable if you only change rears as the front will still grip well.
2014 M235i / EB-II / Coral / Sunroof / Comfort & Parking Packages
2014 X3 3.0d / M sport / AW / Sunroof
      09-17-2014, 05:44 PM   #4
flinchy
Drives: E82 135i
Originally Posted by yulook View Post
Kuhmos are rubbish... thats probably why
KU31's are even worse.. probably the worst of the lot
Can't tell a difference between FK452's and the KU31's on mine for half the price
not like i'm putting 400+hp through them though hah.
I thought KU39 were meant to be higher performance/lower wear rating than the KU31's anyway?
      09-17-2014, 09:53 PM   #5
DR-JEKL
Australia
898
Drives: Space Grey E92 335i 6MT
What are the before and after alignment specs?
      09-17-2014, 09:57 PM   #6
robbieredknapped
robbieredknapped's Avatar
14
Drives: 130i M Sport, 6sp
I had a set if KU39 before. Nothing wrong with them.. Plenty of grip. I think better check alinement spec.
      09-18-2014, 06:50 AM   #7
Moocow
Moocow's Avatar
Australia
24
Drives: 135i
2009 135i  [9.00]
thanks guys
I get the alignment checked.
cheers
      09-19-2014, 06:59 PM   #8
martymil
Australia
389
Drives: Garage is to big to list.
It won't be the aligment Ku 39's are ok nothing great for the same price I would have recommended you the nitto invo, such a better tyre especially in the wet.
I run 12.2 116 mph on the nittos and so far done 13k on the and still heaps of rubber left
      09-25-2014, 05:44 PM   #9
Moocow
Moocow's Avatar
Australia
24
Drives: 135i
2009 135i  [9.00]
I finally took the car back to the guys at Tyerpower North Melbourne.
They changed the toe on the front I think, to be less aggressive (back to stock). This made all the difference! Sure it turned in a little quicker before, but it was unsettling the rear end way too much.
A big shout out to the guys at TyerPower North Melbourne. Very helpful, easy to deal with and nice guys. Strongly recommend them!!!!!!!!!!!!
Cheers
      09-25-2014, 06:22 PM   #10
BrokenVert
Resident Kerbalnaut
BrokenVert's Avatar
Drives: Topless Brute/Hybrid Boogaloo
New tires come with a Teflon like coating to make pulling them out of the mould easy. It takes a couple hundred km for this slick coating to wear off.
      09-27-2014, 05:13 AM   #11
kyratz
Australia
Drives: BSM 1M, F15 X5 35i, E46M3
The tyres will need approx 300 kms to scuff in and remove the slippery outer layer from the manufacturing process. Also kumhos are arguably not as high grip/ quality as contis.
      09-28-2014, 12:11 AM   #12
WAY
Australia
458
Drives: Fast ones
That's a sweeping statement that is unfortunately incorrect. My JCW GP comes with Kumhos and no one has found a replacement that is better for turn in and grip. Too bad they only last 3000-5000km hard driving and are almost impossible to find.
      09-28-2014, 07:18 PM   #13
Moocow
Moocow's Avatar
Australia
24
Drives: 135i
2009 135i  [9.00]
Yep waited for a couple of weeks. The Kumhos arent as a grippy, but it was definitely the alignment.
1addicts
