03-05-2015, 10:43 AM | #1 |
704
Rep 1,917
Possible vacuum leak?
For the past couple weeks I've been having RPM surging at idle; it even stalled on me once while car was running in the driveway. Took the car to my race shop and plugged into the computer and it showed a P00BD fault, having to do with possibly a MAF sensor issue or loose piping. We cleared the code, and it hasn't returned, however the car still idles rough.
FWIW, I have AMS catless downpipes, no tune YET. Any thoughts???
Matt
03-05-2015, 10:55 AM | #2 |
Perennial PFC
336
Rep 1,275
Your car is asking you for the tune! I'd think the real benefit of the catless DP is only realized when you're able to adjust fueling properly with a tune. I don't know the adaptability of the stock ECU, but it must be on the limit with the other reports of driving difficulties when hard on the throttle for cars with catless DP.
03-05-2015, 11:05 AM | #3 | |
704
Rep 1,917
Matt
03-05-2015, 06:53 PM | #5 | |
53
Rep 664
You can run catless down pipes on these engines with stock software and it will run fine. I don't agree with doing so as I believe that this mod needs a complete ECU reflash to operate and its best..but that's well argued in many many posts. Anyways... check the operating values of the air flow sensor. There are some checks that need to be done with a good diagnostic program. Something is going on for the fluctuation of the idle. |
03-06-2015, 09:31 AM | #6 | |
704
Rep 1,917
Thx
Matt
03-09-2015, 01:53 PM | #7 |
53
Rep 664
Tune ? As in performance tune ?
Don't do that. You will have the same issue You should take it to a reputable BMW shop and have them figure out what issue you have going on. Then add the performance software after Last edited by EuroKar; 03-09-2015 at 01:59 PM.. |
03-09-2015, 01:57 PM | #8 | |
704
Rep 1,917
[QUOTE=EuroKar]
Matt
03-16-2015, 10:50 AM | #9 |
704
Rep 1,917
Well, car is fixed. A number of issues were seen. Downpipes were originally installed without a proper seal. New air filters, MAF, plugs and coils were all done. Oil changed as well. Also had a couple instances of DTMAL. Software was upgraded. Car is running smooth as butter now...
If anyone in the Houston area needs a good shop for diagnosis check out MPower on Fondren.
Matt
03-16-2015, 11:15 AM | #10 |
Perennial PFC
336
Rep 1,275
Good news! Was the neglected seal at the bottom of the DP or up top? Boots mentioned coils in his tune up also, is there something different about BMW coils? I had individual coils mounted on top of the plugs in my Lexus. Had the car for 16 years and never touched the plugs or the coils! Much less horsepower of course, but the coil just produces a spark and if it's suitable for the engine, what wears out? Maybe I should do a search and learn something about the new coils.
03-16-2015, 01:41 PM | #11 | |
704
Rep 1,917
And FWIW, make sure you get oil changes every 5K miles. My oil was BLACK as night. FYI, I have 48K miles on my car.
Matt
