02-14-2008, 01:06 PM | #1 |
Rep 2,937
Drives: 2013 Estoril 328i M Sport
My recommendation for a USB flash drive/iPod replacement
Jason/mods, please don't move this to the Audio section. Being most people don't view that forum, I thought this would help the good amount of people that are getting the iPod adapter.
I started another topic a while back asking about what a good choice for a USB flash would be. After a ton of research, I settled on the Corsair Flash Voyager 8GB. I've had the unit for about three weeks now and can give a brief synopsis of its overall quality. It's encased in sturdy and firm rubber padding. Tests have shown that you can run it over and it'll remain in pristine quality. This is unlike many earlier USB flash drives that were in normal plastic housings that could break without much harassment. The unit I bought in particular is the 8GB version, which holds roughly 1,300 songs in 320kbps quality. A main factor in considering a flash drive is it's read speed, and the Flash Voyager is the fastest unit on the market (outside of its more expensive brother the Flash Voyager GT). It's average read speed is 38 mb/s, which is a great deal faster than other drives that average around 8 mb/s. Even if you're sending FLAC quality songs through your amp, there won't be any lag time in requesting the song and it appearing through the speakers. The MAJOR plus in running a USB flash drive instead of your iPhone/iPod as the host of your MP3s is that iPhones/iPods process the audio signal and they do it in analog only. Flash drives on the other hand don't do any of the processing at all. They hand that task over to the unit installed in your car which in turn does it digitally, thus giving a more pristine representation of the original MP3/WAV's quality. The Voyager comes with a USB extension cable that allows you to clear the height restriction in our tiny armrests. Overall I think this is the ideal piece of hardware to use with the iPod adapter that many of us will be getting. If anyone's interested, Newegg has a good deal on it: http://www.newegg.com/Product/Produc...82E16820233037 |
02-14-2008, 01:29 PM | #2 | |
Rep 8,033
1. Are you saying the iPod will not output a digital signal dricetly to the head unit in the car? Are you sure about this? 2. If you don't get the iPod option, is there a USB port that comes standard with the car that you can plug this into? Will it be recognized by the audio system in the car? 3. I thought the main advantage of getting the iPod option was the ability to browse through your collections with the car's interface. This clearly would not allow for that, right? |
02-14-2008, 01:32 PM | #3 | |
Rep 218
02-14-2008, 01:47 PM | #4 | |
Rep 2,937
1. Yes, I'm sure about that. iPhones/iPods do an internal digital to analog conversion and subsequent audio/video degradation occurs once the sound hits your speakers. 2. The iPod Adapter itself is simply a USB port. So no, without the iPod Adapter you won't have a USB port to plug this device into. And yes, iDrive will recognize this flash drive just fine as I've tested it in the 08 M5 and it works with no lag time whatsoever. 3. Actually USB flash drives do allow for browsing your content library through the iDrive interface. iPods and USB flash drives merely store the ID3 tags linked to your songs, so it's up to the iDrive system to sort, organize, and display your library. Hope this helps. Last edited by eclipsisNA; 02-14-2008 at 03:56 PM.. |
02-14-2008, 01:48 PM | #5 | |
2298
Rep 13,006
2. No; you have to get the 6FL option (iPod/USB adapter) 3. If the data in the USB is correctly tagged and organized you will see pretty much the same display organization as an iPod playlist scheme. |
02-14-2008, 01:57 PM | #6 | |
Moderator / European Editor
1545
Rep 6,754
Best regards, south |
02-14-2008, 02:02 PM | #7 |
2298
Rep 13,006
In other words, your iPod will no longer be an iPod, just a portable HDD.
02-14-2008, 02:12 PM | #8 |
1545
Rep 6,754
02-14-2008, 03:31 PM | #9 |
73
Rep 1,603
Drives: F80 M3
Will you notice a difference in sound quality on already lossy files? I wonder. The other question is which piece of electronics has the better DAC -- the iPod or the BMW head unit?
Either way, I'll be using the iPhone I already have for the double-duty. |
02-14-2008, 03:36 PM | #10 |
Rep 924
Drives: Ford Falcon Ute, Ducati 1198S
Hmmm I did not realise the iPod signal was analogue when using the iPod cable. Makes complete sense though...That is unacceptable. Flash drive for me!
02-14-2008, 03:51 PM | #11 | |
Rep 2,937
This is how my setup is going to work: 1. The Flash Voyager in my center console to provide music. 2. iPhone in my pocket for BMW Assist bluetooth. This way I don't have to plug in and unplug the iPhone every time I get in and out of the car. I don't see a reason to use the iPhone for double duty when it's a hassle and the Flash Voyager is only $50 shipped. Correct, because flash drives use FAT32 as their File Allocation Table, and FAT32 is native to Windows. Last edited by eclipsisNA; 02-14-2008 at 04:59 PM.. |
02-14-2008, 04:20 PM | #12 |
1545
Rep 6,754
02-14-2008, 04:28 PM | #13 |
Rep 271
I use the exact same flash memory, but the 16gb version. Works superb! I would really recommend this to all Bimmer guys who has the USB adapter.
Haven't figured out on how to use the "playlist" though... Haven't even tried yet so.. :P I guess the .m3u files has to be in the root of the flash drive? |
02-14-2008, 04:33 PM | #14 | |
Rep 2,937
Thanks to GeriFix for the above insight. |
02-14-2008, 05:08 PM | #15 |
Rep 926
Drives: e92 M3 6MT
Thanks for the tip about the FD Excellere. I would definitely get a 16GB when I get my car. It'll probably go down by then (price).
2008 e92 M3 6MT AW/BLACK (SOLD) 2009 e92 M3 6MT AW/FR |
02-14-2008, 06:04 PM | #16 |
Rep 2,106
02-14-2008, 06:11 PM | #17 |
Rep 2,937
I never use iTunes. Why? Every song they offer is 128kbps. I'd rather use Amazon, mp3sparks.com, or buy a used (and CHEAP) CD in very good condition off of Amazon that has the track I want. I've done that many times. My philosophy is 256/320kbps or nothing at all.
02-14-2008, 06:48 PM | #19 |
Rep 2,937
02-14-2008, 07:17 PM | #20 |
Rep 3,071
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
Will a USB powered portable disk drive work with the BMW USB port. I'm speaking of a drive similiar to the Western Digital Passport. Like the one found here:
http://www.westerndigital.com/global...e=frnt&lang=en
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
02-14-2008, 07:27 PM | #21 | |
Rep 1,274
02-14-2008, 07:32 PM | #22 | |
Rep 8,033
