ARMA SPEED
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      01-07-2015, 02:21 PM   #1
audihere
Drives: F80 M3 and Clown Shoe
sticky brake pedel
Does anyone else notice that the brake pedal sticks up at the top if very lightly pressed on after driving for a while?
My car is in service right now and I took a long drive with service foreman in which he could "sort of feel it".
To me it's more noticeable, sort of like the feeling of a magnet breaking loose.
If it sticks and then I lightly press again on the pedal right away, it's silky smooth (not sticky). But after driving a short distance, I will feel that light resistance and breakaway again.
I hope they can resolve this.
Chris
      01-07-2015, 03:13 PM   #2
Gearhead999s
Gearhead999s's Avatar
815
Drives: RR Velar R=Dynamic M2C R1200GS
I have noticed that a little bit in the free play part of the pedal movement.I do not think it is anything to worry about.
      01-07-2015, 03:18 PM   #3
consolidated
consolidated's Avatar
205
Drives: F80 M3
Glad you mentioned this, thought it was just me. It's like a detent.
F80 M3 / Mineral Grey-Silverstone / CCB
      01-07-2015, 03:42 PM   #4
audihere
Ya, detent is a good description. But if I feel the resitance and then let all the way off and press it again right away, no detent.
Chris
      01-07-2015, 04:04 PM   #5
Gearhead999s
815
That is probably the right description.
      01-07-2015, 06:44 PM   #6
audihere
Just got word back from service department that "this is normal".
The 328 loaner they gave me sure had a silky smooth brake pedal. That was the only part of the 328 that I liked more than my M3
Chris
      01-08-2015, 12:38 PM   #7
audihere
OK, I take this back. While returning to the dealership, I did actually feel the same clicking in the brake pedal as on my M3. However, I don't like it and feel BMW should be able to engineer a smoother operating brake pedal in a car like this.
Chris
      01-22-2015, 03:37 PM   #8
audihere
I'm starting to think this is a mechanical stickiness vs some sort of vacuum.
In the morning, when I start the car, it sticks the first time I press it in too.
Anyone have any ideas? I'd really like to get rid of this annoyance.
Chris
      01-22-2015, 04:56 PM   #9
gthal
gthal's Avatar
1904
Drives: 2018 340i xDrive
I've noticed it myself. I personally find the first 1/2" of brake pedal travel to be too soft. I suspect it was engineered this way to provide smoother application but I lick super touchy, super firm brake pedals
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery
2016 M2 | Long Beach Blue | 6MT
2015 M4 | Austin Yellow | DCT
2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3
      04-27-2018, 04:04 PM   #10
audihere
Anyone have a solution for this randomly "clicky" brake pedal when pressing down on it after driving a while? Also happens in the morning every day when starting up. I can feel the pedal "click" down. IS THIS NORMAL?
I have the cover removed from the pedal area now so I can see up there and have been trying to figure out where the stickiness comes from, but it's a mystery.
      04-28-2018, 07:10 AM   #11
allinon72
allinon72's Avatar
Drives: 20' M2C, 23' X1
I have this in my X1, but haven't noticed it on my M3
      04-28-2018, 12:49 PM   #12
audihere
Thanks for chiming in!
Each day I crawl under the pedals and try to figure out why it's clicking in the morning before starting the car. I'm assuming this click is related to the random one that happens when driving.
I've moves some parts around but it's just no apparent what could be causing this
      05-23-2018, 05:46 PM   #13
audihere
I don't think it's the brake lamp switch because it seems to be non-contact some sort of capacitive sensor switch.
The medium duty spring on the brake pedal mechanism doesn't seem to be causing the stickiness either. Removed it and still having the problem. Not sure what that spring even does?
Rod and linkage that goes into cylinder? is loose, but no way to tighten it. Not sure if that's it, or if it's in the cylinder?
