07-24-2015, 01:51 PM | #1 |
Rep 471
e85 bluetooth content analyzers and installation kits!
What you see here is my ethanol content analyzer (ECA) solution. This is 100% compatible with the Fuel-it brand sensor installation kits at a fraction of the cost. This will allow you to read the data stream from a standard continental flex fuel sensor and view the data in several different ways. All ECA's feature interlocking connectors, a new 5 volt power supply, are prewired for upgradeability (Bluetooth and the digital display can be added after purchase) and feature upgradeable firmware via USB. Packages are: Package A - Standard ECA; $80.00 shipped - my analyzer with a 0-5 volt output lead for use with JB4 (or any other display / ECU that uses a 0-5v input). This will display your ethanol content over pin 15 of the JB4 harness (typically used for meth flow). You can then view your ethanol content via gauge high jacking, over the JB4 mobile app, and it will be logged as well. Includes a full 8 foot 3-wire harness, using OEM style GT150 female connector for the continental sensor (completely weather sealed), loomed in factory style protection, with a interlocking connector on the ECA end. Also includes 5 zip ties to secure the harness. Package B - Bluetooth enabled ECA; $105.00 shipped - the same analyzer and harness as above, plus the addition of a Bluetooth radio (Android compatible only). This will allow you to view your fuel ethanol content and fuel temperature on your Android smartphone or tablet via free smartphone / tablet app I've written (available at the Google Play store), or any of the above methods. V2 of the app should be available in early 2016, which will include blend calculators and a revised interface. Perfect for MDH, Cobb or JB4 users using meth. Add on A - digital LED display add on; $30.00 - Add a fully digital red stand alone LED readout. Can be added after the fact, and does not require JB4 or an Android device. This LED display is compatible with either of the above ECAs by simply plugging in the harness and placing it where you'd like. Shipping is free when ordered with package A or B, or $6.90 if ordered separately to the continental US. Perfect for MDH, Cobb or JB4 users using meth. Add on B - Bluetooth module; $35.00 - For non-bluetooth analyzers shipped 12-10-15 and on. Add a bluetooth module to your non-bluetooth ECA, to upgrade to the bluetooth capability and functionality of Package B. Includes a clear heat shrink tubing and a zip tie to bundle to the ECA. Shipping is $6.90 to the continental US. Perfect for MDH, Cobb or JB4 users using meth. PM me if you'd like to order or for international shipping rates, and I'll provide paypal info for payment. Here is the standard ECA: Modular connectors: Bluetooth enabled ECA: New 5 volt power supply: 8 foot harness with GT150 sensor connector and removable JB4 0-5v output lead with serial pin: Add on B - Bluetooth module: Add on A - Digital LED display: Three simultaneous outputs (0-5v JB4, Bluetooth and digital LED) driven at once: Here is a screenshot of JB4 mobile displaying ethanol content using JB4 pin 15: Here's a picture of JB4 mobile next to ethanol content on the fuel gauge (gauge hijacking in JB4): Here is a screenshot of the Bluetooth app displaying ethanol content and fuel temperature: Harness connected to the continental sensor: Harness run across the engine using the empty channel in the cowl wire carrier: ECA installed and running in the DME box:
08 Montego Blue 135i Coupe // Sport Package // Custom E30 tune // str8shot bluetooth enabled ECA // Walboro 255 inline pump // BMS downpipes // VRSF 7" FMIC // Injen intake // Berk ceramic exhaust // OEM 550i clutch // MFactory single mass flywheel // Vorshlag camber plates // Hotchkis FSB // Turner adjustable drop links // AST 5100 coilovers // Hawk HPS pads // Ti backing plates // Stoptech stainless brake lines // Turner 15mm spacers
09-02-2015, 03:51 PM | #3 |
Rep 471
Edited with screen shot of my new dedicated app. It's a work in progress, but relays all pertinent info as of today.
More features will be added shortly, including a blend calculator.
09-03-2015, 12:16 AM | #4 |
Rep 2,232
ETA on iPhone app availability? I find it will most likely be very hard to be close to exact reading the content on the fuel gauge through the JB4 hijack.
