Mo Reviews
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      11-03-2014, 08:50 PM   #1
Hymiet
Drives: 2015 BMW M3
Road Feel
I hear and read about this car having zero road feel through the steering wheel. Is that an accurate statement?
It makes zero sense to me that BMW would eliminate the feel of the road when driving.
Should I be worried?
      11-03-2014, 08:52 PM   #2
SakhirM4
SakhirM4's Avatar
Drives: '15 SO M4/'20 Z4 M40i
2020 BMW Z4 M40i  [10.00]
2015 BMW M4  [8.76]
How many EPS threads are we going to have? We have been beating this to death for the last week already.
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
      11-03-2014, 08:54 PM   #3
Hymiet
Drives: 2015 BMW M3
Sorry... Didn't know. Where is the thread?
      11-03-2014, 08:57 PM   #4
Carl L
Carl L's Avatar
196
Drives: '15 M3
No and no. The F80 is the best M-car I've owned. (see my sig)
      11-03-2014, 09:00 PM   #5
SakhirM4
SakhirM4's Avatar
2015 BMW M4  [8.76]
http://f80.bimmerpost.com/forums/sho...light=steering
Totally agree. I don't have the problem with steering feel. I guess I am just not a good enough driver to notice the problem
      11-03-2014, 09:00 PM   #6
ES_TRADER
Drives: 328i, 335i, M3, 535i, X5, 36M
2014 Ford Raptor  [0.00]
2012 328i E92  [10.00]
2013 X5  [0.00]
2013 335i F30  [8.00]
1990 Toyota Previa  [0.00]
1997 E36 M3  [10.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
What the heck do they mean by road feel?
Is it that vibration that I felt on my e92 steering wheel when going straight? Because I felt vibrations going over rough pavement then it all went away when I changed out the tires for new ones. Is this what they mean by "road feel?"
      11-03-2014, 09:01 PM   #7
solstice
Drives: 2015 M3 6MT
BMW has done the best they currently can with EPS. Everyone is going EPS, HPS is in the past, there is no way back. It is what it is and the F8X steering is far better than other BMWs with EPS, progress is being made. Some of us don't like it (EPS) but it's a matter of take it or leave it since no new cars will have HPS.
      11-03-2014, 09:02 PM   #8
Lups
Lups's Avatar
11827
Drives: I don't own a car.
You would have to be completely paralyzed not to have a feel with this car. Now, Op, go read the sex thread and you'll get the questions we can not answer going in your head.
Originally Posted by Joekerr View Post
You're still a little new here, so I'll let you in on a little secret. Whenever Lups types gibberish, this is an opportunity for you to imagine it to be whatever you'd like it to be.
Originally Posted by Delta0311 View Post
How would you know this? Did mommy catch you jerking off to some Big Foot porn ?
      11-03-2014, 09:20 PM   #9
CanAutM3
CanAutM3's Avatar
21117
Drives: 2021 911 turbo
      11-03-2014, 09:21 PM   #10
fortressmaximus
Drives: BSM M4
Absolutely not. You can absolutely feel the road through the steering. This car is excellent.
      11-03-2014, 09:30 PM   #11
M3OW
M3OW's Avatar
Drives: Bmw f80 m3 on radar
I just test drove the new m3. The car is very fast and has precise steering. The only concern I have is the responsiveness of the engine but this will only be a problem If you use to previous m3's. I've owned every generation except the original e30 and I'm used to high revving naturally aspirated engines. If your ok with turbos, you will enjoy this car.
2015 PORSCHE CAYMAN GTS 6SPD MANUAL ON ORDER
      01-02-2015, 10:38 AM   #12
ASAP
ASAP's Avatar
10159
Drives: '23 X3 M40i
A little bit off topic... but does anyone know what rear subrame bolts directly to the car actually means?
I have looked at pictures and cannot figure out the difference between a normal 3 series. The car still has bushings... do they just mean solid bushings instead of rubber? I hope not...
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
      01-02-2015, 12:02 PM   #13
M4TW
///M Uber Alles
M4TW's Avatar
332
Drives: '15 MW M4
Road feel to me refers to two slightly different concepts.
One is the ability of the car's chassis, tires and steering to communicate the texture of the road surface on which you are driving through the steering wheel. The other is being able to sense the limits of grip going around a corner.
Having driven a F82 over a wide range of road surfaces - dry and wet concrete and asphalt, gravel, ice, snow and my own winter street, which at times resembles the surface of the moon - I can say confidently that road feel in the F82 is not as good as it was in my e90 HPS system.
That being said, I believe it to be leagues better than other EPS systems I have driven and communicates just enough road feel as a driver needs to drive well. Everything else about the EPS system, however, especially it's ability to, well, steer accurately and precisely as you intend is far superior to anything I have driven before.
In short, it is not quite sex without a condom, nor sex with one. It's somewhere in-between that still allows one to be a good lover of the road.
die Welt ist meine Auster
2015 M4, MW, Black Full Merino, DCT, CCB, Adaptive M Suspension, Premium, Executive. Technology, ConnectedDrive, CF Trim, Convenience Telephony, European Delivery
      01-02-2015, 12:54 PM   #14
Black Gold
Drives: M3
There are no bushings in the rear
      01-02-2015, 04:13 PM   #15
Racer20
Drives: F80 M3, 228i THP, E46 ZHP
A subframe is the structure that goes between the suspension and drivetrain and the body of the car. The engine, suspension, axle, and all the other functional parts are bolted to it, and there's typically one in the front and one in the rear. Here's a picture of a rear subframe from some random car I found on google images:
Suspension components are mounted to the subframe with rubber bushings, and the subframe is also mounted to the body with rubber bushings. You can see the bushings clearly in this pic, those coke-can sized things at the left most end, and the two things above the differential. These bushings reduce vibration and add compliance to make the ride and NVH better at the expense of handling precision and drivetrain response. The M3 does not have these large subframe bushings.
Also, rubber bushings come in a million different flavors. The M3 and 335i bushings may look the same, but the rubber stiffness or shape of the molded rubber could result in a bushing that performs very different. The M3 and 335i probably have a completely different bushing set up.
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
      01-03-2015, 10:53 AM   #16
ASAP
ASAP's Avatar
10159
Drives: '23 X3 M40i
Thank you, I appreciate the response. I do understand everything... I must have been looking at some incorrectly tagged images as there were clearly bushings in those. If there are none, then the explanation is clear.
      01-03-2015, 11:26 AM   #17
WVUDrJay
WVUDrJay's Avatar
262
Drives: 2015 M4
Only reason I can't feel the road is the G force making me light headed from the brutal acceleration and lateral grip.
2015 Alpine white M4\black leather, carbon fiber trim,manual,exec package, 19 inch black rims, M suspension, HK stereo, LED lighting
f80post