      10-12-2018, 12:22 AM   #14
audihere
UPDATE: I got this problem fixed. Cost me a fortune. Not so happy about that, but what a relief the random click when pressing in brake pedal is finally gone!
      11-11-2018, 06:48 PM   #15
thakid22
Drives: 2021 Bmw M340i M-Sport w/ VDC
What part was replaced to fix this?
      11-12-2018, 08:08 AM   #16
mindspin311
Drives: BMW
My 2018 has this issue
2012 Space Grey 128i
      11-16-2018, 07:35 AM   #17
thakid22
I’ve been noticing it on a few BMW’s now.
The dealership will have a hard time finding this because it is hard
to demonstrate the problem when it only happens every now and then.
      05-22-2020, 01:17 AM   #18
audihere
OK, I fixed this!
F u Crevier BMW. F u Irvine BMW. F u BMW NA. Sort of in that order.
With that said...
I'd been thinking this over for a very long time. I actually purchased a used brake pedal assembly to better see what's going on with the pedal linkage.
(No need to remove brake pedal from car)
Being at home during this Covid time, I've been working on my cars and finally decided to try something on the brake pedal I've been mulling over in my head.
I pulled the trim cover off the pedal area *again* and looking at that, in combination with analyzing the eBay pedal assembly I found this:
When you let off the brake pedal, the return spring pulls the rod coming thru the firewall all the way back until it stops. However, there is some slop in the linkages, so the after the rod is fully back, the return spring actually pulls the pedal back just a tiny bit more!
Now if for any reason, the rod gets sticky after driving around for a while, when you I press on the brake pedal, it moves about 1/16" to take up the slop before actually pressing on the rod. That's the clicking sensation - a slight pedal movement before a click to get the rod moving.
So, what I've been wanting to try, is to take up this slop. Get rid of that pre-movement and just start off up against the rod. Using the eBay assembly, I fabricated a high precision spacer. OK, no I didn't, I cut a piece of wood I had in my garage and put some felt on it for good measures.
I did measure my car's pedal position with some digital calipers to find out where it was sitting when not depressed. Using that measurement, I added a little thickness to take up that "slop".
Before, my F80's brake pedal will ALWAYS click very noticeably in the morning one time when starting the car cold. Always. (Subsequent presses are silky smooth) While driving, it would randomly click every 1-5 minutes or so. I was never able to figure out how to force it to click. Car has 40K miles on it now.
I press fit the wood block into the brake pedal channel. First morning, no click! Test drive no click! It hasn't clicked since. In fact, brake pedal feels better than ever beyond the no clicking, not totally sure why.
Here's some pics. YMMV on measurements. https://www.dropbox.com/sh/xbshwkox7...mGxwvk3ja?dl=0
Audihere
      07-06-2021, 12:59 PM   #19
BMW 130i Greg
BMW 130i Greg's Avatar
Drives: BMW 130i 2010
Hi,
I read that you solved the brake pedal problem. But don't your brake lights always come on with such a wooden block in between?
I have an F30 LCI 320i with also an annoying brake pedal. Every time I don't brake for a while I feel a resistance at the beginning of the pedal. Brake shortly afterwards and all is well. After a while back the same resistance.
Thanks in advance!
Greetings Greg
      07-13-2021, 02:28 PM   #20
audihere
Hi Greg, I just replied to your PM. Brake light switch is a simple ratcheting adjustment after the fix is in.
Yes, this COMPLETELY FIXED the sticky feeling in my M3 brake pedad that BMW could not figure out for the life of them.
Looking at my post, it's been over 1 year and I have not had one single click of the brake pedal ever since fixing it!
      07-13-2021, 02:42 PM   #21
BMW 130i Greg
Thank you!
      07-14-2021, 10:06 AM   #22
BMW 130i Greg
@audihere:
You are a HERO!!!
I am so glad you made a topic about this.
I did exactly the same as you did and NO RESISTANCE anymore!!!
Maybe a whole new brake pedal will fix this too?
Greg
f80post
