Mo Reviews
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      11-23-2014, 12:25 PM   #1
Hymiet
Drives: 2015 BMW M3
Active Suspension and Springs
I know its not advised to add performance springs with active suspension but my questions are these:
1. Can I add Performance Springs and lower the car a bit?
2. If you can, other than the car being stiffer at ever setting what am I losing?
3. Has anyone added springs with Active Suspension and if so, do you like it?
Sorry in advance if this is a repost...
Thx!
      11-23-2014, 01:01 PM   #2
FTS
Enjoying driving
FTS's Avatar
Drives: 645
I am not sure why it is not advisable to change springs specifically on active dampers, I would imagine the shocks would handle it better than standard ones. However, with any damper the issue is one of shock travel, if you trim too much on ride height you will upset the balance terribly. If you know how to setup a car, choose the proper height and spring rates, you may be alright. The problem is there isn't enough test data to show what may or may not work.
If you are talking about the aftermarket lowering springs, those are not 'performance' springs, they are only for cosmetic purposes.
      11-23-2014, 01:24 PM   #3
ES_TRADER
Drives: 328i, 335i, M3, 535i, X5, 36M
2014 Ford Raptor  [0.00]
2012 328i E92  [10.00]
2013 X5  [0.00]
2013 335i F30  [8.00]
1990 Toyota Previa  [0.00]
1997 E36 M3  [10.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
Are factory springs "performance" springs?
      11-23-2014, 02:56 PM   #4
FTS
Enjoying driving
FTS's Avatar
Drives: 645
I have no clue, but they are designed for certain level of performance mated to the shocks.
      11-23-2014, 06:20 PM   #5
AreOut
Drives: E39 M5
suspension design is a very tricky one, factory drivers spend hours and hours on Nordschleife and local roads setting it up so I would be really careful changing anything if performance is what you want, there is a chance to hit a good setup but there is much bigger probability the car will actually drive worse than stock
      11-23-2014, 09:45 PM   #6
smedin
smedin's Avatar
70
Drives: 2015 F80 6MT
FWIW: I installed the F32 H&R springs on my F80 with adjustable suspension, and I am extremely pleased with the ride.
F80 6MT. In full color.
      11-23-2014, 09:50 PM   #7
myemailsea
Drives: M-Cars
My M4 with Active Suspension arrives in 2-3 weeks and I spoke with my BMW Service Adviser/Parts Manager and I am lined up to install H&R Springs with wheel adapters coupled with a new alignment on day one @ the BMW Dealership
      11-23-2014, 10:03 PM   #8
///M Leistung
/// Knight Industries Two Thousand
///M Leistung's Avatar
95
Drives: 2015 AW/SO M4
I have the H&R Sports with Adaptive Suspension as well.
Haven't really had a chance to push the car yet. But the ride doesn't seem to have been degraded much, if at all. All functions still function as intended.
      11-30-2014, 10:32 AM   #9
stealth-twntrbo
stealth-twntrbo's Avatar
Drives: 2020 740xi
Are wheel spacers required with the sport springs?
      11-30-2014, 04:14 PM   #10
SSIIM5
Drives: AW ///M4
How much did the dealership quote you for the install? Thanks..
      11-30-2014, 07:05 PM   #11
myemailsea
Drives: M-Cars
I did not ask for pricing. I'll provide an update once the installation is complete
f80post
