05-17-2015, 01:06 PM | #1 |
Rep 5,498
Dinan Intake Observation
I posted this in my build thread but figured it was worth posting here as well.
I bought this intake for pure aesthetic and sound purposes but I made some observations while installing the intake. Here is the Dinan intake side by side with the OE intake. IMG_0855 by JEllis, on Flickr A lot of people have questioned any advantage a Dinan intake has over a drop in filter. Here you can see the size difference in the collars that attach to the filter. Dinan claims theirs is 30% larger. It certainly looks less restrictive. I am not sure if there is anything to be gained from the larger intake collar but I figured it was worth noting since it is a significant difference from the OE intake collar. IMG_0857 by JEllis, on Flickr Food for thought. I don't really care if this thing is making any real power as the sound coming from the motor is awesome with it.
Instagram: jellismotorwerks |
05-17-2015, 01:42 PM | #2 |
657
Rep 1,749
It is often deceiving when people advertise decrease in restriction or increases in volume or flow. While you can have a legit increase in flow from a less restrictive piece such as this, it often can lower or decrease the air movement's velocity as you lose velocity of flow with a larger diameter. Now that can be good or bad just depending on the application. In exhaust for example, you can put a large diameter piped exhaust on a naturally aspirated car like ours and it will truly be larger diameter, higher overall flow capacity but in the end the exhaust gases will flow at a slower velocity and actually lose performance due to loss of scavenging.
On the intake side, the speed at which the air is flowing into the engine is often a piece of the puzzle and as long as an engine is getting enough air, then the higher velocity of the air can be a good thing. Opening up the diameter may allow for more airflow potential but the engine does not need more air necessarily and the pumping losses associated with moving in, inherently slower moving air due to a larger diameter can decrease power. That is why so many intakes rob horsepower, not to mention head soak. I would venture this is such a small difference it doesn't do good or bad in general. However it is a good example of how its a good marketing tool to say its 30 percent less restrictive for example but that doesn't necessarily translate into more power or performance for a given application if there is no need for more overall air and the air is now simply moving more slowly. Turbo cars can be different animals and you can get away with less velocity on intake or exhaust side in favor of more diameter but I am talking about naturally aspirated applications. |
05-17-2015, 01:46 PM | #3 | |
Rep 5,498
05-17-2015, 03:23 PM | #5 |
Rep 3,742
Funny, J; I am about to install a Dinan intake myself. Take a look that the elbow itself. The Dinan one is far more open than the OEM one (for better or worse).
I actually like the Dinan intake for several reasons: A clamping filter instead of one held in place by compression, metal fittings at the PCV hose, a re-usable filter, and sound. Most of all, I wanted mine to blend into the plenum and air box instead of the gloss black OEM elbow, so I hit it with a wrinkle-black look. |
05-17-2015, 04:35 PM | #7 | |
Rep 5,498
05-17-2015, 06:18 PM | #9 |
Rep 5,498
In terms of sound, probably no difference.
05-17-2015, 06:21 PM | #11 |
Rep 5,498
I haven't used a drop in but if I did I would probably go with BMC... OE for Porsche, Ferrari, Merc Motorsports
05-17-2015, 11:29 PM | #12 | |
Rep 3,742
But it seemed to me that it was somewhat difficult to install. In particular, it is difficult to ensure that the rubber seals are fully seated. Before giving up, I'd decided that it was probably easiest to install the elbow on the plenum without the filter and that little plastic transition piece. Then, once the elbow is snug, slip in the filter-and-transition thing as one piece. But I could be way off on this and would be curious to hear your thoughts. |
05-17-2015, 11:45 PM | #13 | |
Rep 5,498
05-18-2015, 12:33 AM | #14 | |
Rep 2,400
Just as an FYI to those who may attempt this in the future, I install all the pieces rubber gasket, elbow, and transition piece as one piece and then slip on the filter last. It's the same way for subsequent filter changes (I change my filter instead of cleaning), just loosen the clamp, pry the knob to unseat the filter and pull the filter off from the transition piece. Re-insert the new filter, push it around the transition piece, push it down together with the knob so that it's snug, then tighten the clamp.
The MS intake elbow I would say is harder to install, given the rubber couplings are much harder and I believe the elbow sticks out even more. Love the Dinan intake piece, except I got a CF plenum to match the elbow Quote:
12-17-2015, 09:24 AM | #15 |
Rep 63
Drives: 2013 E93 M3 LMB, 6MT
Quick question on the air velocity issue.... As some have mentioned in this and other threads, when you put on a larger diameter charge pipe the air in that portion of the system should move slower. But, since the air is then moving into the engine through the exact same opening regardless of what intake you have installed, wouldn't that then re-increase the velocity regardless of what's upstream in the system?
I'm not an induction expert by any means, so there may be other factors I'm not considering... Thanks for any clarity you guys can provide. Last edited by Elwolfe; 12-17-2015 at 09:30 AM.. |
12-17-2015, 10:47 AM | #16 | |
168
Rep 1,792
I just messed around with an online air flow calculator, air speed actually remains the same when go to a bigger duct, but CFM increases with the bigger duct. More air means more power as long as the ECU can adjust for it.
12-17-2015, 06:50 PM | #17 |
Rep 63
Cool, thanks for the info Leonardo.
12-18-2015, 07:08 AM | #18 |
Rep 3,350
Velocity definitely is a function of the cross sectional area for the same mass flowrate. Assuming you hold the mass flowrate constant, and you increase the cross sectional area (diameter, what have you), velocity of the fluid falls.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 |
12-18-2015, 01:23 PM | #19 | |
Rep 804
Drives: Some fun stuff
12-22-2015, 07:42 PM | #20 |
coupe la goon
373
Rep 1,644
Drives: green, black, white
Garage List 2011 BMW 1M Coupe [10.00]
2013 BMW M3 Coupe [10.00] 2010 BMW 535i xDriv ... [0.00] 2008 BMW M3 Coupe ( ... [0.00] |
12-23-2015, 12:21 AM | #21 |
Rep 3,742
12-23-2015, 12:25 AM | #22 |
Rep 3,742
Sound change is not as dramatic as you might think. It's hard to describe, but it just seems to sharpen the buzz-saw induction sound the S65 makes. It's a bit less muffled and muted than with the OEM setup. It's a nice compliment to a good exhaust.
