02-18-2015, 05:06 PM | #1 |
6'0 / 250lb
137
Rep 1,797
New exhaust tips
Bought from Bimmian. VERY good quality. $215/228 shipped.
Tip on left is stock. Tip on right is the new one from Bimmian
Build: '14 M5 - Space Gray / Full Sakhir Orange / Alum Trace / Black 343's / Exec / Driver Assist / LED
Mods: SunTek CXP tint - Vinyl-wrapped door handle chrome - Macht Schnell 12mm spacers - Pedalhaus pedals - iND Cosmetic Package - Polished 90mm exh tips - Coded by v12 - 21" HRE S107's polished lip/black center |
02-18-2015, 05:07 PM | #2 |
6'0 / 250lb
137
Rep 1,797
Pic 2
02-18-2015, 05:13 PM | #4 | |
6'0 / 250lb
137
Rep 1,797
Yes, they fit both standard and CP exhaust. OEM tips slip right off. These will clamp on via 3 bolts that you compress down onto the factory output pipe from the muffler. Super easy install. Once you see it, you'll see how easy it is.
02-18-2015, 05:31 PM | #5 |
Rep 165
you are right, hard to tell which one is the larger diameter. I know the OEM is 76mm in diameter.... i was wondering if you know the actual size of the the "new one"? I personally think going from the original size to 90mm is a sweet spot.
02-18-2015, 07:36 PM | #7 |
6'0 / 250lb
137
Rep 1,797
Correct. It's 3.5" in OD. 88.9mm.
I think you're right... 90mm is a really good size. Though, if I could have it my way, I'd make them a TAD bigger...like 95mm.
02-21-2015, 09:41 PM | #9 |
Rep 6,067
Buddy I recall at some point you got the CF one from ebay... what happened to them? not good quality?
Current : 2020 F92 Black Sapphire M8 - ZF8
Gone : 2018 F80 Mineral Gray M3 - 6MT Gone : 2016 F82 Austin Yellow M4 - 6MT Gone : 2013 F13 Sakhir Orange M6 -7DCT Gone: 2013 F13 Alpine White 650i -ZF8 |
02-21-2015, 09:52 PM | #10 | |
6'0 / 250lb
137
Rep 1,797
I got these because I'm changing overall look of the car a bit since I got new wheels with polished lips. So I want to change the exhaust tips first. Then evaluate changing the M5 badge and side gills.
02-21-2015, 10:15 PM | #11 |
6'0 / 250lb
137
Rep 1,797
Not that I know of. At least not ones you can put on the stock mufflers.
