03-25-2015, 08:44 PM | #1 |
67
Rep 327
Drives: 2017 Tesla Model X P100D
Bench Flash tune is a Bench Flash tune?
AMS Tune - 93HP, 100TQ $2500
http://f10.m5post.com/forums/showthread.php?t=1080125 ESS S63TÜ T-700 Performance ECU Software for F10 M5/F1X M6 - 95HP, 109TQ $1900 http://f10.m5post.com/forums/showthread.php?p=17663073 Vivid Racing Tune - 70HP, 120TQ $1500 http://www.vividracing.com/catalog/v...150949476.html BR Performance Tune - 105HP, 170 nm TQ $1935 http://www.br-performance.be/en-be/c...5-competition/ Eurocharged Tune - Bologna Numbers http://f10.m5post.com/forums/showthread.php?t=1095704 Jailbreak Tune - ? http://f10.m5post.com/forums/showthread.php?t=1082497 Above are all the "Bench Flash Tunes" I've seen lately. I've heard some people say "the tunes are all a similar canned tune, there isnt that much of a difference." Is this true? From my understanding, BR Performance came up with the methodology, hardware, software and instructions to allow tuners to bench flash the M5 ECU. They charged each tuner access to use their proprietary system to direct flash thus bypassing the encryption. However, it's my understanding that each tune is done by a different tuner with difference experience; HP/TQ numbers, rev limiters, will vary - all are just bench flashed onto the ECU in a similar method. The prices are quite different across the board. My question is, are all tunes from each of the vendors above all close enough that it really doesn't matter? Vivid racing is local, can pull and flash the ECU, they have done a number of Ferrair 458's the same way, have experience bench flash tuning, but the tune is one from a European source they load on there. So there is no detailed information behind it. What's everyone's thought. Thanks for the input! Last edited by ImpetuousRacer; 04-01-2015 at 09:41 AM.. Reason: Added ESS Tune and Pricing for each |
03-26-2015, 09:25 AM | #2 | |
Rep 221
03-26-2015, 11:23 AM | #3 | |
Rep 5,110
03-26-2015, 11:52 PM | #4 |
363
Rep 1,805
Drives: 2014 BMW M5 F10 CP
Thanks for a great thread. On your comparisons. Some tunes are with downpipes and there are therefore different parameters for the tuning results. I think it's important that this is taken into account or expectations could not be met or be exceeded.
In the case of the BR Performance tune, I am unclear on your figure indicated. I am running around 600whp which at the crank is a lot higher depending on claimed power loss. Even if this number is 680hp at 10% -15% that's over 100hp increase in power. 44hp is low. The cars with downpipes and Stage II tune are probably closer to 740 - 760 hp.. Whichever tuner you go with, be prepared to remove your ecus and to ship them! 5 days turnaround has been impressive from CA to Belgium..but it's still something you need to accept.
2014 BMW F10 M5 ZCP | SSII / Black | MSR Stage III | MSR Intakes | RPi GTM Exhaust | RPi Catless Downpipes |RW Carbon Front Lip | RW Carbon Diffuser | RW Carbon Trunk Spoiler |
03-27-2015, 07:17 AM | #5 |
14
Rep 137
none the less none of these are "custom" tunes they simply are just that....flashes allowing the stock engine to perform exactly how bmw would of had it unlimited from the factory, the file to get into the factory ecu can be purchased for aprox 8-10k buy tuners alike and can then be "custom" tuned for specific mods provided the tuner is competent to do so
You'll see a few more companies coming out shortly with their own tunes and custom abilities |
03-27-2015, 08:29 AM | #6 | |
363
Rep 1,805
In the case of US based tuners, I think the real benefit will be that they will do a real custom tune that isn't within broad parameters and that is more fine tuned to a specific car. This is where I think the real value will come and I look forward to a time when the decrypted ECUs can be reprogrammed via OBDII or some other means.
