02-21-2015, 10:11 AM | #1 |
BimmerPost Supporting Vendor
1997
Rep 6,916
Winter Car Care Tips - Salt Removal
Winter Car Care Tips - Salt Removal Wash
Helpful Winter Tips
Make sure the car is completely dry
This BMW 435 X Drive receives a salt removal wash and protect. Salt Removal - Wash and Protect Our special pre-soak was designed to chemically remove the majority of the salt and road grime off the paint, with our touch less approach we are preserving the condition of the paint. After shot Interior Mats - Salt Removal - just as important make sure your interior is free and clear of salt as it will cause long term damage to your interior bits and pieces. Before After |
02-21-2015, 10:30 PM | #2 |
Rep 981
I'd like your opinion on those touchless washes typically found at the DIY car washes. I've always heard the water is super hard and can over time dull the paint. I've heard that having the car caked in salt is better than using those.
If you're familiar with the one in hackensack thats the one I'd use. |
02-21-2015, 10:59 PM | #3 |
1997
Rep 6,916
that's the same one I used prior to opening up the shop, I have had no issues with that location. remember after you wash the car you should always try to protect it once dried.
02-22-2015, 01:54 PM | #7 |
Rep 3,066
what is the best product to remove salt stains from carpet in the footwell area? I've been using good ol' elbow grease with warm water and soap. It works ok but I'm sure there is a better way...
02-22-2015, 01:55 PM | #8 |
1997
Rep 6,916
Your method is a good one, you can add 1Z einszett Plastic Deep Cleaner into the mix and it will assist in your salt removal on carpets well.
02-22-2015, 02:50 PM | #9 |
Rep 495
DetailersDomain What is the product you recommend for the touchless salt removal described below?
Also, I have a pretty sturdy pressure washer. Is there a product you recommend that I can mix through the pressure washer to foam the car? My pressure washer has a detergent inlet and wondered what could be used with my foam nozzle to get things started before the 2 bucket method... James.
Drives: 2021 F97 X3MC LCI - Marina Bay Blue Metallic
Gone: 2019 G16 840i GC - Frozen Bluestone Metallic Gone: 2018 F80 M3C - Sakhir II Orange Metallic Gone: 2015 F80 M3 - Mineral Grey Metallic |
02-22-2015, 02:56 PM | #10 |
1997
Rep 6,916
James check out our products in this link - Presoak post #5
02-22-2015, 03:16 PM | #11 |
Rep 495
Thanks. I'll get an order in soon.