09-03-2015, 04:20 AM | #5 |
Rep 2,448
Can you please clarify what we need to install the sensor onto the fuel line? Also interested in iPhone app eta.
09-03-2015, 09:00 AM | #6 | |
Rep 471
To install the actual sensor, you would need one of the fuel-it sensor install kits, or I can make you a one off factory fuel line. I recommend the fuel-it kit since it would probably be cheaper. What I'm selling replaces their $129 analyzer that plugs into the sensor, and feeds the data to JB4 (mine would be $35 with harness). They also don't have a bluetooth version available yet.
09-09-2015, 03:17 PM | #9 |
Rep 471
If you can get the sensor installed on the car, the analyzer will work.
I believe the N55 uses the same fuel line as the N54, so you should be good. I would cross reference the fuel line on real OEM to see the applicable years. I'm currently working on a new enhancement that will allow you to read the ethanol content in the dash, negating the need for an external display.
09-11-2015, 06:00 PM | #11 |
Airborne!
19
Rep 533
So if I bought this...
https://www.skodot.com/us/catalog/pr...FQGqaQodEi0DEA And these.... http://m.summitracing.com/parts/rnb-...FQMJaQodx_kFyA I could just cut my line and do it myself correct? |
09-11-2015, 06:28 PM | #12 |
Rep 471
09-11-2015, 06:31 PM | #13 | |
Rep 471
You need 3/8" steel quick disconnect to 5/8 fuel line. You can cut it yourself, but you need a special tool to insert the fitting into the line. They're compression press fit into the line... |
09-16-2015, 11:29 PM | #14 |
Rep 164
Do I need to be running the fuelit analyzer along with the ethanol sensor or can I just run the ethanol sensor and be compatible with your basic eca?
The basic eca can be read over the jb4 mobile app correct? |
09-17-2015, 08:09 PM | #15 | |
Rep 471
It replaces their $129 jb4 analyzer and does the same thing. The basic eca will output to jb4 and can be read by jb4 mobile.
10-02-2015, 04:37 PM | #16 |
Rep 471
Shipped a couple more kits in all flavors (bluetooth, JB4 only, and with the gauge).
Tried out the red gauge - it looks pretty sharp. It's going to look pretty rad behind the buyers vent:
12-02-2015, 10:26 AM | #17 |
Rep 471
Christmas is nearly here bump!
12-14-2015, 10:38 AM | #18 |
Rep 471
New power supplies are in. Always trying to improve things, I thought I'd give these a try.
These guys produce a rock steady 5 volts flat, with no ripple regardless of input voltage. Perfect for a car where the voltage fluctuates depending on RPM, alternator output, etc. Should provide much more consistency than the USB power supplies of past. These will insert inline between the sensor harness with a provided y-connector, instead of being powered through the USB port (power through the USB port uses the ECA's on board voltage regulator, which sucked some voltage). Power supply: Producing 5 volts with a 12.75 volt input: Producing 5 volts with a 10.75 volt input:
12-23-2015, 10:38 AM | #19 |
Rep 792
Drives: 135i + F25 X3 35i FBO
bump still waiting on a response to my PM, and waiting for shipping status
2013 135i Coupe / LMB on Oyster / 6 Speed / BMWP Front Bumper, Side Skirts, Suspension, Electonic Steering Wheel V2, and CF Rear Spoiler / Jb4 G5 ISO / BMS Intake / ActiveAutowerke Downpipe, Axleback, Intercooler, Strut Bar / BMS CDV Mod / F30 Performance Shift Knob/E-Brake Handle + Bimmian Alcentara Boots / MS8 + JL600/6 + JX500/1 Powering a JL 10w3 in Custom Trunk Box
12-23-2015, 05:53 PM | #20 |
Rep 471
I PM'd you the tracking number a few minutes ago.
12-30-2015, 09:13 AM | #21 |
Rep 471
First digital display shipping out. Ended up using RJ45 connectors for the connection.
Future ones will have a female connector on the ECA side instead of male (doesn't make a difference, just eliminates the cost of the coupler).
03-20-2016, 09:10 AM | #22 |
Rep 471
Just received the order of boards I was waiting for. All back orders will go out this week.