03-27-2015, 11:30 AM | #7 | |
67
Rep 327
Vivid racing is local to me. I can drop the car off there, they will pull the ECU, bench flash, install, dyno before and after all in same day for $1500. Amazing deal! However, they aren't doing the tuning. They have an unspecified "European Partner" that has done a canned tune for the M5 that has supposedly been tested and used. (guess they are licensing the file?) They simply have the ability to pull ECU, open, and flash the file onto the ECU. There is no dyno of the results, there are no prior customers with feedback on it, there is no tuner or tuning company that is disclosed that I can verify their reputation. Hence, the deal so I can be the feedback person and show dyno results. The above scares me. I do not want to go cheap and pay more in the end. However, perhaps all these tunes are very similar and it doesn't matter? |
03-27-2015, 11:35 AM | #8 | |
Rep 2,202
Personally don't trust dynojet numbers much anymore just seeing all the gtr guys go from mustang dynos to dynojets and almost always post 100+whp/trq more on dyno-jets. Which may be a reason we aren't seeing any failures with BMS/DP's/Meth is because when we're all posting 600+ numbers its actually more like high 500s low low 600s |
03-27-2015, 01:35 PM | #9 | |
Rep 2,176
03-27-2015, 05:06 PM | #10 | |
Rep 2,202
Personally if I was going to go about being one of the first in line I would: AMS tune Have MotiV make me a turbo kit Order that dodson dct clutch kit and see how it runs... Keeping it in the back of my mind that the stock gearing and engine internals, and the injectors being asked to pump so much more fuel into the car would still be exposed to an extreme amount of increased wtq and hp. ^and lets not forget stock diffs if you actually have a car making 700+ and start using your launch control lol Yup I'd say stock m4/m3's on a mustang would be somewhere in the 300s with maxed out JB4 e85 ones in the high 400s low and behold http://f80.bimmerpost.com/forums/sho....php?t=1038646 Last edited by M5Rlz; 03-27-2015 at 05:17 PM.. |
03-27-2015, 07:01 PM | #11 |
Curve Thrasher
623
Rep 3,773
Hi guys. Although I'm back offshore working and haven't had much time to perform qualified testing (still in the works), I can report that the speedo limiter is unlocked. On the 4wheel Dyno my car reached a speed (5th) gear @190mph. Hp numbers are up but until I return from work in a few weeks and we finish testing I cannot comment on anything. I think this is an exciting time for f10 m5 owners. Mcarsfan car is running strong as well as another members car here in Town. Safe driving all.
03-27-2015, 10:56 PM | #13 |
Rep 54
Same boat as everyone else.....I'm really anxious to see how the clutches and engine internals hold up to the power. My GTR was making mid-700's HP and low-600's torque and that's all the clutches could handle. It really needed a clutch upgrade just to put that much down. My M5 just put down 655hp/616tq (on a dynojet) with the JB4 on +4.0 which is pretty close to the torque of the GTR which makes me curious if/when I'll have clutch issues. I'm also about to tryout some Nitto NT05R's so I'll lose that buffer of the tires spinning.
03-27-2015, 10:56 PM | #14 | |
363
Rep 1,805
If you have concerns on the shipping, more than happy to assist with information. Key is having someone correctly remove and reinstall your ECUs.
03-29-2015, 08:28 PM | #15 | ||
Rep 87
03-29-2015, 10:08 PM | #16 |
363
Rep 1,805
600whp 625 lb - ft torque on my remap. Been running this tune since January and over 2500 miles. No issues.. Nada...not one.
03-30-2015, 09:28 AM | #17 | |
Rep 54
Also, doesn't Dodson have a kit out already? I haven't researched it, but I feel like I might need to soon. |
03-30-2015, 01:04 PM | #18 | ||
Rep 2,202
They have a clutch kit either in the works or almost ready, maybe even done. While I think its a wise upgrade, I just wouldn't wanna spend the money until I'm sure if the gears could take it, other parts of the trans, diffs, engine internals... |
03-30-2015, 09:47 PM | #19 | |
Route Runner
137
Rep 661
16 SMB M6 Gran Coupe
16 BS X6 X-line (wife's truck) 13 AW M5 (sold) 04 Honda Pilot (everyday car) |
03-31-2015, 01:42 PM | #20 |
8208
Rep 18,823
Drives: BMW
Add ESS's flash to the list:
ESS S63TÜ T-700 Performance ECU Software for F10 M5/F1X M6 - 95HP, 109TQ http://f10.m5post.com/forums/showthread.php?p=17663073
Tom G. | european auto source (eas)
email: tom@europeanautosource.com ˇ web: https://europeanautosource.comˇ tel 866.669.0705 ˇ ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG ˇ FACEBOOK ˇ YOUTUBE ˇ FLICKR ˇ INSTAGRAM |
04-01-2015, 08:01 AM | #21 | |
Route Runner
137
Rep 661
04-02-2015, 06:42 AM | #22 |
363
Rep 1,805
Those are great numbers. Was customization of tune once ecu's flashed done via OBD II?
