01-22-2015, 08:40 PM | #1 |
Rep 495
Can Parking Assistant be Coded On?
I saw someone's order form on here and wondered if the 5DP parking assistant option can be coded, if you have all the cameras?
Is there any other hardware, switches required? Anyone have any insights? Perhaps it needs an FSC code? James.
Drives: 2021 F97 X3MC LCI - Marina Bay Blue Metallic
Gone: 2019 G16 840i GC - Frozen Bluestone Metallic Gone: 2018 F80 M3C - Sakhir II Orange Metallic Gone: 2015 F80 M3 - Mineral Grey Metallic |
01-23-2015, 11:14 AM | #2 |
Explodes on impact
209
Rep 552
Disclaimer: I do not own this car nor how its built
From the technical standpoint, likely it can be coded but need more than just cameras. Most critical is the proximity sensors on the bumpers and sides of the car that is also needed. Its those little circles you find especially just under the front side view cameras as an example. Cameras alone do not have the ability to sense the distance the car is to objects. I would also imagine there might be other systems and/or possible coding/parts needed - such as something that regulates how must throttle/brake to apply. TLL - Yes it can be coded but will be incomplete without other critical systems/parts.
Yea... yea I got an M(azda)3.... <.<
*work in progress* |
01-23-2015, 11:28 AM | #3 |
Rep 495
Thanks. I have front and back parking distance control, plus the full camera package. I just am not sure how the system is activated so wasn't sure if there was any additional hardware required. I was thinking more along the lines of extra sensors or an initiation switch. I didn't think of a controller for the throttle/brake I do have DCT though which should make it easier.
Still too much uncertainty for me to give it a go
01-23-2015, 12:08 PM | #5 |
Rep 495
Just watched a video on YouTube about how this works. The car basically only controls the steering, you have to provide manual throttle and brake input, so it is unlikely there is any required hardware there. That may suggest that there are extra motors required to drive the steering input however, but then again with the F80's electronic steering, this equipment could be accessed by the parking assist too, just needing software input.
I may try and add it tonight and see if it is recognized. I am not sure which ECUs I will need to VO code though, and I am not too keen on adding back in all my prior coding on a hunch. Someone must have tried this...?
01-23-2015, 04:27 PM | #7 | |
Rep 495
Almost talked myself into thinking this might actually work!!
Gone: 2019 G16 840i GC - Frozen Bluestone Metallic Gone: 2018 F80 M3C - Sakhir II Orange Metallic Gone: 2015 F80 M3 - Mineral Grey Metallic Last edited by JDS; 01-23-2015 at 04:27 PM.. Reason: Typo |
02-05-2015, 04:11 PM | #8 |
364
Rep 1,517
Just taking a guess, but looking at the electrical diagram from the 7 series, it would appear both the side cameras (by the wheels) and the side camera control units would also be needed.
http://www.realoem.com/bmw/partgrp.d...43&hg=66&fg=05 |
02-05-2015, 04:48 PM | #9 |
Rep 495
I have the side cameras, I believe, as part of whatever package they come with, but I think the sensors for parking assist might be slightly different and not necessarily purely optically based...
Can't remember where I heard or read that though...
02-05-2015, 09:22 PM | #10 | |
364
Rep 1,517
02-05-2015, 09:26 PM | #11 |
Rep 495
Yes, thanks. I have pretty much given up on this one.
Don't really need it round here anyway. It's not like there is a shortage of parking. And being British, parallel parking is in our blood. We are born able to do it...
12-09-2015, 01:27 AM | #12 |
Sakhir Smurf
314
Rep 594
Drives: Plaid, F82 M4, E46 M3, Sequoia
Did anyone confirm whether this can be done or not?
2015 M4: Sakhir on Sakhir | M-DCT | Adaptive Suspension | Lighting | Executive | Cameras | HK Sound | Full Leather
2004 M3: Laguna Seca Blue | SMGII | Basic track mods: 18" Square setup on R888s / Performance Friction rotors / SS Lines / Ground Control Street/Track Kit / DTC-60 Pads NASA NorCal Instructor |
12-23-2015, 03:51 PM | #13 | |
Rep 1,201
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD) |
